Текущее время: 17 ноя 2026, 00:32
 Заголовок сообщения: Acer 5742zg (la-5893p) Turn off after 5 min
СообщениеДобавлено: 10 фев 2019, 09:02
Hi
This laptop com to my shop i try to clean fan and add past for cpu but not help laptop working fine but trun off after 5 min
The problem is turn off after 5 min and fan high spanning but cpu and gpu temp its normal about 50 centigrade
I mixedup for this problem and do this :
Change io
Change rt8206b
Flash bios and ec
Change cpu pwm controller
Chang fan controller
Change cpu
I check this laptop with os and without Hard disk but same problem
Change with battery and without .. change charge ic
What the friend think about this?
 Заголовок сообщения: Re: Acer (5742zg -la5893p) Turn off after 5 min
СообщениеДобавлено: 10 фев 2019, 09:18
Does it always take 5 minutes to turn off, or can it be quicker depending on how warm the board is? Is the fan always spinning at a high speed or does it gradually increase over time?
 Заголовок сообщения: Re: Acer 5742zg (la-5893p) Turn off after 5 min
СообщениеДобавлено: 10 фев 2019, 12:57
The fan in start system for some seconde slow and even some time stop and then take spanning high till trun off
And for turn off Approximately 5 minutes and sometimes a little earlier or later
СообщениеДобавлено: 10 фев 2019, 13:32
Remove pq65 and check without it.
And also check 7p pu18.
СообщениеДобавлено: 10 фев 2019, 14:18
Ok will do but can you explain about your idea please thanks
СообщениеДобавлено: 10 фев 2019, 16:12
Try flashing the BIOS KBC using DOS, but don’t touch bios MAIN.
СообщениеДобавлено: 10 фев 2019, 16:21
How can i do that ? I only know to flash by programmer device
СообщениеДобавлено: 10 фев 2019, 16:34
This topic has a similar problem, but only with a 5741ZG laptop, so be careful.
http://vlab.su/viewtopic.php?t=8019
СообщениеДобавлено: 10 фев 2019, 17:38
I do that but same problem ..and not solved and pin 7 at pu18 before start 5v and when laptop on is 5v too
СообщениеДобавлено: 10 фев 2019, 23:39
Anybody can help me?
СообщениеДобавлено: 12 фев 2019, 00:27
Problem resolved with program with ME version of bios
Thanks all
Admin please close the post
В этой теме нет новых непрочитанных сообщений. ASUS X555LD turn on with abnormal fan spin and turn off
kandyan
04 мар 2022, 08:55
kandyan Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Acpire 5253G ( LA-7092P) turn off after 3sec
R EZ A
29 ноя 2016, 10:45
R EZ A Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. svf15 (GD6) turn off after 2 about minutes
в форуме Sony
R EZ A
23 окт 2023, 12:40
В этой теме нет новых непрочитанных сообщений. Dell AlienWare M14X R2 (LA-8381P ) shutdown after 30 min
в форуме Dell
ayad
2945
24 сен 2017, 20:42
ayad Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. z510 (nm-a181) shutdown after 30 min
omidhadian
29 апр 2021, 09:53
vasek180295 Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 31
