Текущее время: 15 ноя 2026, 16:12
 Заголовок сообщения: HP DV6 (Quanta R12) hdmi no output
СообщениеДобавлено: 16 сен 2018, 00:10
Hi, have to repair a laptop HP DV6 Quanta R12 with problems in hdmi connector. VGA works ok. Lcd also works perfect.
Checking video signals in hdmi connector with oscilloscope shows nothing in C_TXC_HDMI+, C_TXC_HDMI-, C_TX0_HDMI+, etc. but it has pulses in HDMI_SCL_R and HDMI_SDA_R.
Problem is the same in linux or windows.
I suspect that U8 is not working properly.
Anyone knows something about this problem?
 Заголовок сообщения: Re: HP DV6 (Quanta R12) hdmi no output
СообщениеДобавлено: 16 сен 2018, 09:08
I am sorry, forgot to mention that L28, L30, L31 and L32 are missing, and they are very important to video signals reaching the output connector CN18, But seems that manufacturer omit them on purpose.
Seems that this signals are routed by another way, but cannot see it. this board is a discrete one, perhaps this component are for UMA only.
СообщениеДобавлено: 16 сен 2018, 13:03
Hi, check these resistors
СообщениеДобавлено: 16 сен 2018, 21:23
Thanks for this information, I did not notice this resistor in the schematic.
R391 is missing but R393 is mounted and I can read 4.7k from pins of R393.
R407 and R408 are both missing. (HDMI_CFG0)
R406 is also missing and R404 is mounted. (HDMI_CFG1)
Can you explain which resistor should be mounted?
СообщениеДобавлено: 17 сен 2018, 14:34
Marking U8?
СообщениеДобавлено: 18 сен 2018, 18:06
IOD писал(а):
Marking U8?
The HDMI TM /DVI TM LEVEL SHIFTER (U8) is coming, as soon as change it, I will let you know.
I think it is the damaged part in this board. (I hope)
Вложение:
ps8101_ps8101t_leaflet_20071227.7z
СообщениеДобавлено: 18 сен 2018, 19:30
See the RDT column for PS8101.
СообщениеДобавлено: 30 сен 2018, 17:51
Confirmed, U8 is damaged.
After changed it, HDMI works¡¡¡¡ :ya_hoo_oo: :ya_hoo_oo:
В этой теме нет новых непрочитанных сообщений. Pavillion DV7 (DAUT1AMB6D0 REV:D) No hdmi, vga or lcd screen output
andromedax
25 май 2017, 02:22
desska Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Asus (n551jk rev2.0) No lcd, no hdmi video output
andromedax
2501
27 ноя 2019, 18:57
andromedax Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Giga N2060WF20C 6G hdmi not output
deathdealer9982
12 окт 2023, 17:51
ilie321 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. box amplified subwoofer Newlink SP102 heating output
в форуме Ремонт бытовой техники | Repair of household appliances
eletmoraes
19 мар 2019, 18:28
mia Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. GTX 770 2gb MSI WORK pc remote and no video output.
PT-AH
07 дек 2021, 18:44
PT-AH Перейти к последнему сообщению
Сейчас этот форум просматривают: Caruzo и гости: 56
