Заголовок сообщения: ultrabook samsung (lotus 13 ba41-02040A) NO CHARGER BATTE
Добавлено: 21 фев 2018, 02:16
Зарегистрирован: 18 фев 2012, 22:42 Наличности на руках: 118.34 Сообщения: 389 Откуда: Brasil
ultrabook samsung model: np530uc3-ad5br not charge battery. The owner of the ultrabook samsung bought a new battery without being sure if the problem was in it.
The battery he bought has as specification: Model: CS-SNP530NB PART N: AA-PBYN4AB, AA-PLWN4AB RATING: 7.4VDC 6000mAH 44.4Wh Lithium-Polymer Battery Pack
in another battery announcement location the only difference is in: Lithium-ion
Question? Is there a problem?
The only scheme I've got is:
samsung-530u3c-lotus-13-ba41-01091a-ba41-01092a . Where to start finding the fault of not charging the battery?
I installed Windows on another hd and, after completing the installation, the battery charge marker was fully charged. When I removed the power cord from the power supply of the Ultrabook, the battery was uncharged and there was no charge signal
Now I am verifying that when I remove the motherboard from the enclosure, it even connects but when I put it in place and screw it into the case the motherboard does not turn on.
