Текущее время: 22 ноя 2024, 08:48
nasser_pczone1
Заголовок сообщения: Re: Acer 5742zg (la-5893p) Turn off after 5 min Добавлено: 10 фев 2019, 15:18 |
Сообщения: 40 Откуда: iran
vldmrdnpr писал(а): Remove pq65 and check without it. And also check 7p pu18 Ok will do but can you explain about your idea please thanks
nasser_pczone1
Заголовок сообщения: Re: Acer 5742zg (la-5893p) Turn off after 5 min Добавлено: 10 фев 2019, 17:21 |
servicewit писал(а): Try flashing the BIOS KBC using DOS, but don’t touch bios MAIN.
How can i do that ? I only know to flash by programmer device
servicewit
Заголовок сообщения: Re: Acer 5742zg (la-5893p) Turn off after 5 min Добавлено: 10 фев 2019, 17:34 |
Сообщения: 190 Откуда: simferopol
nasser_pczone1 писал(а): How can i do that ? I only know to flash by programmer device This topic has a similar problem, but only with a 5741ZG laptop, so be careful. http://vlab.su/viewtopic.php?t=8019
nasser_pczone1
Заголовок сообщения: Re: Acer 5742zg (la-5893p) Turn off after 5 min Добавлено: 10 фев 2019, 18:38 |
vldmrdnpr писал(а): Remove pq65 and check without it. And also check 7p pu18. I do that but same problem ..and not solved and pin 7 at pu18 before start 5v and when laptop on is 5v too
