Текущее время: 28 июн 2024, 14:35
 Заголовок сообщения: Asus M4A88T-V EVO/USB3
СообщениеДобавлено: 11 фев 2018, 18:51
Hello colleagues, I have a problem with the title board.
When I put a Pc tester but code only reset the diodes every 2 seconds!
I changed the south bridge but the malfunction remained the same, do I have a suggestion where to go for a malfunction, in advance thanks!
I apologize that I have to write in englisch this way because from the Serbian to Russian translation it is very bad
 Заголовок сообщения: Re: Asus M4A88T-V EVO/USB3
СообщениеДобавлено: 11 фев 2018, 19:52
Why so soon change SB? Did you the BIOS rewrite at first or after?
СообщениеДобавлено: 11 фев 2018, 20:25
Regards, the indication says that something in the reset circle is invalid!
First of all, I changed the bios chip, but the same malfunction remained as I assumed.
СообщениеДобавлено: 11 фев 2018, 20:44
Have you been running a BIOS dump from a work card or from an official website? The website does not fit in this case.
Find the BIOS firmware from a workable card and flash it on the programmer.
---------- Добавлено спустя 8 минут 52 секунды: ----------
I have such a board, it also does not start. I dumped the BIOS from it, but I do not know how it works, I can drop it on the email.
СообщениеДобавлено: 11 фев 2018, 21:02
With these features, the south bridge is not at all. if the reset every 2 seconds -
1. Check the power of the north bridge,
2. check the resistance of the connector capacitors of the north and south bridge (alink signal) 16 pcs, 8 pcs near the south bridge and 8 pcs near the north bridge
3. solder the socket
4. change the north bridge
---------- Добавлено спустя 6 минут 44 секунды: ----------
это почему вы так решили? там нормальный биос в .rom формате, никак не .cap! можно шить программатором и все будет работать (только мак адрес придется прописать)
---------- Добавлено спустя 34 минуты 59 секунд: ----------
The capacitors look like this, which should be checked.
СообщениеДобавлено: 11 фев 2018, 22:16
Спорить не буду, попробую "с сайта" свою прошить. Но именно для этой модели на форуме дампа не было.
(моя плата включается, но не стартует, и не выключается с кнопки- мульт думаю менять)
СообщениеДобавлено: 20 фев 2018, 13:08
Hi, I did not have time, so I changed the Bridge Bridge yesterday and the board worked!
He had a gigabyte board with the same indications a long time ago, with it was a defective sout bridge, which was why he was the first to change it.
I thank everyone for help.
В этой теме нет новых непрочитанных сообщений. M4A88T-V EVO не запускается
в форуме Asus
hrust1990
26 май 2015, 07:36
hobik Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Куплю ASUS TUF Gaming X3 Radeon RX 5600 XT EVO (TUF 3-RX5600XT-O6G-EVO-Gaming)
в форуме Куплю | Buy
ArtKi
09 апр 2024, 02:44
ArtKi Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus m4a88t-m запускается но нет изображения
в форуме Asus
Benedikt
1436
02 ноя 2022, 10:37
Benedikt Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus M4A88TD-V EVO/USB3 прошивка TPU
в форуме Asus
dikabraz
14 мар 2020, 03:58
dikabraz Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. M4A88T-M автостарт
в форуме Asus
TaPaTya
18
4646
01 фев 2018, 17:46
TaPaTya Перейти к последнему сообщению
Сейчас этот форум просматривают: Gem, jetbalance и гости: 16
