Текущее время: 24 июн 2024, 16:54
andromedax
Заголовок сообщения: Re: HP DV6 (Quanta R12) hdmi no output ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 16 сен 2018, 10:08 |
Зарегистрирован: 01 май 2015, 00:34 Наличности на руках: 3.60 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 262 Откуда: Alicante, Spain
I am sorry, forgot to mention that L28, L30, L31 and L32 are missing, and they are very important to video signals reaching the output connector CN18, But seems that manufacturer omit them on purpose. Seems that this signals are routed by another way, but cannot see it. this board is a discrete one, perhaps this component are for UMA only.
andromedax
Заголовок сообщения: Re: HP DV6 (Quanta R12) hdmi no output ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 16 сен 2018, 22:23 |
IOD писал(а): Hi, check these resistors Thanks for this information, I did not notice this resistor in the schematic. R391 is missing but R393 is mounted and I can read 4.7k from pins of R393. R407 and R408 are both missing. (HDMI_CFG0) R406 is also missing and R404 is mounted. (HDMI_CFG1) Can you explain which resistor should be mounted?
andromedax
Заголовок сообщения: Re: HP DV6 (Quanta R12) hdmi no output ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 18 сен 2018, 19:06 |
IOD писал(а): Marking U8? The HDMI TM /DVI TM LEVEL SHIFTER (U8) is coming, as soon as change it, I will let you know. I think it is the damaged part in this board. (I hope) Вложение: ps8101_ps8101t_leaflet_20071227.7z
andromedax
Заголовок сообщения: Re: HP DV6 (Quanta R12) hdmi no output ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 30 сен 2018, 18:51 |
Цитата: I suspect that U8 is not working properly. Confirmed, U8 is damaged. After changed it, HDMI works¡¡¡¡ ![Восторг :ya_hoo_oo:](./images/smilies/bp.gif)
