Текущее время: 20 ноя 2026, 19:47
 Заголовок сообщения: Дамп видеорегистратора NextCAM YE-HD 4550 DVR
СообщениеДобавлено: 24 апр 2020, 01:08
плата: DALAH v:2.3
TW2704AS-SL(V2.3/P)1601043029
 Заголовок сообщения: Re: Дамп видеорегистратора NextCAM YE-HD 4550 DVR
СообщениеДобавлено: 24 апр 2020, 13:10
Ищу дамп на видеорегистратора NextCAM YE-HD 4550 DVR
U-Boot 2010.06 (Jun 21 2013 - 11:45:11)
Check spi flash controller v350... Found
Spi(cs1) ID: 0x01 0x20 0x18 0x03 0x01 0x00
Spi(cs1): Block:64KB Chip:16MB Name:"S25FL128P-1"
In: serial
Out: serial
Err: serial
current hi352xx version 201306211132
current used inner phy
current used 256M mem
current used param offset 11111111111111111
current do_check_flash_boot_param
current prod net 100m
init gpio led setting
dev 0 set background color!
dev 2 set background color!
dev 0 opened!
dev 2 opened!
jpeg decoding .
<<addr=0x80080000, size=0x4604, vobuf=0x8fd00000>>
mmu_enable
<<imgwidth=480, imgheight=320, linebytes=960>>
decode success!!!!
dev 0 opened!
vo hd 0 end
dev 2 opened!
vo cvbs end
graphic layer 0 opened!
graphic layer 2 opened!
USB: scanning bus for devices... 2 USB Device(s) found
0 Storage Device(s) found
Hit any key to stop autoboot: 0
16384 KiB hi_sfc at 0:0 is now current device
## Booting kernel from Legacy Image at 82000000 ...
Image Name: Linux
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2285288 Bytes = 2.2 MiB
Load Address: 80008000
Entry Point: 80008000
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 3.0.8 (lzg@localhost.localdomain) (gcc version 4.4.1 (Hisilicon_v1
00(gcc4.4-290+uclibc_0.9.32.1+eabi+linuxpthread)) ) #15 Wed Aug 21 11:10:56 CST
2013
CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VI
Machine: hi3520d
Memory policy: ECC disabled, Data cache writeback
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 19812
Kernel command line: mem=78M console=ttyAMA0,115200 root=/dev/mtdblock2 rootfsty
pe=jffs2 mtdparts=hi_sfc:768K(boot),2304K(dva110000),13M(rootfs)
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 78MB = 78MB total
Memory: 74496k/74496k available, 5376k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xc5000000 - 0xfe000000 ( 912 MB)
lowmem : 0xc0000000 - 0xc4e00000 ( 78 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.init : 0xc0008000 - 0xc0029000 ( 132 kB)
.text : 0xc0029000 - 0xc040f000 (3992 kB)
.data : 0xc0410000 -
.bss : 0xc042e224 - 0xc047bd80 ( 311 kB)
SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:128 nr_irqs:128 128
sched_clock: 32 bits at 82MHz, resolution 12ns, wraps every 52060ms
Console: colour dummy device 80x30
Calibrating delay loop... 1318.91 BogoMIPS (lpj=6594560)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
NET: Registered protocol family 16
Serial: AMBA PL011 UART driver
uart:0: ttyAMA0 at MMIO 0x20080000 (irq = 40) is a PL011 rev2
console [ttyAMA0] enabled
uart:1: ttyAMA1 at MMIO 0x20090000 (irq = 41) is a PL011 rev2
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
cfg80211: Calling CRDA to update world regulatory domain
Switching to clocksource timer1
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 409
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
NetWinder Floating Point Emulator V0.97 (double precision)
L2cache cache controller enabled
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
fuse init (API version 7.16)
msgmni has been set to 145
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
io scheduler noop registered
io scheduler deadline registered (default)
io scheduler cfq registered
brd: module loaded
loop: module loaded
ahci: SSS flag set, parallel bus scan disabled
ahci ahci.0: AHCI 0001.0200 32 slots 2 ports 3 Gbps 0x3 impl platform mode
ahci ahci.0: flags: ncq sntf stag pm led clo only pmp pio slum part ccc sxs boh
scsi0 : ahci_platform
scsi1 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x10080000-0x1008ffff] port 0x100 irq 52
ata2: SATA max UDMA/133 mmio [mem 0x10080000-0x1008ffff] port 0x180 irq 52
Spi id table Version 1.22
SPI FLASH start_up_mode is 3 Bytes
Spi(cs1):
Block:64KB
Chip:16MB
spi size: 0x16777216
chip num: 1
3 cmdlinepart partitions found on MTD device hi_sfc
Creating 3 MTD partitions on "hi_sfc":
0x000000000000-0x0000000c0000 : "boot"
0x0000000c0000-0x000000300000 : "dva110000"
0x000000300000-0x000001000000 : "rootfs"
Fixed MDIO Bus: probed
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
PPP BSD Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
hiusb-ehci hiusb-ehci.0: HIUSB EHCI
hiusb-ehci hiusb-ehci.0: new USB bus registered, assigned bus number 1
hiusb-ehci hiusb-ehci.0: irq 53, io mem 0x100b0000
hiusb-ehci hiusb-ehci.0: USB 0.0 started, EHCI 1.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
hiusb-ohci hiusb-ohci.0: HIUSB OHCI
hiusb-ohci hiusb-ohci.0: new USB bus registered, assigned bus number 2
hiusb-ohci hiusb-ohci.0: irq 54, io mem 0x100a0000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
usbcore: registered new interface driver cdc_wdm
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver ums-alauda
usbcore: registered new interface driver usbserial
USB Serial support registered for generic
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial Driver core
USB Serial support registered for GSM modem (1-port)
usbcore: registered new interface driver option
option: v0.7.2:USB Driver for GSM modems
USB Serial support registered for pl2303
usbcore: registered new interface driver pl2303
pl2303: Prolific PL2303 USB to serial adaptor driver
mousedev: PS/2 mouse device common for all mice
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
TCP cubic registered
Initializing XFRM netlink socket
NET: Registered protocol family 10
IPv6 over IPv4 tunneling driver
NET: Registered protocol family 17
NET: Registered protocol family 15
lib80211: common routines for IEEE802.11 drivers
Registering the dns_resolver key type
registered taskstats version 1
ata1: SATA link down (SStatus 0 SControl 300)
ata2: SATA link down (SStatus 0 SControl 300)
usb 2-2: new full speed USB device number 2 using hiusb-ohci
input: MOSART Semi. 2.4G Wireless Mouse as /devices/platform/hiusb-ohci.0/usb2/2
-2/2-2:1.0/input/input0
generic-usb 0003:3938:1031.0001: input: USB HID v1.10 Mouse [MOSART Semi. 2.4G W
ireless Mouse] on usb-hiusb-ohci-2/input0
VFS: Mounted root (jffs2 filesystem) on device 31:2.
Freeing init m
_ _ _ _ _ _ _ _ _ _ _ _
\ _ _ _ _ _ ___
/ /__/ \ |_/
/ __ / - _ ___
_ _ _ _/ / / \_/ \_ ______
___________\___\__________________
[RCS]: /etc/init.d/S00devs
[RCS]: /etc/init.d/S01udev
Jan 1 00:00:03 udevd (474): /proc/474/oom_adj is deprecated, please use /proc/4
74/oom_score_adj instead.
udevd[474]: main: error opening /dev/null: No such file or directory
[RCS]: /etc/init.d/S80network
[RCS]: /etc/init.d/S81toe
/upgrade/preupgra
Auto login as root ...
(none) login: admin
Password:
Login incorrect
(none) login: admin
Password:
СообщениеДобавлено: 24 апр 2020, 16:27
показывайте вывод help и printenv
СообщениеДобавлено: 24 апр 2020, 20:56
Как мне это сделать?
СообщениеДобавлено: 24 апр 2020, 22:11
остановить загрузку и дать по-очереди команды
СообщениеДобавлено: 25 апр 2020, 00:46
hisilicon # hheellpp
? - alias for 'help'
base - print or set address offset
bootm - boot application image from memory
bootp - boot image via network using BOOTP/TFTP protocol
cmp - memory compare
cp - memory copy
crc32 - checksum calculation
ddrp - ddrp training tools v200
ddrt - ddr training tools v200
decjpg - jpgd - decode jp
fatinfo - print information about filesystem
fatload - load binary file from a dos filesystem
fatls - list files in a directory (default /)
getinfo - print hardware information
go - start application at address 'addr'
help - print command description/usage
loadb - load binary file over serial line (kermit mode)
loady - load binary file over serial line (ymodem mode)
loop - infinite loop on address range
md - memory display
mii - MII utility commands
mm - memory modify (auto-increme
mtest - simple RAM read/write test
mw - memory write (fill)
nm - memory modify (constant address)
ping - send ICMP ECHO_REQUEST to network host
printenv- print environment variables
rarpboot- boot image via network using RARP/TFTP protocol
reset - Perform RESET of the CPU
saveenv - save environment variables to persistent storage
setenv - set environment variables
setvobg - setvobg - set vo backgroud color.
- setvobg [dev color]
sf - SPI flash sub-system
startgx - startgx - open graphics layer.
- startgx [layer addr stride x y w h]
startvo - startvo - open interface of vo device.
- startvo [dev type sync]
stopgx - stopgx - close graphics layer.
- stopgx [layer]
stopvo - stopvo - close interface of vo device.
- stopvo [dev]
tftp - tftp - download or upload image via network using TFTP protocol
usb - USB sub-system
usbboot - boot from USB device
version - print monitor version
hisilicon #
baudrate=115200
ethaddr=00:00:23:34:45:66
ipaddr=192.168.1.10
serverip=192.168.1.2
netmask=255.255.254.0
bootfile="uImage"
bootcmd=sf probe 0;sf read 0x82000000 0x0C0000 0x240000;bootm 0x82000000
phyintfx=1
bootargs=mem=78M console=ttyAMA0,115200 root=/dev/mtdblock2 rootfstype=jffs2 mtd
auversion0=51c3cc81
auversion1=52142fdf
auversion2=57e267f0
stdin=serial
stdout=serial
stderr=serial
verify=n
jpeg_addr=0x80080000
jpeg_size=0x4604
vobuf=0x8fd00000
ver=U-Boot 2010.06 (Jun 21 2013 - 11:45:11)
Environment size: 561/131068 bytes
hisilicon #
СообщениеДобавлено: 25 апр 2020, 22:10
Висит на лого.
СообщениеДобавлено: 04 май 2020, 22:19
hisilicon # tftp 0x82000000 dump.bin 0x1000000
Hisilicon ETH net controler
MAC: 00-00-23-34-45-66
UP_PORT : phy status change : LINK=DOWN : DUPLEX=FULL : SPEED=100M
UP_PORT : phy status change : LINK=UP : DUPLEX=FULL : SPEED=100M
TFTP to server 192.168.1.2; our IP address is 192.168.1.10
Upload Filename 'dump.bin'.
Upload from address: 0x82000000, 16.000 MB to be send ...
Uploading: *
ARP Retry count exceeded; starting again
Uploading: *
Пожалуйста, помогите. Где моя ошибка?
В этой теме нет новых непрочитанных сообщений. Canon MF 4550 D ошибка E736-0000
kipelov_v_a
4195
30 апр 2020, 18:35
Mishel01 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Ремонт видеорегистратора st dvr 1604 Light
Вячеслав_AT
07 июл 2017, 23:35
fedulaev Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Ищу дамп iTech PRO DVR-161P, мать DVR-HF-S 21-305 80116789
kromka
17 сен 2021, 07:11
kromka Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. D6008D-F (8ch) Model DVR-2008E China DVR MX25L6405
saifkhan250
20 сен 2023, 20:42
saifkhan250 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Дамп от видеорегистратора может кому нужен AHB780XR-3520D_v5.03
***FOX***
10 мар 2018, 14:05
***FOX*** Перейти к последнему сообщению
