Hello if someone can tell which chip is USB 2.0 controller-hub on asus x541uvk 2.0 board because laptop working perfect except not recognize anything in usb 2.0 port only usb 3.0 devices on USB 3.0 port.
please inform about chip so i can replace it.
MoneyBot
Заголовок сообщения: ASUS X541UJ (X541UVK REV 2.0) USB 2.0 controller not working
MoneyBot
battery13v
Заголовок сообщения: Re: ASUS X541UJ (X541UVK REV 2.0) USB 2.0 controller not working
Добавлено: 23 янв 2020, 16:11
Зарегистрирован: 12 янв 2020, 13:16 Наличности на руках: 6.04 Сообщения: 34 Откуда: London
Is 5Volt Present on all usb ports ? Usb Data is connected directly to the PCH/Bridge ... for every port you will find an IC with 8 legs... its responsible of conducting 5Volt to USBs .... check them
prospa
Yes i have 5volt on both usb port (1 x usb 2.0 and 1 x usb 3.0) On usb 3.0 port when connecting usb flash 3.0 working perfectly. But when i connect old flash usb 2.0 doesnt working.
So i m sure like other motherboards that a sub 2.0 hub-controller exist but i dont have schematic so i can find it , only boardview
battery13v
Добавлено: 23 янв 2020, 21:16
Check Data Pins Resistance To Ground on the USB 2 Port
prospa
On usb 2.0 port i have resistance PIN 3 (USB PP3 CON IO) and when i connect flash usb i have 0.20 volt on this pin.
i show on boardview that usb controller connected with cpu chip and i made rework. Now usb 3.0 port works perfect on both usb 2.0 and usb 3.0 flash but the usb 2.0 port nothing.
battery13v
Добавлено: 25 янв 2020, 17:58
you have to change bridge ...
prospa
Сейчас этот форум просматривают: daniilrev и гости: 83
