Текущее время: 23 июн 2024, 07:47
simpleboy123
Заголовок сообщения: Re: Dell 15-3568 (vegas/turis skl/kbl 15341-1 91n85) нужен дамп ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 01 июл 2019, 11:44 |
![Аватара пользователя](./download/file.php?avatar=35336_1445073998.jpg) |
Зарегистрирован: 06 дек 2014, 08:36 Наличности на руках: 58.25 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 140 Откуда: USA
_SkyDreamer_ писал(а): The original problem is that the cooler does not work, with a dump from 3567 running. I tried to update the manufacturer’s website to the latest version of the original dump - it’s still a cooler. I ask for help who has a dump for 3568.
Hi Bro did you tried these clear Me Dumps download/file.php?id=106667download/file.php?id=106668if not tried it, and as you mentioned about Fan, the easiest way to check fan in dell laptops is press F12 and go to Diagnostic if it rotates it means Fan is OK and also communication between EC and Fan is good Good Luck
_________________ do good have good
_SkyDreamer_
Заголовок сообщения: Re: Dell 15-3568 (vegas/turis skl/kbl 15341-1 91n85) нужен дамп ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 01 июл 2019, 13:12 |
Зарегистрирован: 04 май 2015, 11:46 Наличности на руках: 3.07 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 63 Откуда: Sert
IOD писал(а): В родном дампе ME регион пробовали чистить? да не помогает. simpleboy123 писал(а): Hi Bro did you tried these clear Me Dumps download/file.php?id=106667 download/file.php?id=106668 if not tried it, and as you mentioned about Fan, the easiest way to check fan in dell laptops is press F12 and go to Diagnostic if it rotates it means Fan is OK and also communication between EC and Fan is good Good Luck Hi Bro, yes i try flash this dumps, my dump is first (becouse is DIS), Fan work correctly, but AMD Ati graphisc in this dump - AMD HD 8500 Series and any drivers not correctly installed, in my dump work correctly AMD R5 M420.
_SkyDreamer_
Заголовок сообщения: Re: Dell 15-3568 (vegas/turis skl/kbl 15341-1 91n85) нужен дамп ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 01 июл 2019, 17:59 |
IOD писал(а): Выложите свой дамп, попробую Bios Region в нем заменить от 3568. Кстати это Inspiron или Vostro, у Dell и в той, и в той линейке есть модель 15-3568. спасибо за наводку, да действительно есть два одинаковых по нумерации модели в разных сериях с разной начинкой. У меня Vostro
_SkyDreamer_
Заголовок сообщения: Re: Dell 15-3568 (vegas/turis skl/kbl 15341-1 91n85) нужен дамп ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 02 июл 2019, 10:57 |
IOD писал(а): Пробуйте (Boot Guard Profile 5): Ситуация не изменилась. 1) как и на всех биосах - два раза перезагружается без картинки с максимальными оборотами кулера, без изображения 2) далее предложение выйти из Manufacturing Mode 3) как только из него по Alt+F выходим кулер замолкает 4) предложение выбрать платформу - SKL или KBL, выбираю SKL (хотя пробовал и KBL разницы не увидел ни в чем) 5) Предложение ввести Service Tag, ввожу что снизу на крышке ноутбука 6LB4CL2 6) Загрузка ОС, кулер молчит, тест аиды, кулер молчит, выключаю ноутбук, в последние секунды отрабатывания завршения работы, кулер слегка крутанется (как будто тест) На дампе от 15-3567 при включении кулер тоже тестово стартует чуть чуть и работает далее при нагреве системы охлаждения, на дампах от 15-3568 такого события нет и нет работы кулера.
_SkyDreamer_
Заголовок сообщения: Re: Dell 15-3568 (vegas/turis skl/kbl 15341-1 91n85) нужен дамп ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 02 июл 2019, 21:29 |
IOD писал(а): А вы какой BIOS выложили? Оригинальный, или тот, с которым кулер работает? Это оригинальный дамп с проблемного ноутбука Dell Vostro 15-3568 _SkyDreamer_ писал(а): GD25Q128B@WSON8_20190628_161846.zip [5.39 МБ] IOD писал(а): Можно попробовать в Bios 15-3567 внедрить Bios Region от 15-3568. С тем Bios, что я собрал, драйвер видеокарты работает? Да с видеокартами все ок, определяются как надо.
IOD
Заголовок сообщения: Re: Dell 15-3568 (vegas/turis skl/kbl 15341-1 91n85) нужен дамп ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 02 июл 2019, 21:55 |
![Аватара пользователя](./download/file.php?avatar=40843_1607102448.jpg) |
Зарегистрирован: 28 апр 2015, 17:33 Наличности на руках: 9,488.76 ![](./styles/AeroBlack/theme/images/money.png)
_SkyDreamer_ писал(а): видеомодуль не меняется со сменой региона Т.е., вы берете Bios 15-3568, разбираете его FIT, потом тем же FIT разбираете Bios 15-3567, меняете в нем Bios Region c папки Decomp Biosа 15-3568?
_SkyDreamer_
Заголовок сообщения: Re: Dell 15-3568 (vegas/turis skl/kbl 15341-1 91n85) нужен дамп ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 03 июл 2019, 16:56 |
IOD писал(а): Т.е., вы берете Bios 15-3568, разбираете его FIT, потом тем же FIT разбираете Bios 15-3567, меняете в нем Bios Region c папки Decomp Biosа 15-3568?
Да именно так, с таким дампом видеокарта ати неправильная, кулер работает
