Текущее время: 22 сен 2024, 04:45
vik56
Заголовок сообщения: Re: Ищу дамп на камеру Dahua DH-IPC-C22P Добавлено: 30 сен 2019, 11:13 |
Зарегистрирован: 16 май 2011, 13:02 Наличности на руках: 10.11
Сообщения: 40 Откуда: Россия 68
fobos писал(а): Спасибо, но дамп не подошел, загрузчик стартует и виснет, то ли прошивка не та, то ли все таки это не DH-IPC-C22P
System startup
U-Boot 2010.06-svn5625 (Nov 06 2018 - 17:25:32) DRAM: 64 MiB gBootLogPtr:80b80008. Check Flash Memory Controller v100 ... Found SPI Nor(cs 0) ID: 0xc8 0x40 0x18 Block:64KB Chip:16MB Name:"GD25Q128" SPI Nor total size: 16MB hifmc100_get_erasesize:10000.
*** Warning - bad CRC, using default environment
partition file version 2 rootfstype squashfs root /dev/mtdblock5
fail to parse HWID fail to parse bootargsParametersV2.text info fail to init bootargsParametersV2 In: serial Out: serial Err: serial
TEXT_BASE:81000000
sd update init:HWID is missing!
Hisilicon ETH net controler
MAC: 00-13-34-56-78-9A Up/Down PHY not link. Try again use backup_serverip Hisilicon ETH net controler
miiphy_register: non unique device name '0:31' miiphy_register: non unique device name '0:2' MAC: 00-13-34-56-78-9A Up/Down PHY not link. Failed to get info.txt Fail to get info file! Init error! Hisilicon ETH net controler
miiphy_register: non unique device name '0:31' miiphy_register: non unique device name '0:2' MAC: 00-13-34-56-78-9A Up/Down PHY not link. Support backupVer:255 state:ff,err_count:07 fail to parse HWID fail to parse bootargsParameters.text info get bootargs info failed
cmdLine mem=47M console=ttyS0,115200 root=/dev/mtdblock5 rootfstype=squashfs
smagic=0x424f4f54
## Booting kernel from Legacy Image at 82000000 ... Image Name: Linux-3.4.35 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 1163600 Bytes = 1.1 MiB Load Address: 80008000 Entry Point: 80008000 Loading Kernel Image ... OK OK partition file version 2 rootfstype squashfs root /dev/mtdblock5 fail to parse HWID fail to parse bootargsParameters.text info get bootargs info failed
Starting kernel ... Uncompressing Linux... done, booting the kernel.
Смущают строки в логе MAC: 00-13-34-56-78-9A Up/Down PHY not link. Try again use backup_serverip Hisilicon ETH net controler У этих камер нет ethernet, только wifi.
vik56
Заголовок сообщения: Re: Ищу дамп на камеру Dahua DH-IPC-C22P Добавлено: 30 сен 2019, 12:17 |
Не могу остановить загрузку, в ростелекомовском загрузчике есть запрос на остановку, а здесь не пойму какую клавишу нажимать.
System startup
U-Boot 2010.06 (Oct 15 2018 - 13:22:22)
Check Flash Memory Controller v100 ... Found SPI Nor(cs 0) ID: 0xc8 0x40 0x18 Block:64KB Chip:16MB Name:"GD25Q128" SPI Nor total size: 16MB MMC: EMMC/MMC/SD controller initialization.
MMC/SD Card: MID: 0x6f Read Block: 512 Bytes Write Block: 512 Bytes Chip Size: 15075M Bytes (High Capacity) Name: "SMI " Chip Type: SD Version: 2.0 Speed: 50000000Hz Bus Width: 4bit Boot Addr: 0 Bytes
In: serial Out: serial Err: serial Hit any key to stop autoboot: 1 0 Set gpio: 1->0 Set gpio: 5->0 Set gpio: 57->1 Set gpio: 60->1 Set gpio: 7->1 16384 KiB hi_fmc at 0:0 is now current device Unable to register device mmc 0:1
## Booting kernel from Legacy Image at 80007fc0 ... Image Name: Linux-3.4.35 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 3084512 Bytes = 2.9 MiB Load Address: 80008000 Entry Point: 80008000 XIP Kernel Image ... OK OK
Starting kernel ...
vik56
Заголовок сообщения: Re: Ищу дамп на камеру Dahua DH-IPC-C22P Добавлено: 30 сен 2019, 12:35 |
Помогло, Спасибо.
printenv bootargs=mem=47M console=ttyS0,115200 root=/dev/mtdblock7 rootfstype=squashfs bootcmd=kload 0x82000000; bootm 0x82000000 bootdelay=1 baudrate=115200 ethaddr=00:13:34:56:78:9A ipaddr=192.168.1.108 serverip=192.168.1.1 gatewayip=192.168.1.1 netmask=255.255.255.0 bootfile="uImage" wifiaddr=00:12:34:56:78:91 ID=000000000000000000 da=tftp 0x82000000 dhboot.bin.img; flwrite;tftp dhboot-min.bin.img;flwrite dr=tftp 0x82000000 romfs-x.squashfs.img; flwrite dk=tftp 0x82000000 kernel.img; flwrite du=tftp 0x82000000 user-x.squashfs.img; flwrite dw=tftp 0x82000000 web-x.squashfs.img; flwrite dp=tftp 0x82000000 partition-x.cramfs.img;flwrite dc=tftp 0x82000000 custom-x.squashfs.img; flwrite up=tftp 0x82000000 update.img; flwrite tk=tftp 0x82000000 uImage; bootm dh_keyboard=1 appauto=1 sysbackup=1 loglevel=4 pd=tftp 0x82000000 pd-x.squashfs.img; flwrite stdin=serial stdout=serial stderr=serial verify=n ver=U-Boot 2010.06-svn5625 (Nov 06 2018 - 17:25:32)
Environment size: 958/262140 bytes >
vik56
Заголовок сообщения: Re: Ищу дамп на камеру Dahua DH-IPC-C22P Добавлено: 30 сен 2019, 16:51 |
setenv hwid 01:02:0F:60:1D:00:01:10:01:01:04:21C:00:02:00:00:04:00:00:00:40 saveenv не сработало, сработало: hwid 01:02:0F:60:1D:00:01:10:01:01:04:21C:00:02:00:00:04:00:00:00:40
hwid 01:02:0F:60:1D:00:01:10:01:01:04:21C:00:02:00:00:04:00:00:00:40 >$0D;
Erasing SPI flash...
Writing to SPI flash...
done Set HWID success! Now HWID: 01:02:0F:60:1D:00:01:10:01:01:04:21C:00:02:00:00:04:00:00:00:40 > >reset >$0D; reset resetting ...
System startup
System startup
can not search bootargs settings fail to parse bootargsParametersV2.text info fail to init bootargsParametersV2 In: serial Out: serial Err: serial
TEXT_BASE:81000000
MMC: Hisilicon ETH net controler
miiphy_register: non unique device name '0:31' miiphy_register: non unique device name '0:2' MAC: 00-13-34-56-78-9A Up/Down PHY not link. Support backupVer:255 state:ff,err_count:03 can not search bootargs settings fail to parse bootargsParameters.text info get bootargs info failed
hmagic=0x434f4f54 Before write boot backup version page, it should be erased!!!
## Booting kernel from Legacy Image at 82000000 ... Image Name: Linux-3.4.35 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 1163600 Bytes = 1.1 MiB Load Address: 80008000 Entry Point: 80008000 Loading Kernel Image ... OK OK partition file version 2 rootfstype squashfs root /dev/mtdblock5 can not search bootargs settings fail to parse bootargsParameters.text info get bootargs info failed
Зависает так же, но теперь горит красный светодиод.
vik56
Заголовок сообщения: Re: Ищу дамп на камеру Dahua DH-IPC-C22P Добавлено: 30 сен 2019, 17:20 |
Каким образом? ethernet отсутствует, а в режиме uboot wifi не поднимается. Да, верификация проходит нормально. Включил вывод загрузки в консоль, ругается на ethernet вроде бы.
System startup
TEXT_BASE:81000000
miiphy_register: non unique device name '0:31' miiphy_register: non unique device name '0:2' MAC: 00-13-34-56-78-9A Up/Down PHY not link. Support backupVer:255 state:ff,err_count:06 can not search bootargs settings fail to parse bootargsParameters.text info get bootargs info failed
smagic=0x44444351
Booting Linux on physical CPU 0 CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177 CPU: VIVT data cache, VIVT instruction cache Machine: hi3518ev200 gLogRamRes: start=0x82eb7000;size=0x47000 mem_relimitAddr:0x82efe000 console [ttyS0] enabled
ÿ mount: mounting tmpfs on /tmp failed: No such file or directory
mknod: /dev/console: File exists mknod: /dev/ttyS0: File exists mknod: /dev/ttyS1: File exists
mknod: /dev/null: File exists
chmod: /dev/fd: Operation not permitted
keyboard = 0
mount: mounting devpts on /dev/pts failed: Device or resource busy mkdir: can't create directory '/mnt/backup/Config': Read-only file system mkdir: can't create directory '/mnt/backup/debug': Read-only file system
PRODUCT = 01
Module himedia: init ok
hi3518e_base: module license 'Proprietary' taints kernel. hi3518e_base: Unknown symbol hil_mmb_free (err 0) hi3518e_base: Unknown symbol hil_mmb_getby_phys (err 0) hi3518e_base: Unknown symbol hil_mmb_alloc (err 0) insmod: can't insert 'hi3518e_base.ko': unknown symbol in module, or unknown parameter
hi3518e_sys: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_sys: Unknown symbol CMPI_StopModules (err 0) hi3518e_sys: Unknown symbol CMPI_MmzMallocNocache (err 0) hi3518e_sys: Unknown symbol CMPI_UserCopy (err 0) hi3518e_sys: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_sys: Unknown symbol CMPI_CreateProc (err 0) hi3518e_sys: Unknown symbol CMPI_GetModuleName (err 0) hi3518e_sys: Unknown symbol CMPI_ExitModules (err 0) hi3518e_sys: Unknown symbol CMPI_InitModules (err 0) hi3518e_sys: Unknown symbol CMPI_QueryModules (err 0) hi3518e_sys: Unknown symbol HI_LOG (err 0) hi3518e_sys: Unknown symbol CMPI_MmzFree (err 0) hi3518e_sys: Unknown symbol CMPI_RegisterModule (err 0) hi3518e_sys: Unknown symbol CMPI_UnRegisterDevice (err 0) hi3518e_sys: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_sys.ko': unknown symbol in module, or unknown parameter
hi3518e_tde: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_tde: Unknown symbol CMPI_MmzMalloc (err 0) hi3518e_tde: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_tde: Unknown symbol CMPI_CreateProc (err 0) hi3518e_tde: Unknown symbol HI_LOG (err 0) hi3518e_tde: Unknown symbol CMPI_MmzFree (err 0) hi3518e_tde: Unknown symbol hil_mmb_flush_dcache_byaddr (err 0) hi3518e_tde: Unknown symbol CMPI_RegisterModule (err 0) insmod: can't insert 'hi3518e_tde.ko': unknown symbol in module, or unknown parameter
hi3518e_region: Unknown symbol TdeOsiCancelJob (err 0) hi3518e_region: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_region: Unknown symbol CMPI_MmzMallocNocache (err 0) hi3518e_region: Unknown symbol CMPI_UserCopy (err 0) hi3518e_region: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_region: Unknown symbol TdeOsiEndJob (err 0) hi3518e_region: Unknown symbol CMPI_CreateProc (err 0) hi3518e_region: Unknown symbol TdeOsiBeginJob (err 0) hi3518e_region: Unknown symbol TdeOsiWaitForDone (err 0) hi3518e_region: Unknown symbol HI_LOG (err 0) hi3518e_region: Unknown symbol CMPI_MmzFree (err 0) hi3518e_region: Unknown symbol CMPI_GetModuleFuncById (err 0) hi3518e_region: Unknown symbol TdeOsiQuickCopy (err 0) hi3518e_region: Unknown symbol CMPI_RegisterModule (err 0) hi3518e_region: Unknown symbol CMPI_UnRegisterDevice (err 0) hi3518e_region: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_region.ko': unknown symbol in module, or unknown parameter
hi3518e_vgs: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_vgs: Unknown symbol CMPI_MmzMallocNocache (err 0) hi3518e_vgs: Unknown symbol VB_UserAdd (err 0) hi3518e_vgs: Unknown symbol CMPI_UserCopy (err 0) hi3518e_vgs: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_vgs: Unknown symbol VB_UserSub (err 0) hi3518e_vgs: Unknown symbol CMPI_CreateProc (err 0) hi3518e_vgs: Unknown symbol CMPI_GetModuleName (err 0) hi3518e_vgs: Unknown symbol VB_GetBlkBySize (err 0) hi3518e_vgs: Unknown symbol VB_Phy2Handle (err 0) hi3518e_vgs: Unknown symbol HI_LOG (err 0) hi3518e_vgs: Unknown symbol CMPI_MmzFree (err 0) hi3518e_vgs: Unknown symbol VB_Handle2Kern (err 0) hi3518e_vgs: Unknown symbol VB_Handle2PoolId (err 0) hi3518e_vgs: Unknown symbol CMPI_GetModuleFuncById (err 0) hi3518e_vgs: Unknown symbol CMPI_RegisterModule (err 0) hi3518e_vgs: Unknown symbol CMPI_UnRegisterDevice (err 0) hi3518e_vgs: Unknown symbol VB_Handle2Phys (err 0) hi3518e_vgs: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_vgs.ko': unknown symbol in module, or unknown parameter SEN_ID = 1D
umount: can't umount /mnt/fpn: Invalid argument updatePos = 0
hi3518e_isp: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_isp: Unknown symbol CMPI_MmzMallocNocache (err 0) hi3518e_isp: Unknown symbol CMPI_MmzMalloc (err 0) hi3518e_isp: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_isp: Unknown symbol CMPI_CreateProc (err 0) hi3518e_isp: Unknown symbol VB_IsSupplementSupport (err 0) hi3518e_isp: Unknown symbol CMPI_MmzMallocCached (err 0) hi3518e_isp: Unknown symbol HI_LOG (err 0) hi3518e_isp: Unknown symbol CMPI_MmzFree (err 0) hi3518e_isp: Unknown symbol CMPI_GetModuleFuncById (err 0) hi3518e_isp: Unknown symbol CMPI_RegisterModule (err 0) hi3518e_isp: Unknown symbol CMPI_UnRegisterDevice (err 0) hi3518e_isp: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_isp.ko': unknown symbol in module, or unknown parameter
hi3518e_viu: Unknown symbol VB_Handle2Supplement (err 0) hi3518e_viu: Unknown symbol VB_InquirePoolUserCnt (err 0) hi3518e_viu: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_viu: Unknown symbol VB_UserAdd (err 0) hi3518e_viu: Unknown symbol CMPI_UserCopy (err 0) hi3518e_viu: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_viu: Unknown symbol VB_UserSub (err 0) hi3518e_viu: Unknown symbol CMPI_CreateProc (err 0) hi3518e_viu: Unknown symbol VB_GetBlkByPoolId (err 0) hi3518e_viu: Unknown symbol VB_CreatePool (err 0) hi3518e_viu: Unknown symbol VB_GetBlkBySize (err 0) hi3518e_viu: Unknown symbol VB_IsSupplementSupport (err 0) hi3518e_viu: Unknown symbol ISP_GetDCFInfo (err 0) hi3518e_viu: Unknown symbol VB_IsBlkValid (err 0) hi3518e_viu: Unknown symbol HI_LOG (err 0) hi3518e_viu: Unknown symbol VB_Handle2Kern (err 0) hi3518e_viu: Unknown symbol VB_Handle2PoolId (err 0) hi3518e_viu: Unknown symbol CMPI_GetModuleFuncById (err 0) hi3518e_viu: Unknown symbol CMPI_RegisterModule (err 0) hi3518e_viu: Unknown symbol vi_vpss_online (err 0) hi3518e_viu: Unknown symbol CMPI_UnRegisterDevice (err 0) hi3518e_viu: Unknown symbol VB_DestroyPool (err 0) hi3518e_viu: Unknown symbol VB_Handle2Phys (err 0) hi3518e_viu: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_viu.ko': unknown symbol in module, or unknown parameter
hi3518e_vpss: Unknown symbol VB_Handle2Supplement (err 0) hi3518e_vpss: Unknown symbol coefficient6_3M_a15 (err 0) hi3518e_vpss: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_vpss: Unknown symbol CMPI_MmzMallocNocache (err 0) hi3518e_vpss: Unknown symbol g_power_save_enable (err 0) hi3518e_vpss: Unknown symbol VB_UserAdd (err 0) hi3518e_vpss: Unknown symbol coefficient4_2M_a05 (err 0) hi3518e_vpss: Unknown symbol CMPI_MmzMalloc (err 0) hi3518e_vpss: Unknown symbol CMPI_UserCopy (err 0) hi3518e_vpss: Unknown symbol coefficient4_5M_a15 (err 0) hi3518e_vpss: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_vpss: Unknown symbol VB_UserSub (err 0) hi3518e_vpss: Unknown symbol CMPI_CreateProc (err 0) hi3518e_vpss: Unknown symbol coefficient8_lanczos2_8tap (err 0) hi3518e_vpss: Unknown symbol coefficient6_cubic (err 0) hi3518e_vpss: Unknown symbol coefficient8_2M_a05 (err 0) hi3518e_vpss: Unknown symbol coefficient8_3M_a19 (err 0) hi3518e_vpss: Unknown symbol coefficient6_4M_a20 (err 0) hi3518e_vpss: Unknown symbol VB_GetBlkBySize (err 0) hi3518e_vpss: Unknown symbol coefficient8_1_5M_a05 (err 0) hi3518e_vpss: Unknown symbol VB_IsSupplementSupport (err 0) hi3518e_vpss: Unknown symbol VIU_DRV_IsFrameFlashed (err 0) hi3518e_vpss: Unknown symbol coefficient8_cubic (err 0) hi3518e_vpss: Unknown symbol coefficient4_1_5M_a05 (err 0) hi3518e_vpss: Unknown symbol ISP_GetDCFInfo (err 0) hi3518e_vpss: Unknown symbol coefficient6_2M_a05 (err 0) hi3518e_vpss: Unknown symbol VB_IsBlkValid (err 0) hi3518e_vpss: Unknown symbol g_proc_enable (err 0) hi3518e_vpss: Unknown symbol HI_LOG (err 0) hi3518e_vpss: Unknown symbol CMPI_MmzFree (err 0) hi3518e_vpss: Unknown symbol VB_Handle2Kern (err 0) hi3518e_vpss: Unknown symbol VB_Handle2PoolId (err 0) hi3518e_vpss: Unknown symbol coefficient6_1_5M_a05 (err 0) hi3518e_vpss: Unknown symbol CMPI_GetModuleFuncById (err 0) hi3518e_vpss: Unknown symbol coefficient4_cubic (err 0) hi3518e_vpss: Unknown symbol CMPI_RegisterModule (err 0) hi3518e_vpss: Unknown symbol vi_vpss_online (err 0) hi3518e_vpss: Unknown symbol CMPI_UnRegisterDevice (err 0) hi3518e_vpss: Unknown symbol coefficient6_5M_a25 (err 0) hi3518e_vpss: Unknown symbol VB_Handle2Phys (err 0) hi3518e_vpss: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_vpss.ko': unknown symbol in module, or unknown parameter
hi3518e_rc: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_rc: Unknown symbol g_proc_all (err 0) hi3518e_rc: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_rc: Unknown symbol CMPI_CreateProc (err 0) hi3518e_rc: Unknown symbol HI_LOG (err 0) hi3518e_rc: Unknown symbol CMPI_RegisterModule (err 0) hi3518e_rc: Unknown symbol CMPI_UnRegisterDevice (err 0) hi3518e_rc: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_rc.ko': unknown symbol in module, or unknown parameter
hi3518e_venc: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_venc: Unknown symbol VB_UserAdd (err 0) hi3518e_venc: Unknown symbol CMPI_UserCopy (err 0) hi3518e_venc: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_venc: Unknown symbol VB_UserSub (err 0) hi3518e_venc: Unknown symbol CMPI_CreateProc (err 0) hi3518e_venc: Unknown symbol VB_GetBlkBySize (err 0) hi3518e_venc: Unknown symbol VB_IsSupplementSupport (err 0) hi3518e_venc: Unknown symbol VB_IsBlkValid (err 0) hi3518e_venc: Unknown symbol g_proc_enable (err 0) hi3518e_venc: Unknown symbol HI_LOG (err 0) hi3518e_venc: Unknown symbol VB_Handle2PoolId (err 0) hi3518e_venc: Unknown symbol CMPI_GetModuleFuncById (err 0) hi3518e_venc: Unknown symbol CMPI_RegisterModule (err 0) hi3518e_venc: Unknown symbol CMPI_UnRegisterDevice (err 0) hi3518e_venc: Unknown symbol VB_Handle2Phys (err 0) hi3518e_venc: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_venc.ko': unknown symbol in module, or unknown parameter
hi3518e_chnl: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_chnl: Unknown symbol g_proc_all (err 0) hi3518e_chnl: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_chnl: Unknown symbol CMPI_CreateProc (err 0) hi3518e_chnl: Unknown symbol HI_LOG (err 0) hi3518e_chnl: Unknown symbol CMPI_RegisterModule (err 0) hi3518e_chnl: Unknown symbol CMPI_UnRegisterDevice (err 0) hi3518e_chnl: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_chnl.ko': unknown symbol in module, or unknown parameter
hi3518e_h264e: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_h264e: Unknown symbol CMPI_MmzMallocNocache (err 0) hi3518e_h264e: Unknown symbol VB_UserAdd (err 0) hi3518e_h264e: Unknown symbol CMPI_MmzMalloc (err 0) hi3518e_h264e: Unknown symbol hil_mmb_invalid_cache_byaddr (err 0) hi3518e_h264e: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_h264e: Unknown symbol VB_UserSub (err 0) hi3518e_h264e: Unknown symbol CMPI_CreateProc (err 0) hi3518e_h264e: Unknown symbol VB_GetBlkByPoolId (err 0) hi3518e_h264e: Unknown symbol VB_CreatePool (err 0) hi3518e_h264e: Unknown symbol CMPI_MmzMallocCached (err 0) hi3518e_h264e: Unknown symbol HI_LOG (err 0) hi3518e_h264e: Unknown symbol CMPI_MmzFree (err 0) hi3518e_h264e: Unknown symbol hil_mmb_flush_dcache_byaddr (err 0) hi3518e_h264e: Unknown symbol VB_Handle2BlkSize (err 0) hi3518e_h264e: Unknown symbol VB_Handle2PoolId (err 0) hi3518e_h264e: Unknown symbol CMPI_GetModuleFuncById (err 0) hi3518e_h264e: Unknown symbol CMPI_RegisterModule (err 0) hi3518e_h264e: Unknown symbol CMPI_UnRegisterDevice (err 0) hi3518e_h264e: Unknown symbol VencBufferCache (err 0) hi3518e_h264e: Unknown symbol VB_DestroyPool (err 0) hi3518e_h264e: Unknown symbol VB_Handle2Phys (err 0) hi3518e_h264e: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_h264e.ko': unknown symbol in module, or unknown parameter
hi3518e_jpege: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_jpege: Unknown symbol CMPI_MmzMallocNocache (err 0) hi3518e_jpege: Unknown symbol hil_mmb_invalid_cache_byaddr (err 0) hi3518e_jpege: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_jpege: Unknown symbol CMPI_CreateProc (err 0) hi3518e_jpege: Unknown symbol VB_IsSupplementSupport (err 0) hi3518e_jpege: Unknown symbol HI_LOG (err 0) hi3518e_jpege: Unknown symbol CMPI_MmzFree (err 0) hi3518e_jpege: Unknown symbol CMPI_GetModuleFuncById (err 0) hi3518e_jpege: Unknown symbol CMPI_RegisterModule (err 0) hi3518e_jpege: Unknown symbol CMPI_UnRegisterDevice (err 0) hi3518e_jpege: Unknown symbol VencBufferCache (err 0) hi3518e_jpege: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_jpege.ko': unknown symbol in module, or unknown parameter insmod: can't open 'hi3518e_vda.ko': No such file or directory
[OSA-DRV] OSA Build on Dec 5 2018 at 04:00:09. [OSA-DRV] SVN NUM: 5514.
[OSA-DRV] Monitor Task pid=693 tid=693
[LOG-DRV] LOG Build on Dec 5 2018 at 03:59:23. [LOG-DRV] SVN NUM: 9984.
[LOG-DRV] ramStart:0x82eb7000;ramSize:0x47000;select:1 [OSA-DRV] Char device create OK ! [LOG-DRV] coreId = 0, logLevel = 2 [LOG-DRV] coreId = 1, logLevel = 2 [LOG-DRV] coreId = 2, logLevel = 2 [LOG-DRV] coreId = 3, logLevel = 2 [LOG-DRV] coreId = 4, logLevel = 2 [LOG-DRV] coreId = 5, logLevel = 2
[0;32;32m00:00:06|[DH_Binder] Binder.ko Build on Nov 6 2018 at 17:20:03. [m[0;32;32m00:00:06|[DH_Binder] SVN NUM: 3518.
[m[0;32;32m00:00:06|[DH_Binder] NameServer Initial OK ! [m[0;32;32m00:00:06|[DH_Binder] Create binder memory pool(size:16384) OK! [m[0;32;32m00:00:06|[DH_Binder] Create binder memory pool(size:225280) OK! [m[0;32;32m00:00:06|[DH_Binder] Binder Initial OK ! [m[0;32;32m00:00:06|[OSA-DRV] Char device create OK ! [m[0;32;32m00:00:06|[DH_Binder] SR driver initial OK ! [m[0;32;32m00:00:06|[OSA-DRV] Char device create OK ! [m[0;32;32m00:00:06|[DH_Binder] NS driver initial OK ! [m[0;32;32m00:00:06|[OSA-DRV] Char device create OK ! [m[0;32;32m00:00:06|[DH_Binder] Binder driver initial OK ! [m [0;32;32m00:00:06|[prc] PRC Driver Build on Nov 6 2018 at 17:20:56. [m[0;32;32m00:00:06|[prc] SVN NUM: 12231.
[m[0;32;32m00:00:06|[prc] Start to init module! [m[0;32;32m00:00:06|[prc] pinmux init ok [m[0;32;32m00:00:06|[prc] gpio soc init ok [m[0;32;32m00:00:06|[prc] spi init ok [m[0;32;32m00:00:06|[prc] IIC init ok [m[0;36m00:00:06|[prc] PRC_wdtInit OK [m[0;36m00:00:06|[prc] PRC_rtcInit OK! [m[0;32;32m00:00:06|[prc] Success to init module! [m [0;32;32m00:00:06|[pdc]
PDC Build on Nov 6 2018 at 17:28:34. [m[0;32;32m00:00:06|[pdc] SVN NUM: 8253.
[m[0;36m00:00:06|[pdc] BASE_LINE: 240 [m[0;32;32m00:00:06|[pdc] OSA_kProcCreate OK [m[0;32;32m00:00:06|[OSA-DRV] Char device create OK ! [m[0;36m00:00:06|[pdc] PDC_PartionInit ok!! [m[0;32;32m00:00:06|[pdc] HWID : 01:02:0F:60:1D:00:01:10:01:01:04:21C:00:02:00:00:04:00:00:00:40 [m[0;32;31m00:00:06|[pdc] ERROR (HWID_parsePdtType|5247): nPrdtLineId f wrong ! [m[0;32;32m00:00:06|[OSA-DRV] Char device create OK ! [m[0;32;31m00:00:06|[pdc] ERROR (PDC_vinCfgPlatInit|122): Unknown Product Type [m[0;36m00:00:06|[pdc] binderFlag: 0x0, funcap: 0x0,0x0,0x0,0x0 [m[0;32;34m00:00:06|[pdc] videoOut Channel is 0 [m[0;32;31m00:00:06|[pdc] ERROR (PDC_cfgFindInitOps|331): Not probed, please check it ! [m[0;32;31m00:00:06|[pdc] ERROR (PDC_cfgInit|364): Device not found ! [m[0;32;31m00:00:06|[pdc] ERROR (PDC_drvInit|194): PDC_cfgInit() [m[1;37m00:00:06|[pdc] Dev has No Key Cfg! [m[0;32;32m00:00:06|[OSA-DRV] Char device create OK ! [m[0;32;32m00:00:06|[OSA-DRV] Char device create OK ! [m[0;32;32m00:00:06|[pdc] SramFile init ok ! [m[0;32;32m00:00:06|[pdc] Both of Chief and Backup File CRC check OK! [m[0;35m00:00:06|[OSA-DRV] recordTsk Task pid=721 tid=721 [m[0;32;32m00:00:06|[OSA-DRV] Char device create OK ! [m[0;32;32m00:00:06|[OSA-DRV] Char device create OK ! [m[0;32;31m00:00:06|[pdc] ERROR (PDC_drvInit|209): PDC Driver Initial Failed ! [m<1>mipi_init init phy power successful! load hi_mipi driver successful! *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x200f0040: 0x00000000 --> 0x00000002 [END] *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x200f0044: 0x00000000 --> 0x00000002 [END] *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x200f0080: 0x00000000 --> 0x00000001 [END] *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x200f0088: 0x00000000 --> 0x00000001 [END] *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x200f008c: 0x00000000 --> 0x00000002 [END] *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x200f0090: 0x00000000 --> 0x00000002 [END] *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x200f0094: 0x00000000 --> 0x00000001 [END] *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x2003002c: 0x000C4003 --> 0x000B4001 [END]
audioin = 1
<4>acodec: Unknown symbol CMPI_RemoveProc (err 0) <4>acodec: Unknown symbol CMPI_CreateProc (err 0) insmod: can't insert 'acodec.ko': unknown symbol in module, or unknown parameter
<4>hi3518e_aio: Unknown symbol CMPI_UnRegisterModule (err 0) <4>hi3518e_aio: Unknown symbol HI_LOG (err 0) <4>hi3518e_aio: Unknown symbol CMPI_GetModuleFuncById (err 0) <4>hi3518e_aio: Unknown symbol CMPI_RegisterModule (err 0) insmod: can't insert 'hi3518e_aio.ko': unknown symbol in module, or unknown parameter <4>hi3518e_ai: Unknown symbol VB_InquirePoolUserCnt (err 0) <4>hi3518e_ai: Unknown symbol CMPI_UnRegisterModule (err 0) <4>hi3518e_ai: Unknown symbol CMPI_MmzMallocNocache (err 0) <4>hi3518e_ai: Unknown symbol VB_UserAdd (err 0) <4>hi3518e_ai: Unknown symbol CMPI_UserCopy (err 0) <4>hi3518e_ai: Unknown symbol CMPI_RemoveProc (err 0) <4>hi3518e_ai: Unknown symbol VB_UserSub (err 0) <4>hi3518e_ai: Unknown symbol CMPI_CreateProc (err 0) <4>hi3518e_ai: Unknown symbol VB_GetBlkByPoolId (err 0) <4>hi3518e_ai: Unknown symbol VB_CreatePool (err 0) <4>hi3518e_ai: Unknown symbol VB_IsBlkValid (err 0) <4>hi3518e_ai: Unknown symbol HI_LOG (err 0) <4>hi3518e_ai: Unknown symbol CMPI_MmzFree (err 0) <4>hi3518e_ai: Unknown symbol VB_Handle2Kern (err 0) <4>hi3518e_ai: Unknown symbol VB_Handle2PoolId (err 0) <4>hi3518e_ai: Unknown symbol CMPI_GetModuleFuncById (err 0) <4>hi3518e_ai: Unknown symbol CMPI_RegisterModule (err 0) <4>hi3518e_ai: Unknown symbol CMPI_UnRegisterDevice (err 0) <4>hi3518e_ai: Unknown symbol VB_DestroyPool (err 0) <4>hi3518e_ai: Unknown symbol VB_Handle2Phys (err 0) <4>hi3518e_ai: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_ai.ko': unknown symbol in module, or unknown parameter <4>hi3518e_ao: Unknown symbol CMPI_UnRegisterModule (err 0) <4>hi3518e_ao: Unknown symbol CMPI_MmzMallocNocache (err 0) <4>hi3518e_ao: Unknown symbol CMPI_UserCopy (err 0) <4>hi3518e_ao: Unknown symbol CMPI_RemoveProc (err 0) <4>hi3518e_ao: Unknown symbol CMPI_CreateProc (err 0) <4>hi3518e_ao: Unknown symbol HI_LOG (err 0) <4>hi3518e_ao: Unknown symbol CMPI_MmzFree (err 0) <4>hi3518e_ao: Unknown symbol hil_mmb_flush_dcache_byaddr (err 0) <4>hi3518e_ao: Unknown symbol CMPI_GetModuleFuncById (err 0) <4>hi3518e_ao: Unknown symbol CMPI_RegisterModule (err 0) <4>hi3518e_ao: Unknown symbol CMPI_UnRegisterDevice (err 0) <4>hi3518e_ao: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_ao.ko': unknown symbol in module, or unknown parameter <4>hi3518e_aenc: Unknown symbol CMPI_UnRegisterModule (err 0) <4>hi3518e_aenc: Unknown symbol VB_UserAdd (err 0) <4>hi3518e_aenc: Unknown symbol CMPI_UserCopy (err 0) <4>hi3518e_aenc: Unknown symbol CMPI_RemoveProc (err 0) <4>hi3518e_aenc: Unknown symbol VB_UserSub (err 0) <4>hi3518e_aenc: Unknown symbol CMPI_CreateProc (err 0) <4>hi3518e_aenc: Unknown symbol g_stAiChn (err 0) <4>hi3518e_aenc: Unknown symbol VB_IsBlkValid (err 0) <4>hi3518e_aenc: Unknown symbol HI_LOG (err 0) <4>hi3518e_aenc: Unknown symbol CMPI_GetModuleFuncById (err 0) <4>hi3518e_aenc: Unknown symbol CMPI_RegisterModule (err 0) <4>hi3518e_aenc: Unknown symbol CMPI_UnRegisterDevice (err 0) <4>hi3518e_aenc: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_aenc.ko': unknown symbol in module, or unknown parameter <4>hi3518e_adec: Unknown symbol CMPI_UnRegisterModule (err 0) <4>hi3518e_adec: Unknown symbol CMPI_UserCopy (err 0) <4>hi3518e_adec: Unknown symbol CMPI_RemoveProc (err 0) <4>hi3518e_adec: Unknown symbol CMPI_CreateProc (err 0) <4>hi3518e_adec: Unknown symbol HI_LOG (err 0) <4>hi3518e_adec: Unknown symbol CMPI_RegisterModule (err 0) <4>hi3518e_adec: Unknown symbol CMPI_UnRegisterDevice (err 0) <4>hi3518e_adec: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_adec.ko': unknown symbol in module, or unknown parameter [m
[m[0;32;32m[OSA-APP] OSA Build on Dec 5 2018 at 04:00:03. [m[0;32;32m[OSA-APP] SVN NUM: 5514.
[m[0;32;32m[libpdi] libpdi.so Build on Nov 6 2018 at 17:26:37. [m[0;32;32m[libpdi] SVN NUM: 37655. [m[0;32;32m[libpdi] PDI product has 1 configs!!! [m[0;32;32m[libpdi] PDI product Init OK! [m[0;32;32m[libpdi] PDI hwid Get OK! [m[1;33m[libp di] WARN : RTC Dev not exists,status = -1 [0;32;32m00:00:07|[pdc] Both of Chief and Backup File CRC check OK! [m[0;32;32m00:00:07|[pdc] phyaddr = 82efe000, memLen = 2000 [m[m[0;32;32m[libpdi] Get fpga upgrade cfg failed, use default [0;32;32m00:00:07|[pdc] The cmd 3221510146 is invalid [m[m[0;32;32m[libpdi] Get flash total size failed. [0;32;32m00:00:07|[pdc] gSupportSwitchPart = 0 [m[m[0;32;32m[libpdi] Support backup partition !!! [m[0;32;32m[libpdi] Flashtype = 0x3,patSize = 0x40000,rwSize = 0x10000,ersSize = 0x10000 [m[0;32;32m[libpdi] gFlashCtrlObj.isSupportSwitchPart:0 [m[0;32;32m[libpdi] gFlashCtrlObj.bootFromBack:0 [m[0;32;32m[libpdi] gFlashCtrlObj.bootVersion:2 [m[0;32;31m[libpdi] ERROR (PDI_comGetMapInfo|1285): Fail to Get ComMapInfo [m[0;32;31m[libpdi] ERROR (PDI_preInit|155): PDI_comInit execute Error and return OSA_EFAIL [m[1;33m[libpdi] WARN : Device has no crypt chip! [m[0;32;32m[libpdi] phyaddr= 0x82efe000, memLen= 0x2000 [0;32;32m00:00:07|[pdc] Both of Chief and Backup File CRC check OK! [m[m
[m[0;32;32m[libpdi] libpdi.so Build on Nov 6 2018 at 17:26:37. [m[0;32;32m[libpdi] SVN NUM: 37655. [m[0;32;32m[libpdi] PDI product has 1 configs!!! [m[0;32;32m[libpdi] PDI product Init OK! [m[0;32;32m[libpdi] PDI hwid Get OK! [m[1;33m[libpdi] WARN : RTC Dev not exists,status = -1 [0;32;32m00:00:07|[pdc] Both of Chief and Backup File CRC check OK! [m[0;32;32m00:00:07|[pdc] phyaddr = 82efe000, memLen = 2000 [m[m[0;32;32m[libpdi] Get fpga upgrade cfg failed, use default [0;32;32m00:00:07|[pdc] The cmd 3221510146 is invalid [m[m[0;32;32m[libpdi] Get flash total size failed. [0;32;32m00:00:07|[pdc] gSupportSwitchPart = 0 [m[m[0;32;32m[libpdi] Support backup partition !!! [m[0;32;32m[libpdi] Flashtype = 0x3,patSize = 0x40000,rwSize = 0x10000,ersSize = 0x10000 [m[0;32;32m[libpdi] gFlashCtrlObj.isSupportSwitchPart:0 [m[0;32;32m[libpdi] gFlashCtrlObj.bootFromBack:0 [m[0;32;32m[libpdi] gFlashCtrlObj.bootVersion:2 [m[0;32;31m[libpdi] ERROR (PDI_comGetMapInfo|1285): Fail to Get ComMapInfo [m[0;32;31m[libpdi] ERROR (PDI_preInit|155): PDI_comInit execute Error and return OSA_EFAIL [m[1;33m[libpdi] WARN : Device has no crypt chip! [m[0;32;32m[libpdi] phyaddr= 0x82efe000, memLen= 0x2000 [0;32;32m00:00:07|[pdc] Both of Chief and Backup File CRC check OK! [m[mFail to get env hwidEx! [0;32;31m[libpdi] ERROR (PDI_comGetMapInfo|1285): Fail to Get ComMapInfo [m
[Systools]: Build on Dec 5 2018 at 04:04:15. [Systools]:SVN NUM: 36182.
Syshelper: WdtSatrtTime = 60(s), appauto = 1, hctosystime = 1500 [0;32;31m00:00:07|[libpdi] ERROR (PDI_wdtOpen|109): wdt open error [m[1;33m00:00:07|[systools] WARN : open wdt period failed [m[1;33m00:00:07|[systools] WARN : wdtStart failed [m[0;32;31m00:00:07|[libpdi] ERROR (NetGetMAC|2731): SIOCGIFHWADDR,eth0 [m[0;32;32m00:00:07|[libpdi] Get default ip failed [m[mFail to get env hwidEx! Fail to get env coremnt! [0;32;32m00:00:07|[systools] appauto 's flag = 1 [m[0;32;32m00:00:07|[systools] please wait sonia to send net info [m[0;32;31m[libpdi] ERROR (PDI_comGetMapInfo|1285): Fail to Get ComMapInfo [mName: upgraded, bulid date: Nov 6 2018 17:31:17, svn: 937 UPGRADED_MSG: start download file! sysbackup_value =1 [m
[m[0;32;32m[libpdi] libpdi.so Build on Nov 6 2018 at 17:26:37. [m[0;32;32m[libpdi] SVN NUM: 37655. [m[0;32;32m[libpdi] PDI product has 1 configs!!! [m[0;32;32m[libpdi] PDI product Init OK! [m[0;32;32m[libpdi] PDI hwid Get OK! [m[1;33m[libpdi] WARN : RTC Dev not exists,status = -1 [0;32;32m00:00:08|[pdc] Both of Chief and Backup File CRC check OK! [m[0;32;32m00:00:08|[pdc] phyaddr = 82efe000, memLen = 2000 [m[m[0;32;32m[libpdi] Get fpga upgrade cfg failed, use default [0;32;32 m00:00:08|[pdc] The cmd 3221510146 is invalid [m[m[0;32;32m[libpdi] Get flash total size failed. [0;32;32m00:00:08|[pdc] gSupportSwitchPart = 0 [m[m[0;32;32m[libpdi] Support backup partition !!! [m[0;32;32m[libpdi] Flashtype = 0x3,patSize = 0x40000,rwSize = 0x10000,ersSize = 0x10000 [m[0;32;32m[libpdi] gFlashCtrlObj.isSupportSwitchPart:0 [m[0;32;32m[libpdi] gFlashCtrlObj.bootFromBack:0 [m[0;32;32m[libpdi] gFlashCtrlObj.bootVersion:2 [m[0;32;31m[libpdi] ERROR (PDI_comGetMapInfo|1285): Fail to Get ComMapInfo [m[0;32;31m[libpdi] ERROR (PDI_preInit|155): PDI_comInit execute Error and return OSA_EFAIL [m[1;33m[libpdi] WARN : Device has no crypt chip! [m[0;32;32m[libpdi] phyaddr= 0x82efe000, memLen= 0x2000 [0;32;32m00:00:08|[pdc] Both of Chief and Backup File CRC check OK! [m[mFail to get env hwidEx! [0;32;31m[libpdi] ERROR (PDI_comGetMapInfo|1285): Fail to Get ComMapInfo [m
[0;32;32m00:00:08|[systools] Boot support backup version 2 [m[0;32;32m00:00:08|[libpdi] Read: blkIndex: 0,pageIndex: 0,byteIndex: 0 ,fLag: ff [m[0;32;32m00:00:08|[libpdi] Read: blkIndex: 0,pageIndex: 1,byteIndex: 0 ,fLag: ff [m[0;32;32m00:00:08|[libpdi] Read: blkIndex: 0,pageIndex: 2,byteIndex: 0 ,fLag: ff [m[0;32;32m00:00:08|[libpdi] Read: blkIndex: 0,pageIndex: 3,byteIndex: 0 ,fLag: ff [m[0;32;32m00:00:08|[systools] Do not need backup!!! [m[0;32;31m00:00:08|[libpdi] ERROR (CommLen_DeleteSemLock|176): CommLen_DeleteSemLock fail [m[1;33m00:00:08|[libpdi] WARN (PDI_commlenDeinit|783): CommLen_DeleteSemLock fail [m<4>sensor: Unknown symbol g_stIspExpFunc (err 0) insmod: can't insert '/usr/lib/modules/sensor.ko': unknown symbol in module, or unknown parameter product_name =01 [m
[m[0;32;32m[libpdi] libpdi.so Build on Nov 6 2018 at 17:26:37. [m[0;32;32m[libpdi] SVN NUM: 37655. [m[0;32;32m[libpdi] PDI product has 1 configs!!! [m[0;32;32m[libpdi] PDI product Init OK! [m[0;32;32m[libpdi] PDI hwid Get OK! [m[1;33m[libpdi] WARN : RTC Dev not exists,status = -1 [0;32;32m00:00:08|[pdc] Both of Chief and Backup File CRC check OK! [m[0;32;32m00:00:08|[pdc] phyaddr = 82efe000, memLen = 2000 [m[m[0;32;32m[libpdi] Get fpga upgrade cfg failed, use default [0;32;32m00:00:08|[pdc] The cmd 3221510146 is invalid [m[m[0;32;32m[libpdi] Get flash total size failed. [0;32;32m00:00:08|[pdc] gSupportSwitchPart = 0 [m[m[0;32;32m[libpdi] Support backup partition !!! [m[0;32;32m[libpdi] Flashtype = 0x3,patSize = 0x40000,rwSize = 0x10000,ersSize = 0x10000 [m[0;32;32m[libpdi] gFlashCtrlObj.isSupportSwitchPart:0 [m[0;32;32m[libpdi] gFlashCtrlObj.bootFromBack:0 [m[0;32;32m[libpdi] gFlashCtrlObj.bootVersion:2 [m[0;32;31m[libpdi] ERROR (PDI_comGetMapInfo|1285): Fail to Get ComMapInfo [m[0;32;31m[libpdi] ERROR (PDI_preInit|155): PDI_comInit execute Error and return OSA_EFAIL [m[1;33m[libpdi] WARN : Device has no crypt chip! [m[0;32;32m[libpdi] phyaddr= 0x82efe000, memLen= 0x2000 [0;32;32m00:00:08|[pdc] Both of Chief and Backup File CRC check OK! [m[mFail to get env hwidEx! [0;32;31m[libpdi] ERROR (PDI_comGetMapInfo|1285): Fail to Get ComMapInfo [m
init eth2 to default [0;36m00:00:08|[libpdi] NET_disableRoute = 0 [m[0;32;31m00:00:08|[libpdi] ERROR (CommLen_DeleteSemLock|176): CommLen_DeleteSemLock fail [m[1;33m00:00:08|[libpdi] WARN (PDI_commlenDeinit|783): CommLen_DeleteSemLock fail [m[m
[0;36m00:00:08|[libpdi] NET_disableRoute = 0 [mIPV6: only init eth2"netinit6 help" for help [0;32;31m00:00:08|[libpdi] ERROR (CommLen_DeleteSemLock|176): CommLen_DeleteSemLock fail [m[1;33m00:00:08|[libpdi] WARN (PDI_commlenDeinit|783): CommLen_DeleteSemLock fail [mcap_sd 540
RTL8188EU: module init start RTL8188EU: rtl8188eu v4.3.0.9_15178.20150907 RTL8188EU: build time: Nov 6 2018 17:17:30 SvnVersion:32572 RTL8188EU: usb_endpoint_descriptor(0): RTL8188EU: bLength=7 RTL8188EU: bDescriptorType=5 RTL8188EU: bEndpointAddress=81 RTL8188EU: wMaxPacketSize=512 RTL8188EU: bInterval=0 RTL8188EU: RT_usb_endpoint_is_bulk_in = 1 RTL8188EU: usb_endpoint_descriptor(1): RTL8188EU: bLength=7 RTL8188EU: bDescriptorType=5 RTL8188EU: bEndpointAddress=2 RTL8188EU: wMaxPacketSize=512 RTL8188EU: bInterval=0 RTL8188EU: RT_usb_endpoint_is_bulk_out = 2 RTL8188EU: usb_endpoint_descriptor(2): RTL8188EU: bLength=7 RTL8188EU: bDescriptorType=5 RTL8188EU: bEndpointAddress=3 RTL8188EU: wMaxPacketSize=512 RTL8188EU: bInterval=0 RTL8188EU: RT_usb_endpoint_is_bulk_out = 3 RTL8188EU: nr_endpoint=3, in_num=1, out_num=2
RTL8188EU: USB_SPEED_HIGH RTL8188EU: CHIP TYPE: RTL8188E RTL8188EU: register rtw_netdev_ops to netdev_ops RTL8188EU: Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_D_CUT_1T1R_RomVer(0) RTL8188EU: RF_Type is 3!! RTL8188EU: _ConfigNormalChipOutEP_8188E OutEpQueueSel(0x05), OutEpNumber(2) RTL8188EU: EEPROM type is E-FUSE RTL8188EU: ====> _ReadAdapterInfo8188EU RTL8188EU: Boot from EFUSE, Autoload OK ! RTL8188EU: SetHwReg8188EU: bMacPwrCtrlOn=1 bFWReady == _FALSE call reset 8051... RTL8188EU: =====> _8051Reset88E(): 8051 reset success . RTL8188EU: efuse_read_phymap_from_txpktbuf bcnhead:0 RTL8188EU: efuse_read_phymap_from_txpktbuf len:125, lenbak:125, aaa:125, aaabak:125 RTL8188EU: efuse_read_phymap_from_txpktbuf read count:123 RTL8188EU: EEPROM ID=0x8129 RTL8188EU: VID = 0x0BDA, PID = 0x0179 RTL8188EU: Customer ID: 0x00, SubCustomer ID: 0xCD RTL8188EU: Hal_ReadPowerSavingMode88E...bHWPwrPindetect(0)-bHWPowerdown(0) ,bSupportRemoteWakeup(1) RTL8188EU: ### PS params=> power_mgnt(0),usbss_enable(0) ### RTL8188EU: ======= Path 0, Channel 1 ======= RTL8188EU: Index24G_CCK_Base[0][1] = 0x2b RTL8188EU: Index24G_BW40_Base[0][1] = 0x30 RTL8188EU: ======= Path 0, Channel 2 ======= RTL8188EU: Index24G_CCK_Base[0][2] = 0x2b RTL8188EU: Index24G_BW40_Base[0][2] = 0x30 RTL8188EU: ======= Path 0, Channel 3 ======= RTL8188EU: Index24G_CCK_Base[0][3] = 0x2a RTL8188EU: Index24G_BW40_Base[0][3] = 0x30 RTL8188EU: ======= Path 0, Channel 4 ======= RTL8188EU: Index24G_CCK_Base[0][4] = 0x2a RTL8188EU: Index24G_BW40_Base[0][4] = 0x30 RTL8188EU: ======= Path 0, Channel 5 ======= RTL8188EU: Index24G_CCK_Base[0][5] = 0x2a RTL8188EU: Index24G_BW40_Base[0][5] = 0x30 RTL8188EU: ======= Path 0, Channel 6 ======= RTL8188EU: Index24G_CCK_Base[0][6] = 0x29 RTL8188EU: Index24G_BW40_Base[0][6] = 0x2f RTL8188EU: ======= Path 0, Channel 7 ======= RTL8188EU: Index24G_CCK_Base[0][7] = 0x29 RTL8188EU: Index24G_BW40_Base[0][7] = 0x2f RTL8188EU: ======= Path 0, Channel 8 ======= RTL8188EU: Index24G_CCK_Base[0][8] = 0x29 RTL8188EU: Index24G_BW40_Base[0][8] = 0x2f RTL8188EU: ======= Path 0, Channel 9 ======= RTL8188EU: Index24G_CCK_Base[0][9] = 0x28 RTL8188EU: Index24G_BW40_Base[0][9] = 0x2e RTL8188EU: ======= Path 0, Channel 10 ======= RTL8188EU: Index24G_CCK_Base[0][10] = 0x28 RTL8188EU: Index24G_BW40_Base[0][10] = 0x2e RTL8188EU: ======= Path 0, Channel 11 ======= RTL8188EU: Index24G_CCK_Base[0][11] = 0x28 RTL8188EU: Index24G_BW40_Base[0][11] = 0x2e RTL8188EU: ======= Path 0, Channel 12 ======= RTL8188EU: Index24G_CCK_Base[0][12] = 0x27 RTL8188EU: Index24G_BW40_Base[0][12] = 0x2e RTL8188EU: ======= Path 0, Channel 13 ======= RTL8188EU: Index24G_CCK_Base[0][13] = 0x27 RTL8188EU: Index24G_BW40_Base[0][13] = 0x2e RTL8188EU: ======= Path 0, Channel 14 ======= RTL8188EU: Index24G_CCK_Base[0][14] = 0x27 RTL8188EU: Index24G_BW40_Base[0][14] = 0x2e RTL8188EU: ======= TxCount 0 ======= RTL8188EU: CCK_24G_Diff[0][0]= 0 RTL8188EU: OFDM_24G_Diff[0][0]= 2 RTL8188EU: BW20_24G_Diff[0][0]= 0 RTL8188EU: BW40_24G_Diff[0][0]= 0 RTL8188EU: EEPROMRegulatory = 0x0 RTL8188EU: mlmepriv.ChannelPlan = 0x20 RTL8188EU: CrystalCap: 0x23 RTL8188EU: EEPROM Customer ID: 0x 0 RTL8188E U: EEPROM : AntDivCfg = 0, TRxAntDivType = 3 RTL8188EU: Board Type: 0x 0 RTL8188EU: ThermalMeter = 0x1b RTL8188EU: <==== _ReadAdapterInfo8188EU in 40 ms RTL8188EU: init_channel_set ChannelPlan ID 20 Chan num:13 RTL8188EU: pwrctrlpriv.bSupportRemoteWakeup~~~~~~ RTL8188EU: pwrctrlpriv.bSupportRemoteWakeup~~~[1]~~~ RTL8188EU: rtw_macaddr_cfg MAC Address = 00:12:34:56:78:91 RTL8188EU: bDriverStopped:1, bSurpriseRemoved:0, bup:0, hw_init_completed:0 RTL8188EU: rtw_ndev_init(eth2) RTL8188EU: _rtw_drv_register_netdev, MAC Address (if1) = 00:12:34:56:78:91 RTL8188EU: module init ret=0
[m
[m[0;32;32m[libpdi] libpdi.so Build on Nov 6 2018 at 17:26:37. [m[0;32;32m[libpdi] SVN NUM: 37655. [m[0;32;32m[libpdi] PDI product has 1 configs!!! [m[0;32;32m[libpdi] PDI product Init OK! [m[0;32;32m[libpdi] PDI hwid Get OK! [m[1;33m[libpdi] WARN : RTC Dev not exists,status = -1 [0;32;32m00:00:10|[pdc] Both of Chief and Backup File CRC check OK! [m[0;32;32m00:00:10|[pdc] phyaddr = 82efe000, memLen = 2000 [m[m[0;32;32m[libpdi] Get fpga upgrade cfg failed, use default [0;32;32m00:00:10|[pdc] The cmd 3221510146 is invalid [m[m[0;32;32m[libpdi] Get flash total size failed. [0;32;32m00:00:10|[pdc] gSupportSwitchPart = 0 [m[m[0;32;32m[libpdi] Support backup partition !!! [m[0;32;32m[libpdi] Flashtype = 0x3,patSize = 0x40000,rwSize = 0x10000,ersSize = 0x10000 [m[0;32;32m[libpdi] gFlashCtrlObj.isSupportSwitchPart:0 [m[0;32;32m[libpdi] gFlashCtrlObj.bootFromBack:0 [m[0;32;32m[libpdi] gFlashCtrlObj.bootVersion:2 [m[0;32;31m[libpdi] ERROR (PDI_comGetMapInfo|1285): Fail to Get ComMapInfo [m[0;32;31m[libpdi] ERROR (PDI_preInit|155): PDI_comInit execute Error and return OSA_EFAIL [m[1;33m[libpdi] WARN : Device has no crypt chip! [m[0;32;32m[libpdi] phyaddr= 0x82efe000, memLen= 0x2000 [0;32;32m00:00:10|[pdc] Both of Chief and Backup File CRC check OK! [m[mFail to get env hwidEx! [0;32;31m[libpdi] ERROR (PDI_comGetMapInfo|1285): Fail to Get ComMapInfo [m
[0;36m00:00:10|[libpdi] NET_disableRoute = 0 [monly init eth2 "netinit help" for help [0;32;31m00:00:10|[libpdi] ERROR (CommLen_DeleteSemLock|176): CommLen_DeleteSemLock fail [m[1;33m00:00:10|[libpdi] WARN (PDI_commlenDeinit|783): CommLen_DeleteSemLock fail [mRTL8188EU: +871x_drv - drv_open, bup=0 RTL8188EU: Set RF Chip ID to RF_6052 and RF type to 1T1R. RTL8188EU: rtl8188e_FirmwareDownload fw:NIC, size: 13904 RTL8188EU: rtl8188e_FirmwareDownload: fw_ver=b fw_subver=0001 sig=0x88e1, Month=11, Date=27, Hour=30, Minute=36 RTL8188EU: polling_fwdl_chksum: Checksum report OK! (1, 0ms), REG_MCUFWDL:0x00030005 RTL8188EU: =====> _8051Reset88E(): 8051 reset success . RTL8188EU: _FWFreeToGo: Polling FW ready OK! (20, 0ms), REG_MCUFWDL:0x000300c6 RTL8188EU: FWDL success. write_fw:1, 20ms
==> rtl8188e_iol_efuse_patch
RTL8188EU: pDM_Odm TxPowerTrackControl = 1
RTL8188EU: rtl8188eu_hal_init in 700ms RTL8188EU: hw_var_set_opmode()-4042 mode = 2 RTL8188EU: MAC Address = 00:12:34:56:78:91 RTL8188EU: -871x_drv - drv_open, bup=1
aewcfg = IPC-IPVM2150F cp: can't stat '/var/tmp/2Acfg/IPC-IPVM2150F/icr_para.bin': No such file or directory
appauto=1
./usr/etc/app.sh: line 9: can't create /proc/osa_root/pdc/pdcWdt: nonexistent directory
[m
[m[0;32;32m[libpdi] libpdi.so Build on Nov 6 2018 at 17:26:37. [m[0;32;32m[libpdi] SVN NUM: 37655. [m[0;32;32m[libpdi] PDI product has 1 configs!!! [m[0;32;32m[libpdi] PDI product Init OK! [m[0;32;32m[libpdi] PDI hwid Get OK! [m[1;33m[libpdi] WARN : RTC Dev not exists,status = -1 [0;32;32m00:00:12|[pdc] Both of Chief and Backup File CRC check OK! [m[0;32;32m00:00:12|[pdc] phyaddr = 82efe000, memLen = 2000 [m[m[0;32;32m[libpdi] Get fpga upgrade cfg failed, use default [0;32;32m00:00:12|[pdc] The cmd 3221510146 is invalid [m[m[0;32;32m[libpdi] Get flash total size failed. [0;32;32m00:00:12|[pdc] gSupportSwitchPart = 0 [m[m[0;32;32m[libpdi] Support backup partition !!! [m[0;32;32m[libpdi] Flashtype = 0x3,patSize = 0x40000,rwSize = 0x10000,ersSize = 0x10000 [m[0;32;32m[libpdi] gFlashCtrlObj.isSupportSwitchPart:0 [m[0;32;32m[libpdi] gFlashCtrlObj.bootFromBack:0 [m[0;32;32m[libpdi] gFlashCtrlObj.bootVersion:2 [m[0;32;31m[libpdi] ERROR (PDI_comGetMapInfo|1285): Fail to Get ComMapInfo [m[0;32;31m[libpdi] ERROR (PDI_preInit|155): PDI_comInit execute Error and return OSA_EFAIL [m[1;33m[libpdi] WARN : Device has no crypt chip! [m[0;32;32m[libpdi] phyaddr= 0x82efe000, memLen= 0x2000 [0;32;32m00:00:12|[pdc] Both of Chief and Backup File CRC check OK! [m[mFail to get env hwidEx! [0;32;31m[libpdi] ERROR (PDI_comGetMapInfo|1285): Fail to Get ComMapInfo
[m[0;32;32m[libvsf] libvsf.a svn num: 10925 Last Build:Nov 6 2018 17:21:25
RTL8188EU: eth2 cmd=57,1,0 process_time=1320 > 1 sec
[0;32;32m00:00:17|[Binder-Lib] libbinder.so Build on Nov 6 2018 at 17:20:00. [m[0;32;32m00:00:17|[Binder-Lib] SVN NUM: 3518.
[m[0;35m00:00:17|[libvsf] ***************VSF FRAMEWORK*********** [m[0;32;32m00:00:17|[libvsf]
[m[0;32;32m00:00:17|[libvsf] /usr/bin/sonia Build on Nov 6 2018 at 17:21:25. [m[0;32;32m00:00:17|[libvsf] SVN NUM: 10925.
[m[0;32;32m00:00:17|[libvsf] Initialized server config. Product line 15, model 0. Supporting mask 0x100001 [m[0;32;31m00:00:17|[libvsf] ERROR (VSF_vinSelect|211): Not support SensorId: 29 ! [m[0;32;32m00:00:17|[libvsf] VSF_shmInit succeed [m[0;35m00:00:17|[libvsf] Node VSF_Node_0x05010000 created [m[0;32;32m00:00:17|[libvsf] VSF_ctrlInit succeed [m[0;32;32m00:00:17|[AEW] AEWB ALG Build on Nov 6 2018 at 17:21:59. [m[0;32;32m00:00:17|[AEW] SVN NUM: 40895.
[m[0;32;32m00:00:17|[AEW] params is created ok! [m[0;32;32m00:00:17|[AEW] params is inited ok! [m[0;32;32m00:00:17|[AEW] msg between 2A and sonia is created ok! [m[0;32;32m00:00:17|[AEW] app cfg create ok [m[1;33m00:00:17|[AEW] WARN (APP_cfgLoad|296): Warning!! cfgfile load failed, use default params. [m[0;32;32m00:00:17|[AEW] alg isp create ok [m[0;32;32m00:00:17|[H3A] H3A Build on Nov 6 2018 at 17:21:33. [m[0;32;32m00:00:17|[H3A] SVN NUM: 39693.
[m[0;32;31m00:00:17|[libpdi] ERROR (PDI_ircutCreate|347): Can't open /dev/pdcIRCut [m[0;32;31m00:00:17|[AEW] ERROR (Drv_AewIrcutAdaptorCreate|39): Fail to create icr! [m[0;32;31m00:00:17|[AEW_DRV] ERROR (DRV_icrCreate|113): Fail to create icr! [m[0;32;31m00:00:17|[libpdi] ERROR (PDI_adcCreate|111): Can't open /dev/pdcAdc [m[0;32;31m00:00:17|[AEW] ERROR (Drv_AewAdcAdaptorCreate|230): PDI_adcCreate failed! [m[1;33m00:00:17|[AEW_DRV] WARN (DRV_icrCreate|121): Fail to create adc! [m[0;32;32m00:00:17|[ICR] ICR Build on Nov 6 2018 at 17:21:36. [m[0;32;32m00:00:17|[ICR] SVN NUM: 43958.
[m[1;33m00:00:17|[ICR] WARN (ALG_aewICRCreate|664): The device does not have icr! [m[1;33m00:00:17|[ICR] WARN (ALG_aewICRCreate|682): The device does not have adc! [m[0;32;32m00:00:17|[ICR] adc type: 0. [m[0;32;31m00:00:17|[ICR] ERROR (APP_icrCfgReadCheckParam|58): fopen /var/tmp/icr_para.bin file fail [m[0;32;31m00:00:17|[ICR] ERROR (APP_icrCfgReadCheckParam|58): fopen /var/tmp/0/icr_para.bin file fail [m[1;33m00:00:17|[ICR] WARN (ALG_aewICRCreate|713): Can't find icr_para.bin ! [m[1;33m00:00:17|[ICR] WARN (ALG_icrGetCfgParam|99): The nPrdtLineId =15 does not suppourted! [m[0;32;32m00:00:17|[ICR] icrGetCfgParam: nPrdtLineId:15,nSensorId:29, pa_algIcrCfgParam:0xad300c [m[0;32;31m00:00:17|[libpdi] ERROR (PDI_smartIrCreate|100): Can't open /dev/pdcSmartIR [m[0;32;31m00:00:17|[AEW] ERROR (AEW_smartIrCreate|114): Fail to create SmartIr! [m[1;33m00:00:17|[AEW] WARN (ALG_smartIrCreate|205): The device does not have smartir! [m[0;35m00:00:17|[AEW] ALG_AutoIRThread Task pid=836 tid=839 [m[0;32;32m00:00:17|[AEW] smartIr thread is created successful! [m[0;32;31m00:00:17|[libpdi] ERROR (PDI_adcCreate|111): Can't open /dev/pdcAdc [m[1;33m00:00:17|[AEW] WARN (AEW_adcCreate|192): Fail to create adc! [m[0;32;31m00:00:17|[libpdi] ERROR (PDI_irisCreate|265): Can't open /dev/pdcIris [m[mcreate iris handle failed [0;32;32m00:00:17|[AEW] load default awb params ok![m[0;32;32m00:00:17|[AEW] the device's ishwidEx=0, ircut type=0 [m[0;32;32m00:00:17|[pdc] Get motor cfg failed ! [m[0;32;31m00:00:17|[AEW] ERROR (AEW_lensTypeGet|535): create lens handle failed [m[0;32;32m00:00:17|[AEW] aewb creat over
[m[0;35m00:00:17|[libvsf] Node VSF_Node_0x01010000 created [m[0;32;32m00:00:17|[libvsf] AEWB run !!! [m[0;35m00:00:17|[libvsf] Node VSF_Node_0x09010000 created [m[0;32;31m00:00:17|[libvsf] ERROR (VSF_drvSysInit|133): Unknow PicSize!..... [m[0;32;31m00:00:17|[libvsf] ERROR (VSF_encInit|651): encode drier init failed [m[0;32;31m00:00:17|[libvsf] ERROR (VSF_init|1152): VSF_encInit failed [m[0;32;31m00:00:17|[libvsf] ERROR (main _vd|172): VIDEO_serverInit() [mmain( /usr/bin/sonia AEWB) |00:00:17|[StreamApp@445535][StreamApp.cpp:18]|INFO [StreamAppComponent] initStreamAppServerComponent |00:00:17|[StreamSvr@437644][TransformatBase.cpp:9]|INFO [StreamAppComponent] initStreamSvrParseCreaterComponent |00:00:17|[StreamApp@445535][DHEncryptLiveStreamSource.cpp:17]|INFO [StreamAppComponent] initStreamAppDHEncryptComponent [0;32;32m00:00:18|[pdc] pCbparams->OpSetBeep = null [m[0;32;32m00:00:18|[libpdi] pWrapper->beep = NULL [m[0;32;32m00:00:18|[pdc] pCbparams->OpSetBeep = null [m[0;32;32m00:00:18|[libpdi] pWrapper->beep = NULL [m[0;32;32m00:00:18|[libpdi] >-------System3_getSystemInfo-------> [m /usr/bin/sonia AEWBFail to get env devalias! Fail to get env dvname! Fail to get env devOEM! Fail to get env authcode! [0;32;32m00:00:18|[libpdi] Get authcode error [mFail to get env productDate! [0;32;31m00:00:18|[libpdi] ERROR (NetGetMAC|2731): SIOCGIFHWADDR,eth0 [m[0;32;31m00:00:18|[libpdi] ERROR (PDI_comGetMapInfo|1285): Fail to Get ComMapInfo [m[1;33m00:00:18|[pdc] WARN (MISC_ioctl|746): Get SdCard cfg failed ! [m[0;32;32m00:00:18|[libpdi] deviceChannel[0]: Unknown [m[0;32;32m00:00:18|[libpdi] deviceType: 01 [m[0;32;32m00:00:18|[libpdi] processorType: 0 [m[0;32;32m00:00:18|[libpdi] hardwareVersion: 1.00 [m[0;32;32m00:00:18|[libpdi] appAutoStart: 1 [m[0;32;32m00:00:18|[libpdi] serialNumber: 000000000000000000 [m[0;32;32m00:00:18|[libpdi] deviceClass: Unknown [m[0;32;32m00:00:18|[libpdi] noPtz: 1 [m[0;32;32m00:00:18|[libpdi] noSdCard: 1 [m[0;32;32m00:00:18|[libpdi] noRTC: 1 [m[0;32;32m00:00:18|[libpdi] bandWidth: 0 [m[0;32;32m00:00:18|[libpdi] channelNum: 1 [m[0;32;32m00:00:18|[libpdi] <-------System3_getSystemInfo-------< [m[1;34;40m00:00:18|SecurityUnit|the input num is 2|Src/CipherManager/CipherManager.cpp:45|config()[0m [31;40m00:00:18|[Manager] [ver:Unknown] error CommonConfigManager.cpp config 232 tid:836 CCommonConfigManager::CCommonConfigManager() read config file /mnt/mtd/Config/Config1 /mnt/mtd/Config/Config2 failed [0m[33;40m00:00:18|[Manager] [ver:Unknown] warn CommonConfigManager.cpp config 242 tid:836 CCommonConfigManager::CCommonConfigManager() read old defalut config file failed. [0m[33;40m00:00:18|[Manager] [ver:Unknown] warn CommonConfigManager.cpp config 249 tid:836 CCommonConfigManager::CCommonConfigManager() read custom config file failed. [0;32;32m00:00:18|[pdc] pCbparams->OpSetBeep = null [m[0;32;32m00:00:18|[libpdi] pWrapper->beep = NULL [m[0;32;32m00:00:18|[libpdi] >-------System3_getSystemInfo-------> [m[0mFail to get env devalias! Fail to get env dvname! Fail to get env devOEM! Fail to get env authcode! [0;32;32m00:00:18|[libpdi] Get authcode error [mFail to get env productDate! [0;32;31m00:00:18|[libpdi] ERROR (NetGetMAC|2731): SIOCGIFHWADDR,eth0 [m[0;32;31m00:00:18|[libpdi] ERROR (PDI_comGetMapInfo|1285): Fail to Get ComMapInfo [m[1;33m00:00:18|[pdc] WARN (MISC_ioctl|746): Get SdCard cfg failed ! [m[0;32;32m00:00:18|[libpdi] deviceChannel[0]: Unknown [m[0;32;32m00:00:18|[libpdi] deviceType: 01 [m[0;32;32m00:00:18|[libpdi] processorType: 0 [m[0;32;32m00:00:18|[libpdi] hardwareVersion: 1.00 [m[0;32;32m00:00:18|[libpdi] appAutoStart: 1 [m[0;32;32m00:00:18|[libpdi] serialNumber: 000000000000000000 [m[0;32;32m00:00:18|[libpdi] deviceClass: Unknown [m[0;32;32m00:00:18|[libpdi] noPtz: 1 [m[0;32;32m00:00:18|[libpdi] noSdCard: 1 [m[0;32;32m00:00:18|[libpdi] noRTC: 1 [m[0;32;32m00:00:18|[libpdi] bandWidth: 0 [m[0;32;32m00:00:18|[libpdi] channelNum: 1 [m[0;32;32m00:00:18|[libpdi] <-------System3_getSystemInfo-------< [m[33;40m00:00:18|[Manager] [ver:] warn tid:836 init:86 use default cmos def path! [0;32;32m00:00:18|[libpdi] read RTC_SRAM_REBOOT = 1 [m[0;36m 00:00:18|[libpdi] PDI_getStartUpFlag: 1 [m[0m[32;40m00:00:18|[Manager] [ver:] info tid:836 CMagicBox::CMagicBox() getStartUpFlag 1 [0m[33;40m00:00:18|[Manager] [ver:] warn tid:836 CMagicBox::setSubModuleInfo fail! [0m[32;40m00:00:18|[Manager] [ver:] info tid:836 CMagicBox::onConfigAutoMaintain day = [2], hour = [2], min = [0], enable = [true] [0m[32;40m00:00:18|[Manager] [ver:] info tid:836 CMagicBox::startDstTune readCMOS DstTune flag is 0. [0m[33;40m00:00:18|[Manager] [ver:] warn tid:836 CMagicBox::CMagicBox() load /var/tmp/pd/ProductDefinition product definition Languages file failed. [0m[31;40m00:00:18|[Manager] [ver:Unknown] error LanguageShorthand.cpp readShorthandMap 50 tid:836 CLanguageShorthand file is not exist! [0m[33;40m00:00:18|[Unknown] [ver:Unknown] warn Main.cpp main 1043 tid:836 SDIO_test============= [0m[33;40m00:00:18|[Unknown] [ver:Unknown] warn Main.cpp main 1055 tid:836 setProductDefinition PasswdFindWay B. [0;32;31m00:00:18|[libpdi] ERROR (PDI_wdtOpen|109): wdt open error [m[0m[31;40m00:00:18|[Manager] [ver:Unknown] error UserManager.cpp initialize 352 tid:836 currDevSerial:000000000000000000 [0m[31;40m00:00:18|[Manager] [ver:Unknown] error UserManager.cpp initialize 364 tid:836 DevInformation'SerialID:000000000000000000 [0m[31;40m00:00:18|[Manager] [ver:Unknown] error UserManager.cpp initialize 352 tid:836 currDevSerial:000000000000000000 [0m[31;40m00:00:18|[Manager] [ver:Unknown] error UserManager.cpp initialize 364 tid:836 DevInformation'SerialID:000000000000000000 [0;32;32m00:00:18|[pdc] pCbparams->OpSetBeep = null [m[0;32;32m00:00:18|[libpdi] pWrapper->beep = NULL [m[0;32;32m00:00:18|[pdc] pCbparams->OpSetBeep = null [m[0;32;32m00:00:18|[libpdi] pWrapper->beep = NULL [m[0;32;32m00:00:18|[pdc] pCbparams->OpSetBeep = null [m[0;32;32m00:00:18|[libpdi] pWrapper->beep = NULL [m[0m[33;40m00:00:18|[Manager] [ver:] warn tid:836 CMagicBox::getDeviceSubClass DeviceSubClass empty ! [0m[31;40m00:00:18|[Manager] [ver:Unknown] error SSHDHelper.cpp start 72 tid:836 CSShConfigHelper::start, get ProductDefinition[SupportSSH] Failed || SupportSSH is false. [1;33m00:00:18|[libpdi] WARN : Device has no crypt chip! [m[1;33m00:00:18|[libpdi] WARN : Device has no crypt chi[1;30m00:00:18|[DH_Binder] Process sonia(pid:836) close binder ! [mp! [m[0;32;32m00:00:18|[libpdi] [m[0m[31;40m00:00:18|[Manager] [ver:Unknown] error Locales.cpp config 143 tid:836 Src/Locales.cpp:143 system has no supportLanguages. /usr/bin/sonia: Src/Locales.cpp: 144: virtual bool Dahua::Manager::CLocales::config(const Json::Value&): Assertion `0' failed. Aborted ####application exit:134, system will reboot! ./usr/etc/app.sh: line 27: /usr/bin/exittime: not found
keyboard = 0
BusyBox v1.18.4 (2015-12-21 14:21:30 CST) built-in shell (ash) Revision: 12964 Enter 'help' for a list of built-in commands.
~ # [0;32;31m00:01:10|[libpdi] ERROR (NetGetMAC|2731): SIOCGIFHWADDR,eth0 [m[0;32;32m00:01:10|[libpdi] Get default ip failed [m
vik56
Заголовок сообщения: Re: Ищу дамп на камеру Dahua DH-IPC-C22P Добавлено: 30 сен 2019, 18:17 |
С другим id.
hwid 01:02:0F:49:1D:00:01:10:01:01:04:21C:00:02:00:00:04:00:00:00:40 >$0D;
done Set HWID success! Now HWID: 01:02:0F:49:1D:00:01:10:01:01:04:21C:00:02:00:00:04:00:00:00:40 > >reset reset >$0D;
resetting ...
System startup
System startup
TEXT_BASE:81000000
miiphy_register: non unique device name '0:31' miiphy_register: non unique device name '0:2' MAC: 00-13-34-56-78-9A Up/Down PHY not link. Support backupVer:255 state:ff,err_count:07 can not search bootargs settings fail to parse bootargsParameters.text info get bootargs info failed
smagic=0x44444351
keyboard = 0
PRODUCT = 01
[m[0;36m00:00:06|[pdc] BASE_LINE: 240 [m[0;32;32m00:00:06|[pdc] OSA_kProcCreate OK [m[0;32;32m00:00:06|[OSA-DRV] Char device create OK ! [m[0;36m00:00:06|[pdc] PDC_PartionInit ok!! [m[0;32;32m00:00:06|[pdc] HWID : 01:02:0F:49:1D:00:01:10:01:01:04:21C:00:02:00:00:04:00:00:00:40 [m[0;32;31m00:00:06|[pdc] ERROR (HWID_parsePdtType|5247): nPrdtLineId f wrong ! [m[0;32;32m00:00:06|[OSA-DRV] Char device create OK ! [m[0;32;31m00:00:06|[pdc] ERROR (PDC_vinCfgPlatInit|122): Unknown Product Type [m[0;36m00:00:06|[pdc] binderFlag: 0x0, funcap: 0x0,0x0,0x0,0x0 [m[0;32;34m00:00:06|[pdc] videoOut Channel is 0 [m[0;32;31m00:00:06|[pdc] ERROR (PDC_cfgFindInitOps|331): Not probed, please check it ! [m[0;32;31m00:00:06|[pdc] ERROR (PDC_cfgInit|364): Device not found ! [m[0;32;31m00:00:06|[pdc] ERROR (PDC_drvInit|194): PDC_cfgInit() [m[1;37m00:00:06|[pdc] Dev has No Key Cfg! [m[0;32;32m00:00:06|[OSA-DRV] Char device create OK ! [m[0;32;32m00:00:06|[OSA-DRV] Char device create OK ! [m[0;32;32m00:00:06|[pdc] SramFile init ok ! [m[0;32;32m00:00:06|[pdc] Both of Chief and Backup File CRC check OK! [m[0;35m00:00:06|[OSA-DRV] recordTsk Task pid=721 tid=721 [m[0;32;32m00:00:06|[OSA-DRV] Char device create OK ! [m[0;32;32m00:00:06|[OSA-DRV] Char device create OK ! [m[0;32;31m00:00:06|[pdc] ERROR (PDC_drvInit|209): PDC Driver Initial Failed ! [m<1>mipi_init init phy power successful! load hi_mipi driver successful! *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x200f0040: 0x00000000 --> 0x00000002 [END] *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x200f0044: 0x00000000 --> 0x00000002 [END] *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x200f0080: 0x00000000 --> 0x00000001 [END] *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x200f0088: 0x00000000 --> 0x00000001 [END] *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x200f008c: 0x00000000 --> 0x00000002 [END] *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x200f0090: 0x00000000 --> 0x00000002 [END] *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x200f0094: 0x00000000 --> 0x00000001 [END] *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x2003002c: 0x000C4003 --> 0x000B4001 [END]
audioin = 1
[m
appauto=1
[m
[m[0;35m00:00:17|[libvsf] Node VSF_Node_0x01010000 created [m[0;32;32m00:00:17|[libvsf] AEWB run !!! [m[0;35m00:00:17|[libvsf] Node VSF_Node_0x09010000 created [m[0;32;31m00:00:17|[libvsf] ERROR (VSF_drvSysInit|133): Unknow PicSize!..... [m[0;32;31m00:00:17|[libvsf] ERROR (VSF_encInit|651): encode drier init failed [m[0;32;31m00:00:17|[libvsf] ERROR (VSF_init|1152): VSF_encInit failed [m[0;32;31m00:00:17|[libvsf] ERROR (main _vd|172): VIDEO_serverInit() [mmain( /usr/bin/sonia AEWB) |00:00:17|[StreamApp@445535][StreamApp.cpp:18]|INFO [StreamAppComponent] initStreamAppServerComponent |00:00:17|[StreamSvr@437644][TransformatBase.cpp:9]|INFO [StreamAppComponent] initStreamSvrParseCreaterComponent |00:00:17|[StreamApp@445535][DHEncryptLiveStreamSource.cpp:17]|INFO [StreamAppComponent] initStreamAppDHEncryptComponent [0;32;32m00:00:18|[pdc] pCbparams->OpSetBeep = null [m[0;32;32m00:00:18|[libpdi] pWrapper->beep = NULL [m[0;32;32m00:00:18|[pdc] pCbparams->OpSetBeep = null [m[0;32;32m00:00:18|[libpdi] pWrapper->beep = NULL [m[0;32;32m00:00:18|[libpdi] >-------System3_getSystemInfo-------> [m /usr/bin/sonia AEWBFail to get env devalias! Fail to get env dvname! Fail to get env devOEM! Fail to get env authcode! [0;32;32m00:00:18|[libpdi] Get authcode error [mFail to get env productDate! [0;32;31m00:00:18|[libpdi] ERROR (NetGetMAC|2731): SIOCGIFHWADDR,eth0 [m[0;32;31m00:00:18|[libpdi] ERROR (PDI_comGetMapInfo|1285): Fail to Get ComMapInfo [m[1;33m00:00:18|[pdc] WARN (MISC_ioctl|746): Get SdCard cfg failed ! [m[0;32;32m00:00:18|[libpdi] deviceChannel[0]: Unknown [m[0;32;32m00:00:18|[libpdi] deviceType: 01 [m[0;32;32m00:00:18|[libpdi] processorType: 0 [m[0;32;32m00:00:18|[libpdi] hardwareVersion: 1.00 [m[0;32;32m00:00:18|[libpdi] appAutoStart: 1 [m[0;32;32m00:00:18|[libpdi] serialNumber: 000000000000000000 [m[0;32;32m00:00:18|[libpdi] deviceClass: Unknown [m[0;32;32m00:00:18|[libpdi] noPtz: 1 [m[0;32;32m00:00:18|[libpdi] noSdCard: 1 [m[0;32;32m00:00:18|[libpdi] noRTC: 1 [m[0;32;32m00:00:18|[libpdi] bandWidth: 0 [m[0;32;32m00:00:18|[libpdi] channelNum: 1 [m[0;32;32m00:00:18|[libpdi] <-------System3_getSystemInfo-------< [m[1;34;40m00:00:18|SecurityUnit|the input num is 2|Src/CipherManager/CipherManager.cpp:45|config()[0m [31;40m00:00:18|[Manager] [ver:Unknown] error CommonConfigManager.cpp config 232 tid:836 CCommonConfigManager::CCommonConfigManager() read config file /mnt/mtd/Config/Config1 /mnt/mtd/Config/Config2 failed [0m[33;40m00:00:18|[Manager] [ver:Unknown] warn CommonConfigManager.cpp config 242 tid:836 CCommonConfigManager::CCommonConfigManager() read old defalut config file failed. [0m[33;40m00:00:18|[Manager] [ver:Unknown] warn CommonConfigManager.cpp config 249 tid:836 CCommonConfigManager::CCommonConfigManager() read custom config file failed. [0;32;32m00:00:18|[pdc] pCbparams->OpSetBeep = null [m[0;32;32m00:00:18|[libpdi] pWrapper->beep = NULL [m[0;32;32m00:00:18|[libpdi] >-------System3_getSystemInfo-------> [m[0mFail to get env devalias! Fail to get env dvname! Fail to get env devOEM! Fail to get env authcode! [0;32;32m00:00:18|[libpdi] Get authcode error [mFail to get env productDate! [0;32;31m00:00:18|[libpdi] ERROR (NetGetMAC|2731): SIOCGIFHWADDR,eth0 [m[0;32;31m00:00:18|[libpdi] ERROR (PDI_comGetMapInfo|1285): Fail to Get ComMapInfo [m[1;33m00:00:18|[pdc] WARN (MISC_ioctl|746): Get SdCard cfg failed ! [m[0;32;32m00:00:18|[libpdi] deviceChannel[0]: Unknown [m[0;32;32m00:00:18|[libpdi] deviceType: 01 [m[0;32;32m00:00:18|[libpdi] processorType: 0 [m[0;32;32m00:00:18|[libpdi] hardwareVersion: 1.00 [m[0;32;32m00:00:18|[libpdi] appAutoStart: 1 [m[0;32;32m00:00:18|[libpdi] serialNumber: 000000000000000000 [m[0;32;32m00:00:18|[libpdi] deviceClass: Unknown [m[0;32;32m00:00:18|[libpdi] noPtz: 1 [m[0;32;32m00:00:18|[libpdi] noSdCard: 1 [m[0;32;32m00:00:18|[libpdi] noRTC: 1 [m[0;32;32m00:00:18|[libpdi] bandWidth: 0 [m[0;32;32m00:00:18|[libpdi] channelNum: 1 [m[0;32;32m00:00:18|[libpdi] <-------System3_getSystemInfo-------< [m[33;40m00:00:18|[Manager] [ver:] warn tid:836 init:86 use default cmos def path! [0;32;32m00:00:18|[libpdi] read RTC_SRAM_REBOOT = 1 [m[0;36m 00:00:18|[libpdi] PDI_getStartUpFlag: 1 [m[0m[32;40m00:00:18|[Manager] [ver:] info tid:836 CMagicBox::CMagicBox() getStartUpFlag 1 [0m[33;40m00:00:18|[Manager] [ver:] warn tid:836 CMagicBox::setSubModuleInfo fail! [0m[32;40m00:00:18|[Manager] [ver:] info tid:836 CMagicBox::onConfigAutoMaintain day = [2], hour = [2], min = [0], enable = [true] [0m[32;40m00:00:18|[Manager] [ver:] info tid:836 CMagicBox::startDstTune readCMOS DstTune flag is 0. [0m[33;40m00:00:18|[Manager] [ver:] warn tid:836 CMagicBox::CMagicBox() load /var/tmp/pd/ProductDefinition product definition Languages file failed. [0m[31;40m00:00:18|[Manager] [ver:Unknown] error LanguageShorthand.cpp readShorthandMap 50 tid:836 CLanguageShorthand file is not exist! [0m[33;40m00:00:18|[Unknown] [ver:Unknown] warn Main.cpp main 1043 tid:836 SDIO_test============= [0m[33;40m00:00:18|[Unknown] [ver:Unknown] warn Main.cpp main 1055 tid:836 setProductDefinition PasswdFindWay B. [0;32;31m00:00:18|[libpdi] ERROR (PDI_wdtOpen|109): wdt open error [m[0m[31;40m00:00:18|[Manager] [ver:Unknown] error UserManager.cpp initialize 352 tid:836 currDevSerial:000000000000000000 [0m[31;40m00:00:18|[Manager] [ver:Unknown] error UserManager.cpp initialize 364 tid:836 DevInformation'SerialID:000000000000000000 [0m[31;40m00:00:18|[Manager] [ver:Unknown] error UserManager.cpp initialize 352 tid:836 currDevSerial:000000000000000000 [0m[31;40m00:00:18|[Manager] [ver:Unknown] error UserManager.cpp initialize 364 tid:836 DevInformation'SerialID:000000000000000000 [0;32;32m00:00:18|[pdc] pCbparams->OpSetBeep = null [m[0;32;32m00:00:18|[libpdi] pWrapper->beep = NULL [m[0;32;32m00:00:18|[pdc] pCbparams->OpSetBeep = null [m[0;32;32m00:00:18|[libpdi] pWrapper->beep = NULL [m[0;32;32m00:00:18|[pdc] pCbparams->OpSetBeep = null [m[0;32;32m00:00:18|[libpdi] pWrapper->beep = NULL [m[0m[33;40m00:00:18|[Manager] [ver:] warn tid:836 CMagicBox::getDeviceSubClass DeviceSubClass empty ! [0m[31;40m00:00:18|[Manager] [ver:Unknown] error SSHDHelper.cpp start 72 tid:836 CSShConfigHelper::start, get ProductDefinition[SupportSSH] Failed || SupportSSH is false. [1;33m00:00:18|[libpdi] WARN : Device has no crypt chip! [m[1;33m0[1;30m00:00:18|[DH_Binder] Process sonia(pid:836) close binder ! [m0:00:18|[libpdi] WARN : Device has no crypt chip! [m[0;32;32m00:00:18|[libpdi] [m[0m[31;40m00:00:18|[Manager] [ver:Unknown] error Locales.cpp config 143 tid:836 Src/Locales.cpp:143 system has no supportLanguages. /usr/bin/sonia: Src/Locales.cpp: 144: virtual bool Dahua::Manager::CLocales::config(const Json::Value&): Assertion `0' failed. Aborted ####application exit:134, system will reboot! ./usr/etc/app.sh: line 27: /usr/bin/exittime: not found
keyboard = 0
fobos
Заголовок сообщения: Re: Ищу дамп на камеру Dahua DH-IPC-C22P Добавлено: 01 окт 2019, 23:31 |
Зарегистрирован: 24 май 2017, 01:56 Наличности на руках: 710.34
Сообщения: 672 Откуда: г. Ставрополь
к сожалению мимо...это прошивка под 8Мб флешь, а у вас стоит 16Мб...если оперировать "чем то похожим", то я вам гору прошивок накидаю - до нового года можно будет экспериментировать...если хотите заняться поиском, то критерии этого поиска я уже озвучивал...повторюсь: прошивка должна быть на процессор HI3518ev200, и сенсор ominivision ov9732, размер получаемого в итоге дампа должен быть 16Мб, ну и размер ОЗУ должен совпадать с оригиналом. И то собрав из исходников, соответствующих данным требованиям, не будет гарантии, что камера заведется, т.к. есть еще масса нюансов, которые учесть трудно...
Agafon
Заголовок сообщения: Re: Ищу дамп на камеру Dahua DH-IPC-C22P Добавлено: 10 окт 2019, 17:19 |
Сообщения: 1 Откуда: Киров
vik56 писал(а): Вот оригинал. Каким программатором сливали дамп?
