Текущее время: 08 ноя 2026, 13:26
 Заголовок сообщения: Prestigio MultiPad 4 Ultra quad 8.0 3G pmp7280c 3g quad вечный перезагруз
СообщениеДобавлено: 03 июн 2017, 17:03
Всем ДВС!
Изначально висел на лого. При попытке прошивки вставал на 5%. Заменил флеш. Прошивка прошла успешно. Теперь лого на 7 секунд и перезагруз. Встал на UART
UART
<hit enter to activate fiq debugger>
▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒[PWRAP] pwrap_init_preloader
[PWRAP] pwrap_init
[PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=0 rdata=5AA5
[PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=1 rdata=5AA5
[PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=2 rdata=5AA5
[PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=3 rdata=5AA5
[PMIC_WRAP]wrap_init pass,the return value=0.
pl pmic init start
pl pmic efuse start
pl pmic efuse BUCK trim
[0x1C8]=0xEC02
[0x1CA]=0x805F
[0x20E]=0xB0
[0x260]=0xF0
[0x286]=0x70
pl pmic efuse end
pl pmic en rst [0x126]=0x13
[0xE]=0x1
[0x540]=0xA0
Battery exist
[0xE]=0x1
[0x540]=0xA0
pl vm read [0x290]=0x68
pl vm set [0x290]=0x6A
pl vm check [0x290]=0x6A
pl pmic init done
[PLFM] Init I2C: OK(0)
[PLFM] Init PWRAP: OK(0)
[PLFM] Init PMIC: OK(0)
[PLFM] chip[CA00]
[BLDR] Build Time: 20130820-174037
==== Dump RGU Reg ========
RGU MODE: 34
RGU LENGTH: FFE0
RGU STA: 40000000
RGU INTERVAL: FFF
RGU SWSYSRST: 0
==== Dump RGU Reg End ====
RGU: g_rgu_satus:2
mtk_wdt_mode_config mode value=34, tmp:22000030
PL RGU RST: ??
SW reset with bypass power key flag
Find bypass powerkey flag
mtk_wdt_mode_config mode value=70, tmp:22000071
kpd register for pmic set!
mt_usb_calibraion: input_reg = 0x0
mt_usb_calibraion: term_vref = 0x0, clkref = 0x0, vrt_vref = 0x0,
[RTC] bbpu = 0xD, con = 0x406
[RTC] irqsta = 0x0, pdn1 = 0x1000, pdn2 = 0x201, spar0 = 0x40, spar1 = 0x800
[RTC] new_spare0 = 0x0, new_spare1 = 0x1, new_spare2 = 0x1, new_spare3 = 0x1
[PLFM] WDT reboot bypass power key!
[RTC] rtc_bbpu_power_on done
[EMI] enable_combo_dis:0,has_emmc_nand:0
[SD0] Bus Width: 1
[SD0] SET_CLK(260kHz): SCLK(259kHz) MODE(0) DDR(0) DIV(193) DS(0) RS(0)
[SD0] Switch to High-Speed mode!
[SD0] SET_CLK(260kHz): SCLK(259kHz) MODE(2) DDR(1) DIV(96) DS(0) RS(0)
[SD0] Bus Width: 8
[SD0] Size: 7376 MB, Max.Speed: 52000 kHz, blklen(512), nblks(15106048), ro(0)
[SD0] Initialized
[SD0] SET_CLK(52000kHz): SCLK(50000kHz) MODE(2) DDR(1) DIV(0) DS(0) RS(0)
msdc_ett_offline_to_pl: size<2> m_id<0x70>
msdc <0> <HYNIX > <MMC08G>
msdc <1> <xxxxxx> <MMC08G>
msdc failed to find
*******EMMC_INFO*******
eMMC partition size(1 block = 512Bytes):
BOOT1:<8192> blocks
BOOT2:<8192> blocks
RPMB :<8192> blocks
GP1 :<0> blocks
GP2 :<0> blocks
GP3 :<0> blocks
GP4 :<0> blocks
USER :<15106048> blocks
found:1,i:0
[EMI] DDR3
[EMI] eMMC/NAND ID = 70,1,0,4D,4D,43,30,38,47
[EMI] MDL number = 0
init ddr3 x32
Delay test
rank 0 coarse = 12
rank 0 fine = 40
10:| 0 1 1 1 0 0
opt_dle value:7
byte:0, (DQS,DQ)=(8,A)
byte:1, (DQS,DQ)=(8,B)
byte:2, (DQS,DQ)=(8,A)
byte:3, (DQS,DQ)=(8,B)
[EMI] DRAMC calibration passed
[MEM] complex R/W mem test pass
▒▒▒▒▒▒▒▒▒▒▒============func=load_pt_from_fixed_addr===scan pmt from 700000=====
find pt at 700000
next pt 0
64bit parse PMT
find pt
part PRELOADER size 0000000000000000 0000000000600000
part MBR size 0000000000600000 0000000000080000
part EBR1 size 0000000000680000 0000000000080000
part __NODL_PMT size 0000000000700000 0000000000400000
part __NODL_PRO_INFO size 0000000000B00000 0000000000300000
part __NODL_NVRAM size 0000000000E00000 0000000000500000
part __NODL_PROTECT_F size 0000000001300000 0000000000A00000
part __NODL_PROTECT_S size 0000000001D00000 0000000000A00000
part __NODL_SECCFG size 0000000002700000 0000000000020000
part UBOOT size 0000000002720000 0000000000060000
part BOOTIMG size 0000000002780000 0000000000600000
part RECOVERY size 0000000002D80000 0000000000600000
part SEC_RO size 0000000003380000 0000000000600000
part __NODL_MISC size 0000000003980000 0000000000080000
part LOGO size 0000000003A00000 0000000000300000
part EBR2 size 0000000003D00000 0000000000080000
part __NODL_EXPDB size 0000000003D80000 0000000000A00000
part ANDROID size 0000000004780000 0000000028A00000
part CACHE size 000000002D180000 0000000007E00000
part USRDATA size 0000000034F80000 00000000A0000000
part __NODL_FAT size 00000000D4F80000 00000000F7780000
[PART] blksz: 512B
[PART] [0x0000000000000000-0x00000000005FFFFF] "PRELOADER" (12288 blocks)
[PART] [0x0000000000600000-0x000000000067FFFF] "MBR" (1024 blocks)
[PART] [0x0000000000680000-0x00000000006FFFFF] "EBR1" (1024 blocks)
[PART] [0x0000000000700000-0x0000000000AFFFFF] "PMT" (8192 blocks)
[PART] [0x0000000000B00000-0x0000000000DFFFFF] "PRO_INFO" (6144 blocks)
[PART] [0x0000000000E00000-0x00000000012FFFFF] "NVRAM" (10240 blocks)
[PART] [0x0000000001300000-0x0000000001CFFFFF] "PROTECT_F" (20480 blocks)
[PART] [0x0000000001D00000-0x00000000026FFFFF] "PROTECT_S" (20480 blocks)
[PART] [0x0000000002700000-0x000000000271FFFF] "SECURE" (256 blocks)
[PART] [0x0000000002720000-0x000000000277FFFF] "UBOOT" (768 blocks)
[PART] [0x0000000002780000-0x0000000002D7FFFF] "BOOTIMG" (12288 blocks)
[PART] [0x0000000002D80000-0x000000000337FFFF] "RECOVERY" (12288 blocks)
[PART] [0x0000000003380000-0x000000000397FFFF] "SECSTATIC" (12288 blocks)
[PART] [0x0000000003980000-0x00000000039FFFFF] "MISC" (1024 blocks)
[PART] [0x0000000003A00000-0x0000000003CFFFFF] "LOGO" (6144 blocks)
[PART] [0x0000000003D00000-0x0000000003D7FFFF] "EBR2" (1024 blocks)
[PART] [0x0000000003D80000-0x000000000477FFFF] "EXPDB" (20480 blocks)
[PART] [0x0000000004780000-0x000000002D17FFFF] "ANDSYSIMG" (1331200 blocks)
[PART] [0x000000002D180000-0x0000000034F7FFFF] "CACHE" (258048 blocks)
[PART] [0x0000000034F80000-0x000001FFD4F7FFFF] "USER" (-3145728 blocks)
[PART] [0x000001FFD4F80000-0x000001FFD4F7FFFF] "FAT" (0 blocks)
[ROM_INFO] 'v2','0x2700000','0x20000','0x3380000','0x2C00'
[SEC_K] SML KEY AC = 0
[SEC_K] SBC_PUBK Found
[SEC] AES Legacy : 0
[SEC] SECCFG AC : 1
[SEC] read '0x2700000'
0x41,0x4E,0x44,0x5F,0x53,0x45,0x43,0x43,
[LIB] SecLib.a '20121226-155014'
[LIB] CFG read size '0x4000' '0x1860'
[LIB] Name =
[LIB] Config = 0x22, 0x22
0x31,0x41,0x35,0x35
[platform_vusb_on] PASS
[TOOL] <UART> wait sync time 150ms->131ms
[TOOL] <UART> receieved data: ()
[PART] Image with part header
[PART] name : LK
[PART] addr : FFFFFFFFh
[PART] size : 239992
[PART] magic: 58881688h
[PART] load "UBOOT" from 0x0000000002720200 (dev) to 0x81E00000 (mem) [SUCCESS]
[PART] load speed: 15624KB/s, 239992 bytes, 15ms
[SECRO] Don't read
[AUTHEN] rsa.N length = 1024 bytes
[AUTHEN] rsa.E length = 20 bytes
[LIB] NS-CHIP
[LIB] Don't check
Device APC domain init setup:
[PLFM] ram_console->start=0x23A
[PLFM] ram_console(0x2)=0x2 (boot reason)
0:dram_rank_size:40000000
[PLFM] boot reason: 4
[PLFM] boot mode: 0
[PLFM] META COM0: 0
[PLFM] <0x800A0008>: 0x0
[PLFM] boot time: 403ms
[BLDR] jump to 0x81E00000
[BLDR] <0x81E00000>=0xEA000007
[BLDR] <0x81E00004>=0xEA006369
[PROFILE] ------- i2c init takes 0 ms --------
mtk_wdt_mode LK config mode value=71
mtk_wdt_mode_config LK mode value=30, tmp:22000030
UB wdt init
mtk_wdt_mode LK config mode value=30
mtk_wdt_mode_config LK mode value=79, tmp:22000079
[LEDS]LK: leds_init: mt65xx_backlight_off
[LEDS]LK: mt65xx_backlight_off
[LEDS]LK: lcd-backlight level is 0
[DDP] disp_bls_set_backlight: 0, PWM div 36
[PROFILE] ------- led init takes 2 ms --------
[LEDS]LK: isink_init: turn on PMIC6320 isink
DISP/disp common log enabled
DISP/lcd log enabled
DISP_Init, 599
DISP/DISP_Init, 603
DISP/DISP_Init, 608
DISP/DISP_Init, 614
DISP/DISP_Init, 637
[DDP]disp_path_config(), srcModule=2, addr=0x0, inFormat=0,
pitch=0, bgROI(0,0,1024,768), bgColor=0, outFormat=0, dstModule=13, dstAddr=0x0,
DISI_MODULE_DPI0
ASSERT error OVLLayerSwitch,89
ASSERT error OVLLayerConfig,161
ASSERT error
ASSERT error
ASSERT error
ASSERT error
RDMA: w=1024, h=768, pitch=3072, mode=0
ASSERT error
[DSS]===== DISP OVL Reg Dump: ============
[DSS](000)OVL_STA =0x1e
[DSS](004)OVL_INTEN =0xf
[DSS](008)OVL_INTSTA =0x0
[DSS](00C)OVL_EN =0x1
[DSS](010)OVL_TRIG =0x0
[DSS](014)OVL_RST =0x0
[DSS](020)OVL_ROI_SIZE =0x3000400
[DSS](024)OVL_DATAPATH_CON =0x0
[DSS](028)OVL_ROI_BGCLR =0x0
[DSS](02C)OVL_SRC_CON =0x4
[DSS](030)OVL_L0_CON =0xff
[DSS](034)OVL_L0_SRCKEY =0x0
[DSS](038)OVL_L0_SRC_SIZE =0x0
[DSS](03C)OVL_L0_OFFSET =0x0
[DSS](040)OVL_L0_ADDR =0x0
[DSS](044)OVL_L0_PITCH =0x0
[DSS](0C0)OVL_RDMA0_CTRL =0x3ff0000
[DSS](0C4)OVL_RDMA0_MEM_START_TRIG =0x0
[DSS](0C8)OVL_RDMA0_MEM_GMC_SETTING =0x10101010
[DSS](0CC)OVL_RDMA0_MEM_SLOW_CON =0x0
[DSS](0D0)OVL_RDMA0_FIFO_CTRL =0x1000000
[DSS](050)OVL_L1_CON =0xff
[DSS](054)OVL_L1_SRCKEY =0x0
[DSS](058)OVL_L1_SRC_SIZE =0x0
[DSS](05C)OVL_L1_OFFSET =0x0
[DSS](060)OVL_L1_ADDR =0x0
[DSS](064)OVL_L1_PITCH =0x0
[DSS](0E0)OVL_RDMA1_CTRL =0x3ff0000
[DSS](0E4)OVL_RDMA1_MEM_START_TRIG =0x0
[DSS](0E8)OVL_RDMA1_MEM_GMC_SETTING =0x10101010
[DSS](0EC)OVL_RDMA1_MEM_SLOW_CON =0x0
[DSS](0F0)OVL_RDMA1_FIFO_CTRL =0x1000000
[DSS](070)OVL_L2_CON =0x1000
[DSS](074)OVL_L2_SRCKEY =0xff
[DSS](078)OVL_L2_SRC_SIZE =0x3000400
[DSS](07C)OVL_L2_OFFSET =0x0
[DSS](080)OVL_L2_ADDR =0xbf800000
[DSS](084)OVL_L2_PITCH =0x800
[DSS](100)OVL_RDMA2_CTRL =0x3ff0001
[DSS](104)OVL_RDMA2_MEM_START_TRIG =0x0
[DSS](108)OVL_RDMA2_MEM_GMC_SETTING =0x10101010
[DSS](10C)OVL_RDMA2_MEM_SLOW_CON =0x0
[DSS](110)OVL_RDMA2_FIFO_CTRL =0x1000000
[DSS](090)OVL_L3_CON =0xff
[DSS](094)OVL_L3_SRCKEY =0x0
[DSS](098)OVL_L3_SRC_SIZE =0x0
[DSS](09C)OVL_L3_OFFSET =0x0
[DSS](0A0)OVL_L3_ADDR =0x0
[DSS](0A4)OVL_L3_PITCH =0x0
[DSS](120)OVL_RDMA3_CTRL =0x3ff0000
[DSS](124)OVL_RDMA3_MEM_START_TRIG =0x0
[DSS](128)OVL_RDMA3_MEM_GMC_SETTING =0x10101010
[DSS](12C)OVL_RDMA3_MEM_SLOW_CON =0x0
[DSS](130)OVL_RDMA3_FIFO_CTRL =0x1000000
[DSS](1C4)OVL_DEBUG_MON_SEL =0x1800000
[DSS](1C4)OVL_RDMA0_MEM_GMC_SETTING2 =0x1800000
[DSS](1C8)OVL_RDMA1_MEM_GMC_SETTING2 =0x180
[DSS](1CC)OVL_RDMA2_MEM_GMC_SETTING2 =0x0
[DSS](1D0)OVL_RDMA3_MEM_GMC_SETTING2 =0x0
[DSS](240)OVL_FLOW_CTRL_DBG =0xf8c02
[DSS](244)OVL_ADDCON_DBG =0x0
[DSS](248)OVL_OUTMUX_DBG =0x0
[DSS](24C)OVL_RDMA0_DBG =0x10000001
[DSS](250)OVL_RDMA1_DBG =0x10000001
[DSS](254)OVL_RDMA2_DBG =0x10000001
[DSS](258)OVL_RDMA3_DBG =0x10000001
[DSS]===== DISP WDMA1 Reg Dump: ============
[DSS](000)WDMA_INTEN =0x0
[DSS](004)WDMA_INTSTA =0x0
[DSS](008)WDMA_EN =0x0
[DSS](00C)WDMA_RST =0x0
[DSS](010)WDMA_SMI_CON =0x3
[DSS](014)WDMA_CFG =0x0
[DSS](018)WDMA_SRC_SIZE =0x0
[DSS](01C)WDMA_CLIP_SIZE =0x0
[DSS](020)WDMA_CLIP_COORD =0x0
[DSS](024)WDMA_DST_ADDR =0x0
[DSS](028)WDMA_DST_W_IN_BYTE =0x0
[DSS](02C)WDMA_ALPHA =0xff
[DSS](030)WDMA_BUF_ADDR =0x0
[DSS](034)WDMA_STA =0x1
[DSS](038)WDMA_BUF_CON1 =0x1000ff
[DSS](03C)WDMA_BUF_CON2 =0x10101010
[DSS](040)WDMA_C00 =0x0
[DSS](044)WDMA_C02 =0x0
[DSS](048)WDMA_C10 =0x0
[DSS](04C)WDMA_C12 =0x0
[DSS](050)WDMA_C20 =0x0
[DSS](054)WDMA_C22 =0x0
[DSS](058)WDMA_PRE_ADD0 =0x0
[DSS](05C)WDMA_PRE_ADD2 =0x0
[DSS](060)WDMA_POST_ADD0 =0x0
[DSS](064)WDMA_POST_ADD2 =0x0
[DSS](070)WDMA_DST_U_ADDR =0x0
[DSS](074)WDMA_DST_V_ADDR =0x0
[DSS](078)WDMA_DST_UV_PITCH =0x0
[DSS](090)WDMA_DITHER_CON =0x0
[DSS](0A0)WDMA_FLOW_CTRL_DBG =0x1
[DSS](0A4)WDMA_EXEC_DBG =0x0
[DSS](0A8)WDMA_CLIP_DBG =0x0
[DSS]===== DISP RDMA0 Reg Dump: ========
[DSS](000)RDMA_INT_ENABLE =0x0
[DSS](004)RDMA_INT_STATUS =0x0
[DSS](010)RDMA_GLOBAL_CON =0x101
[DSS](014)RDMA_SIZE_CON_0 =0x400
[DSS](018)RDMA_SIZE_CON_1 =0x300
[DSS](024)RDMA_MEM_CON =0x80
[DSS](028)RDMA_MEM_START_ADDR =0x0
[DSS](02C)RDMA_MEM_SRC_PITCH =0x0
[DSS](030)RDMA_MEM_GMC_SETTING_0 =0x10101010
[DSS](034)RDMA_MEM_SLOW_CON =0x0
[DSS](030)RDMA_MEM_GMC_SETTING_1 =0x20
[DSS](040)RDMA_FIFO_CON =0x80f00008
[DSS](054)RDMA_CF_00 =0x0
[DSS](058)RDMA_CF_01 =0x0
[DSS](05C)RDMA_CF_02 =0x0
[DSS](060)RDMA_CF_10 =0x0
[DSS](064)RDMA_CF_11 =0x0
[DSS](068)RDMA_CF_12 =0x0
[DSS](06C)RDMA_CF_20 =0x0
[DSS](070)RDMA_CF_21 =0x0
[DSS](074)RDMA_CF_22 =0x0
[DSS](078)RDMA_CF_PRE_ADD0 =0x0
[DSS](07C)RDMA_CF_PRE_ADD1 =0x0
[DSS](080)RDMA_CF_PRE_ADD2 =0x0
[DSS](084)RDMA_CF_POST_ADD0 =0x0
[DSS](088)RDMA_CF_POST_ADD1 =0x0
[DSS](08C)RDMA_CF_POST_ADD2 =0x0
[DSS](090)RDMA_DUMMY =0xfff00000
[DSS](094)RDMA_DEBUG_OUT_SEL =0x0
[DSS](0x020)CFG_SCL_MOUT_EN =0x0
[DSS](0x024)CFG_OVL_MOUT_EN =0x2
[DSS](0x028)CFG_COLOR_MOUT_EN =0x0
[DSS](0x02C)CFG_TDSHP_MOUT_EN =0x0
[DSS](0x030)CFG_MOUT_RST =0x0
[DSS](0x034)CFG_RDMA0_OUT_SEL =0x2
[DSS](0x038)CFG_RDMA1_OUT_SEL =0x0
[DSS](0x03C)CFG_OVL_PQ_OUT_SEL =0x0
[DSS](0x040)CFG_WDMA0_SEL =0x0
[DSS](0x044)CFG_OVL_SEL =0x0
[DSS](0x048)CFG_OVL_PQ_IN_SEL =0x0
[DSS](0x04C)CFG_COLOR_SEL =0x0
[DSS](0x050)CFG_TDSHP_SEL =0x0
[DSS](0x054)CFG_BLS_SEL =0x0
[DSS](0x058)CFG_DBI_SEL =0x0
[DSS](0x05C)CFG_DPI0_SEL =0x0
[DSS](0x60))CFG_MISC =0x0
[DSS](0x70))CFG_PATH_DEBUG0 =0x0
[DSS](0x74))CFG_PATH_DEBUG1 =0x0
[DSS](0x78))CFG_PATH_DEBUG2 =0x600013
[DSS](0x7C))CFG_PATH_DEBUG3 =0x0
[DSS](0x80))CFG_PATH_DEBUG4 =0x0
[DSS](0x100)CFG_CG_CON0 =0xffff1ecc
[DSS](0x104)CFG_CG_SET0 =0x0
[DSS](0x108)CFG_CG_CLR0 =0x0
[DSS](0x110)CFG_CG_CON1 =0xfffffcf8
[DSS](0x114)CFG_CG_SET1 =0x0
[DSS](0x118)CFG_CG_CLR1 =0x0
[DSS](0x120)CFG_HW_DCM_EN0 =0x0
[DSS](0x124)CFG_HW_DCM_EN_SET0 =0x0
[DSS](0x128)CFG_HW_DCM_EN_CLR0 =0x0
[DSS](0x130)CFG_HW_DCM_EN1 =0x0
[DSS](0x134)CFG_HW_DCM_EN_SET1 =0x0
[DSS](0x138)CFG_HW_DCM_EN_CLR1 =0x0
[DSS](0x800)CFG_MBIST_DONE0 =0x0
[DSS](0x804)CFG_MBIST_DONE1 =0x0
[DSS](0x808)CFG_MBIST_FAIL0 =0x0
[DSS](0x80C)CFG_MBIST_FAIL1 =0x3ffff
[DSS](0x810)CFG_MBIST_FAIL2 =0x0
[DSS](0x814)CFG_MBIST_HOLDB0 =0xffffffff
[DSS](0x818)CFG_MBIST_HOLDB1 =0xffffffff
[DSS](0x81C)CFG_MBIST_MODE0 =0xff
[DSS](0x820)CFG_MBIST_MODE1 =0x55aa0000
[DSS](0x824)CFG_MBIST_BSEL0 =0x0
[DSS](0x828)CFG_MBIST_BSEL1 =0x0
[DSS](0x82C)CFG_MBIST_BSEL2 =0x0
[DSS](0x830)CFG_MBIST_BSEL3 =0x5aaaa50a
[DSS](0x834)CFG_MBIST_CON =0x5555aaa5
[DSS](0x870)CFG_DEBUG_OUT_SEL =0x0
[DSS](0x874)CFG_TEST_CLK_SEL =0x0
[DSS](0x880)CFG_DUMMY =0x0
[DSS]((0x0) CFG_MUTEX_INTEN =0x1
[DSS]((0x4) CFG_MUTEX_INTSTA =0x0
[DSS]((0x8) CFG_REG_UPD_TIMEOUT=0xff
[DSS]((0xC) CFG_REG_COMMIT =0x0
[DSS](0x20)CFG_MUTEX_EN(0) =0x0
[DSS](0x24)CFG_MUTEX(0) =0x3
[DSS](0x28)CFG_MUTEX_RST(0) =0x0
[DSS](0x2c)CFG_MUTEX_MOD(0) =0x84
[DSS](0x30)CFG_MUTEX_SOF(0) =0x2
[DSS](0x40)CFG_MUTEX_EN(1) =0x0
[DSS](0x44)CFG_MUTEX(1) =0x0
[DSS](0x48)CFG_MUTEX_RST(1) =0x0
[DSS](0x4c)CFG_MUTEX_MOD(1) =0x0
[DSS](0x50)CFG_MUTEX_SOF(1) =0x0
[DSS](0x60)CFG_MUTEX_EN(2) =0x0
[DSS](0x64)CFG_MUTEX(2) =0x0
[DSS](0x68)CFG_MUTEX_RST(2) =0x0
[DSS](0x6c)CFG_MUTEX_MOD(2) =0x0
[DSS](0x70)CFG_MUTEX_SOF(2) =0x0
[DSS](0x80)CFG_MUTEX_EN(3) =0x0
[DSS](0x84)CFG_MUTEX(3) =0x0
[DSS](0x88)CFG_MUTEX_RST(3) =0x0
[DSS](0x8c)CFG_MUTEX_MOD(3) =0x0
[DSS](0x90)CFG_MUTEX_SOF(3) =0x0
[DSS](0xa0)CFG_MUTEX_EN(4) =0x0
[DSS](0xa4)CFG_MUTEX(4) =0x0
[DSS](0xa8)CFG_MUTEX_RST(4) =0x0
[DSS](0xac)CFG_MUTEX_MOD(4) =0x0
[DSS](0xb0)CFG_MUTEX_SOF(4) =0x0
disp_bls_config : PWM config data (0,0)
[DDP] disp_bls_config : gBLSMutexID = 3
DISP/DPI_Set_DrivingCurrent not implement for 6575[DISP] - uboot - DSI_PowerOn. 0x 0,0x 0,0x 0
[DISP] - uboot - DSI_PowerOff. 0x 0,0x 0,0x 0
DISP/DISP_Init, 642
DISP/DISP_Init, 657
[PROFILE] ------- disp init takes 276 ms --------
[LK_pmic6329_init] Start...................
[LK_PMIC_INIT] PMIC CID=0x2020
[LK_PMIC_INIT] Turn Off chrind
[LK_PMIC_INIT_SETTING_V1] PMIC Chip = 2020
[LK_PMIC_INIT_SETTING_V1] 20121220 (>=2)
[LK_PMIC_INIT_SETTING_V1] Done
[LK_PMIC_CUSTOM_SETTING_V1] Done
[PROFILE] ------- pmic6329_init takes 4 ms --------
[PROFILE] ------- platform_early_init takes 496 ms --------
[mmc_legacy_init]: start
[mmc_legacy_init]: start mmc_init_host
[msdc_init]: start
[SD0] Bus Width: 1
[msdc_init]: finish succesfully
[mmc_legacy_init]: start mmc_init_card
[mmc_init_card]: start
[SD0] Bus Width: 8
[SD0] Initialized
[mmc_init_card]: finish successfully
addr_trans_init
addr_trans_init done
[mt_part_register_device]
[mt_part_register_device]malloc 1024 : 81e59508
mt6577_part_init_pmt
find pt at 700000
next pt 0
64bit parse PMT, size pt = 88
Find pt
partition PRELOADER size 0000000000000000 0000000000600000
partition MBR size 0000000000600000 0000000000080000
partition EBR1 size 0000000000680000 0000000000080000
partition __NODL_PMT size 0000000000700000 0000000000400000
partition __NODL_PRO_INFO size 0000000000b00000 0000000000300000
partition __NODL_NVRAM size 0000000000e00000 0000000000500000
partition __NODL_PROTECT_F size 0000000001300000 0000000000a00000
partition __NODL_PROTECT_S size 0000000001d00000 0000000000a00000
partition __NODL_SECCFG size 0000000002700000 0000000000020000
partition UBOOT size 0000000002720000 0000000000060000
partition BOOTIMG size 0000000002780000 0000000000600000
partition RECOVERY size 0000000002d80000 0000000000600000
partition SEC_RO size 0000000003380000 0000000000600000
partition __NODL_MISC size 0000000003980000 0000000000080000
partition LOGO size 0000000003a00000 0000000000300000
partition EBR2 size 0000000003d00000 0000000000080000
partition __NODL_EXPDB size 0000000003d80000 0000000000a00000
partition ANDROID size 0000000004780000 0000000028a00000
partition CACHE size 000000002d180000 0000000007e00000
partition USRDATA size 0000000034f80000 00000000a0000000
partition __NODL_FAT size 00000000d4f80000 00000000f7780000
[SD0] boot device found
[PROFILE] ------- NAND/EMMC init takes 101 ms --------
[mt_part_get_partition] MISC
[mt_part_get_partition] 1cc00
[LK_ENV]ENV SIG Wrong
[LK_ENV]no valid env
[PROFILE] ------- ENV init takes 3 ms --------
[mt_part_get_partition] LOGO
[mt_part_get_partition] 1d000
[LK_BOOT] LOGO magic number : 0x58881688
[LK_BOOT] LOGO name : LOGO
[LK_BOOT] LOGO size : 1093915
read the data of LOGO
[AUXADC] u4Sample_times=1, ret_data=786, u4channel[0]=786.
[AUXADC] u4Sample_times=2, ret_data=786, u4channel[0]=1572.
[AUXADC] u4Sample_times=3, ret_data=786, u4channel[0]=2358.
[AUXADC] u4Sample_times=4, ret_data=786, u4channel[0]=3144.
[AUXADC] u4Sample_times=5, ret_data=786, u4channel[0]=3930.
[AUXADC] adc_result_temp=786, adc_result=3684, r_val_temp=4.
bq24196_chrg_status = 0
is_low_battery, FALSE
DISP/panel is enabled
[LK]DISP_GetPages: disp_fb_pages=2!
DISP/[Func]LCD_ConfigOVL
disp_path_config_layer, 48
[DDP]disp_path_config_layer(), layer=2, source=0, fmt=1, addr=0xbf800000, x=0, y=0
w=1024, h=768, pitch=2048, keyEn=0, key=0, aen=0, alpha=0
[DDP]disp_path_config_layer(), layer=3, source=0, fmt=1, addr=0xbf980000, x=0, y=0
w=1024, h=768, pitch=2048, keyEn=1, key=-16777216, aen=0, alpha=0
[wwy] hardware address = bfc80000, fb_offset_logo = 3
[DDP]disp_path_config_layer(), layer=2, source=0, fmt=1, addr=0xbfc80000, x=0, y=0
[PROFILE] ------- load_logo takes 249 ms --------
kpd read addr: 0x0502: data:0x41fc
[AUXADC] u4Sample_times=1, ret_data=787, u4channel[0]=787.
[AUXADC] u4Sample_times=2, ret_data=787, u4channel[0]=1574.
[AUXADC] u4Sample_times=3, ret_data=787, u4channel[0]=2361.
[AUXADC] u4Sample_times=4, ret_data=787, u4channel[0]=3148.
[AUXADC] u4Sample_times=5, ret_data=787, u4channel[0]=3935.
[AUXADC] adc_result_temp=787, adc_result=3689, r_val_temp=4.
[LEDS]LK: mt65xx_backlight_on
[LEDS]LK: lcd-backlight level is 255
[DDP] disp_bls_set_backlight: 255, PWM div 36
[PROFILE] ------- backlight takes 7 ms --------
[FACTORY] Check factory boot
[FACTORY] Wait 50ms for special keys
detecting pmic just reset
[RECOVERY] Check recovery boot
[RECOVERY] Wait 50ms for special keys
[mboot_recovery_load_misc]: size is 6144
[mboot_recovery_load_misc]: misc_addr is 0x81e5d920
[LK_BOOT] Load 'MISC' partition to 0x81E5D920 (6144 bytes in 1 ms)
[pmic_detect_powerkey] Release
WDT get boot reason is 4 from pre-loader
[is_force_boot] Bypass Kernel Power off charging mode and enter Normal Boot
[kernel_power_off_charging_detection] Turn off HW Led
< Kernel Enter Normal Boot >
[PROFILE] ------- boot mode select takes 155 ms --------
[partition_get_index]find preloader PRELOADER index 0
[partition_get_index]find seccfg SECURE index 8
[mt_part_get_partition] SECURE
[mt_part_get_partition] 13800
[partition_get_index]find sec_ro SECSTATIC index 12
[mt_part_get_partition] SECSTATIC
[mt_part_get_partition] 19c00
[SEC_SRO] Search SECRO - HASH is not corrected
[SEC_INIT] Search SECRO - SW sec boot not enabled
[AUXADC] u4Sample_times=1, ret_data=761, u4channel[0]=761.
[AUXADC] u4Sample_times=2, ret_data=761, u4channel[0]=1522.
[AUXADC] u4Sample_times=3, ret_data=761, u4channel[0]=2283.
[AUXADC] u4Sample_times=4, ret_data=762, u4channel[0]=3045.
[AUXADC] u4Sample_times=5, ret_data=762, u4channel[0]=3807.
[AUXADC] adc_result_temp=761, adc_result=3567, r_val_temp=4.
g_boot_mode = 0
check VBAT=3567 mV with 3450 mV
[bq24196_dump_register] Reg[0x0]=0x37
[bq24196_dump_register] Reg[0x1]=0xB
[bq24196_dump_register] Reg[0x2]=0x60
[bq24196_dump_register] Reg[0x3]=0x11
[bq24196_dump_register] Reg[0x4]=0xB2
[bq24196_dump_register] Reg[0x5]=0x9A
[bq24196_dump_register] Reg[0x6]=0x3
[bq24196_dump_register] Reg[0x7]=0x4B
[bq24196_dump_register] Reg[0x8]=0x0
[bq24196_dump_register] Reg[0x9]=0x80
[bq24196_dump_register] Reg[0xA]=0x2B
[PROFILE] ------- battery init takes 11 ms --------
show_logo, in_addr=0xbf4000a4, fb_addr=0xbf800000, logolen=89267, ticks=1470
ticks=1536
[wwy] hardware address = bf800000, fb_offset_logo = 0
[PROFILE] ------- show logo takes 74 ms --------
[PROFILE] ------- sw_env takes 0 ms --------
[PROFILE] ------- platform_init takes 619 ms --------
[LIB] NS-CHIP
[LIB] Don't check
[mt_part_get_partition] BOOTIMG
[mt_part_get_partition] 13c00
part page addr is 0xd
[LK_BOOT] Android Partition Name : BOOTIMG
[LK_BOOT] Android Boot IMG Hdr - Magic : ANDROID
[LK_BOOT] Android Boot IMG Hdr - Kernel Size : 0x40bac0
[LK_BOOT] Android Boot IMG Hdr - Rootfs Size : 0x9b0b5
[LK_BOOT] Android Boot IMG Hdr - Page Size : 0x800
> page count of kernel image = 2072
> kernel mem offset = 0x80008000
> rootfs mem offset = 0x80414000
> boot image size = 0x4a8800
read the data of BOOTIMG (size = 0x4a8800)
> from - 0x0000000002780800 (skip boot img hdr)
> to - 0x80007e00 (starts with kernel img hdr)
[LK_BOOT] KERNEL magic number : 0x58881688
[LK_BOOT] KERNEL name : KERNEL
[LK_BOOT] KERNEL size : 0x40b8c0
[LK_BOOT] ROOTFS magic number : 0x58881688
[LK_BOOT] ROOTFS name : ROOTFS
[LK_BOOT] ROOTFS size : 0x9aeb5
[PROFILE] ------- load boot.img takes 81 ms --------
lcd one 21151
[wwy] mt_disp_adjusting_hardware_addr fb_offset_logo = 3
SSSS:0x808610c4
SSSS:0x0
SSSS:0x0
SSSS:0x80
[PROFILE] ------- boot_time takes 1265 ms --------
[LK_ENV]get_env hibboot
[LK_ENV]get_env resume
resume = NULL
booting linux @ 0x80008000, ramdisk @ 0x84000000 (634549)
[LEDS]LK: leds_deinit: LEDS off
[LEDS]LK: red level is 0
[LEDS]LED PMIC#6:0
[LEDS]LK: green level is 0
[LEDS]LED PMIC#7:0
[LEDS]LK: blue level is 0
[LEDS]LED PMIC#6:0
DRAM Rank :1
DRAM Rank[0] Size = 0x40000000
cmdline: console=tty0 console=ttyMT0,921600n1 root=/dev/ram lcm=1-qp08_changcheng_tm097b3 fps=4727 lcm_type=0 pl_t=403 lk_t=1265 printk.disable_uart=1 boot_reason=4
lk boot time = 1265 ms
lk boot mode = 0
lk finished --> jump to linux kernel
Uncompressing Linux... done, booting the kernel.
Не грузит ядро?
 Заголовок сообщения: Re: Prestigio MultiPad 4 Ultra quad 8.0 3G pmp7280c 3g quad вечный перезагруз
СообщениеДобавлено: 17 июн 2017, 10:47
Попалась такая-же мать(нет изо, флешка не шьется). Пересадил новую флешь на неё. Симптомы те-же: заставка-перезагруз-заставка. Флеш образа принимает, форматится не хочет. Выходит битая флеш. Или я что-то упускаю?
 Заголовок сообщения: Re: Prestigio MultiPad 4 Ultra quad 8.0 3G pmp7280c 3g quad вечный перезагруз  [РЕШЕНО]
СообщениеДобавлено: 30 июн 2017, 20:13
Нашел убитую по питанию плату какого-то планшета. С неё пересадил Samsung 8Гб. Прошил - всё завелось. Всем спасибо. Закрываю
СообщениеДобавлено: 06 янв 2018, 21:39
Все верно память сдохла!
СообщениеДобавлено: 03 фев 2020, 11:46
Иногда виной и программное обеспечение.
---------- Добавлено спустя 1 час 15 минут 8 секунд: ----------
Выкладываю схему может кому надо
В этой теме нет новых непрочитанных сообщений. Нет изображения планшета Prestigio multipad pmp7100d3g quad
в форуме Prestigio
And81
22 сен 2018, 10:23
TheMonomah Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. prestigio multipad visconte quad pmp880td помогите опознать элемент
в форуме Prestigio
Djiin
17 мар 2023, 11:35
Artemka26 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Homtom HT20. Вечный перезагруз
в форуме Китайские телефоны
fevgin
11 фев 2018, 11:10
fevgin Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. prestigio multipad 2 ultra duo 3g
в форуме Prestigio
Knjazmyskin
07 янв 2018, 01:23
kalipso Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Prestigio PMP7280C не заряжается
в форуме Prestigio
gogoer
9572
26 сен 2019, 17:58
345shrus345 Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 0
