Текущее время: 01 ноя 2026, 11:01
 Заголовок сообщения: ASUS X541UJ (X541UVK REV 2.0) USB 2.0 controller not working
СообщениеДобавлено: 23 янв 2020, 15:34
Hello if someone can tell which chip is USB 2.0 controller-hub on asus x541uvk 2.0 board because laptop working perfect except not recognize anything in usb 2.0 port only usb 3.0 devices on USB 3.0 port.
please inform about chip so i can replace it.
 Заголовок сообщения: Re: ASUS X541UJ (X541UVK REV 2.0) USB 2.0 controller not working
СообщениеДобавлено: 23 янв 2020, 16:11
Is 5Volt Present on all usb ports ?
Usb Data is connected directly to the PCH/Bridge ... for every port you will find an IC with 8 legs... its responsible of conducting 5Volt to USBs .... check them
СообщениеДобавлено: 23 янв 2020, 19:12
Yes i have 5volt on both usb port (1 x usb 2.0 and 1 x usb 3.0)
On usb 3.0 port when connecting usb flash 3.0 working perfectly. But when i connect old flash usb 2.0 doesnt working.
So i m sure like other motherboards that a sub 2.0 hub-controller exist but i dont have schematic so i can find it , only boardview
СообщениеДобавлено: 23 янв 2020, 21:16
Check Data Pins Resistance To Ground on the USB 2 Port
СообщениеДобавлено: 25 янв 2020, 12:11
On usb 2.0 port i have resistance PIN 3 (USB PP3 CON IO) and when i connect flash usb i have 0.20 volt on this pin.
i show on boardview that usb controller connected with cpu chip and i made rework.
Now usb 3.0 port works perfect on both usb 2.0 and usb 3.0 flash but the usb 2.0 port nothing.
СообщениеДобавлено: 25 янв 2020, 17:58
you have to change bridge ...
СообщениеДобавлено: 27 янв 2020, 10:21
where is bridge on this cpu ...i see only cpu on boardview?
СообщениеДобавлено: 27 янв 2020, 11:08
USB-controller is in the SoC (CPU)
В сети
СообщениеДобавлено: 31 янв 2020, 14:16
change CPU if u have low resistance on USB data-line to the ground
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. ASUS X541UJ (ASUS X541UVK) не стартует с подключенным АКБ
GrimPro
15 окт 2019, 08:44
Slalus Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus X541UJ-GQ035 (X541UVK REV 2.0) Замена/отключение ОЗУ
stanly
5889
13 сен 2018, 16:31
leopold1112 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Asus X541UJ-GQ444 (X541UVK rev2.0) Мультиконтроллер не транслирует PM_PWRBTN#
Roofo
01 апр 2020, 17:52
dokcon Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. x541uj-gq702 (x541uvk rev 2.0) Ищу дамп BIOS
rikster
14
7316
20 май 2018, 16:27
rikster Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus (X541uvk) Asus x541uvk rev.2 ищу биос с отключеной оперативкой
mukapotap
11 окт 2018, 09:59
mukapotap Перейти к последнему сообщению
Сейчас этот форум просматривают: foras, milovidov.dl, Vl-soft и гости: 182
