Текущее время: 22 ноя 2024, 02:52
 Заголовок сообщения: Zotac GTx 980ti articstorm - artifacts after drive installation
СообщениеДобавлено: 22 мар 2020, 20:18
hello everyone, I received a gtx980ti that from the artifacts after installing the drives, I already did the reballing but it didn't work, I rewrote the vga bios, it didn't work, accessing the pc via the onboard vga it recognizes the card, however there is an error 43, thing that I can check before condemning the GPU?
since already thanks.
 Заголовок сообщения: Re: Zotac GTx 980ti articstorm - artifacts after drive installation
СообщениеДобавлено: 22 мар 2020, 20:58
Hi! Artefacts horisontal or vertical? Can you post photo artefacts?
СообщениеДобавлено: 22 мар 2020, 22:26
If it diagonal, then do it to trash...
СообщениеДобавлено: 23 мар 2020, 00:59
Hi, this type artefact:
Another observation I can make is that the board takes a few more seconds than normal to start the Pc.
СообщениеДобавлено: 23 мар 2020, 01:08
viewtopic.php?f=48&t=96805&hilit=%2Amats%2A
run to mats
СообщениеДобавлено: 23 мар 2020, 22:33
hi, mats imagens:
however, during the test there was a lot of artifacts as shown in the images:
and
thanks for help.
СообщениеДобавлено: 23 мар 2020, 22:53
Reball
M12
M11
M1
СообщениеДобавлено: 24 мар 2020, 00:02
madking писал(а):
Reball
M12
M11
M1
reball the meoria modules, I understand, but take me one more doubt please, if removing the mentioned memories, if I turn the card on it will work? just for testing.
and if it doesn't work even after reball, would the attempt to replace the modules be justified?
thanks for help!
СообщениеДобавлено: 24 мар 2020, 01:51
Without these modules, the card will not produce an image.
if reball does not help, then change 3 memory modules to the same
if there are problems after the replacement, the GPU has died
СообщениеДобавлено: 24 мар 2020, 19:27
guy,
I was checking to see if I have any other memory module but I didn't find it but found a similar one in a Gtx750Ti the difference is that this ends with AFR and the one on the 980Ti ends with MRF, both are 512Mb, is there any problem to replace? I couldn't see any difference in the datasheet ...
СообщениеДобавлено: 24 мар 2020, 21:36
if hynix, look at R0T or R2T it's speed dependent
СообщениеДобавлено: 25 мар 2020, 22:38
after reballing the same mistakes remained, but there was a change in the numbers there when reading the mats, should I hope? I am looking for compatible hinyx modules for replacement.
another detail I noticed, is that while it stays on the windows loading page, the keyboard keeps flashing, turning on and off, until it locks in the artifacts and stays on for good.
СообщениеДобавлено: 26 мар 2020, 00:19
compatible GDDR5
hynix H5GQ4H24MFR - R2C
samsung K4G41325FC - HC28
СообщениеДобавлено: 27 мар 2020, 06:40
hello friends, I need help, after using the memory modules (samsung K4G41325FC - HC28) accused by the mats, the video card ran with the fans 100% and did not upload any more videos, so I disassembled it and saw the measurements and I don’t have any more vrms tension nor of memory, in the pwm ncp81174 I have 1.2v (low?) in the enab and 5v in the Vcc, however without movement in the g1 / g4, what can I check now?
Rgpu = 2.7omhs
Memories = 25 omhs
L5 (1v) = 365ohm
L20 = 1.7v
В этой теме нет новых непрочитанных сообщений. Zotac RTX 2080ti artifacts after driver and 0 errors on MATS, No error 43, any ideas?
metobala
24 июл 2021, 07:20
Joe24 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Zotac GTX 1080 8GB artifacts died memory or gpu ??
allas
12 дек 2020, 16:27
allas Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Next GT440 2GB artifacts after loading video driver
FRD
3574
22 окт 2016, 22:17
makarog Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. ZOTAC RTX 2080TI Gets me Artifacts
MicroTech Computers
06 окт 2020, 07:43
LO-master Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Zotac GTX 1060 6gb cannot install driver | Zotac GTX 1060 6gb не может установить драйвер
katoda22
20 июн 2024, 04:46
hrwang Перейти к последнему сообщению
Сейчас этот форум просматривают: wid0wmak3r и гости: 105
cron
