Текущее время: 22 ноя 2024, 04:23
 Страница 1 из 1 [ Сообщений: 25 ]
 Заголовок сообщения: P8H67-M PRO Usb Device Over Current Status Detected
СообщениеДобавлено: 19 апр 2020, 18:12
All usb are good have voltages.
Has anyone encountered this problem, I have had a couple of times so far but failed to resolve it
changed 3 processors
the pins on the socket are good
 Заголовок сообщения: Re: P8H67-M PRO Usb Device Over Current Status Detected
СообщениеДобавлено: 19 апр 2020, 18:32
Slave82
Hello, if you have a boardview on the Board, check the resistor assemblies URN1 URN2 URN3 URN4 most likely you will find a break in one of the assemblies
You should also check whether the power supply voltage is present on the USB ports 5V
Стёрли.
СообщениеДобавлено: 19 апр 2020, 18:35
Download boardview for this model motherboard and find circuit OC#1, OC#2 and etc. Check it.
СообщениеДобавлено: 20 апр 2020, 01:03
I changed the resistors but same problem
when i enter new bios via programmer it can enter bios but after first save it goes back to the beginning and goes off after 15 seconds
СообщениеДобавлено: 20 апр 2020, 02:24
All usb ports have +5 voltage present? If yes, and resistors URN(1,2,3,4) is changed/good, and post still show overcurrent warning -> south bridge is damaged.
Главный враг истины не отсутствие знания, а иллюзия знания.
СообщениеДобавлено: 20 апр 2020, 12:16
that all usb ports have 5 volts
the resistors were changed just in case al were good
СообщениеДобавлено: 20 апр 2020, 13:14
what about this signals? :wo)(ll:
СообщениеДобавлено: 20 апр 2020, 20:00
I don't have an oscillator
СообщениеДобавлено: 20 апр 2020, 20:20
Don't need oscillator. It dc signal. 3 volt or 0 volt. All of them must be 3 volt.
СообщениеДобавлено: 20 апр 2020, 20:23
You don't need oscilloscope now. Just do measure voltage at 1,3,5,7 pin on URN4, and 1,3,7 pin on URN2.
СообщениеДобавлено: 20 апр 2020, 21:19
URN4
1-3v
3-3v
5-0v
7-0v
URN2
1-3v
3-3v
7-3v
СообщениеДобавлено: 20 апр 2020, 21:28
Slave82 писал(а):
5-0v
7-0v
Here your problem. Measure resistance on this lines compare to ground.
СообщениеДобавлено: 20 апр 2020, 21:30
urn4 - 5,7 - bad
now check urn1 pin 4, 2
I think uf6, uf7 is bad
СообщениеДобавлено: 20 апр 2020, 23:14
URN1
2-0v
4-0v
my version of the board is 1.05
СообщениеДобавлено: 20 апр 2020, 23:16
check UF6, UF7
СообщениеДобавлено: 20 апр 2020, 23:20
Here +5V present?
СообщениеДобавлено: 21 апр 2020, 17:25
has all the voltages in those places more precisely 5volts
СообщениеДобавлено: 21 апр 2020, 17:31
find broken trace from USB to URN1
СообщениеДобавлено: 21 апр 2020, 18:39
Place temporary wire from USB +5V to 2,4 pin of URN1 and try boot-up the motherboard. If she will work propertly, you can seeking damaged track, or create some bypass circuit, like a recommended for temporary.
СообщениеДобавлено: 22 апр 2020, 11:42
Tried but same case
СообщениеДобавлено: 22 апр 2020, 12:07
try what? :ps_ih:
are you have 5v on usb1314? are you have 5v on urn1 pin4? it same wire! take off ud7, find broken trace.
are you have 5v on usb1112? are you have 5v on urn1 pin2? it same wire! take off ud6, find broken trace.
СообщениеДобавлено: 22 апр 2020, 13:32
I have 5 volts in all places
СообщениеДобавлено: 22 апр 2020, 13:56
Slave82 писал(а):
URN1
2-0v
4-0v
What about this? I don't understand.
СообщениеДобавлено: 26 апр 2020, 14:24
I'm giving up!
СообщениеДобавлено: 26 апр 2020, 19:22
Take off memory, motherboard don't will poweroff. You have a time for measurement..
Measure votage on USB1314 and USB1112, then measure voltage on URN1 pin 2 and pin4.
Result write here.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. ASUS Z170 PRO Gaming "usb device over current status detected"
в форуме Asus
SJan
14
5854
05 май 2020, 01:27
arneol Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus m2n USB device over current status detected
в форуме Asus
jjoloka
04 дек 2015, 13:47
jjoloka Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Eee PC1015PE (1015PZ rev 1.1G) USB Device Over Current Status Detected
diamondelectr
27 мар 2016, 13:45
egorofff Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus p8h61-ml lx3plus r2.0 USB Device Over Current Status Detected
в форуме Asus
SevenPC
05 авг 2016, 11:53
SevenPC Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Asus M5A78L-M LX3 Rev 1.01 - USB Device Over Current Status Detected
в форуме Asus
StereoKolobok
4664
28 июн 2017, 17:56
StereoKolobok Перейти к последнему сообщению
