Текущее время: 22 ноя 2024, 02:29
TheMArcos
Заголовок сообщения: Re: Zotac GTx 980ti articstorm - artifacts after drive installation Добавлено: 24 мар 2020, 00:02 |
Зарегистрирован: 18 мар 2020, 04:02 Наличности на руках: 21.68
Сообщения: 184 Откуда: Brasil
madking писал(а): Reball M12 M11 M1
reball the meoria modules, I understand, but take me one more doubt please, if removing the mentioned memories, if I turn the card on it will work? just for testing. and if it doesn't work even after reball, would the attempt to replace the modules be justified? thanks for help!
TheMArcos
Заголовок сообщения: Re: Zotac GTx 980ti articstorm - artifacts after drive installation Добавлено: 24 мар 2020, 19:27 |
madking писал(а): if reball does not help, then change 3 memory modules to the same guy, I was checking to see if I have any other memory module but I didn't find it but found a similar one in a Gtx750Ti the difference is that this ends with AFR and the one on the 980Ti ends with MRF, both are 512Mb, is there any problem to replace? I couldn't see any difference in the datasheet ...
