Текущее время: 19 ноя 2026, 18:09
MoneyBot
Заголовок сообщения: Дамп видеорегистратора NextCAM YE-HD 4550 DVR |
MoneyBot
m70bg
Заголовок сообщения: Re: Дамп видеорегистратора NextCAM YE-HD 4550 DVR  Добавлено: 24 апр 2020, 13:10 |
| Я тут случайно |
Сообщения: 7 Откуда: Bulgaria
Ищу дамп на видеорегистратора NextCAM YE-HD 4550 DVR
U-Boot 2010.06 (Jun 21 2013 - 11:45:11)
Check spi flash controller v350... Found Spi(cs1) ID: 0x01 0x20 0x18 0x03 0x01 0x00 Spi(cs1): Block:64KB Chip:16MB Name:"S25FL128P-1" In: serial Out: serial Err: serial current hi352xx version 201306211132 current used inner phy current used 256M mem current used param offset 11111111111111111 current do_check_flash_boot_param current prod net 100m init gpio led setting dev 0 set background color! dev 2 set background color! dev 0 opened! dev 2 opened! jpeg decoding . <<addr=0x80080000, size=0x4604, vobuf=0x8fd00000>> mmu_enable <<imgwidth=480, imgheight=320, linebytes=960>> decode success!!!! dev 0 set background color! dev 2 set background color! dev 0 opened! vo hd 0 end dev 2 opened! vo cvbs end graphic layer 0 opened! graphic layer 2 opened! USB: scanning bus for devices... 2 USB Device(s) found 0 Storage Device(s) found Hit any key to stop autoboot: 0 16384 KiB hi_sfc at 0:0 is now current device
## Booting kernel from Legacy Image at 82000000 ... Image Name: Linux Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2285288 Bytes = 2.2 MiB Load Address: 80008000 Entry Point: 80008000 Loading Kernel Image ... OK OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel. Linux version 3.0.8 (lzg@localhost.localdomain) (gcc version 4.4.1 (Hisilicon_v1 00(gcc4.4-290+uclibc_0.9.32.1+eabi+linuxpthread)) ) #15 Wed Aug 21 11:10:56 CST 2013 CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c53c7f CPU: VIPT nonaliasing data cache, VI Machine: hi3520d Memory policy: ECC disabled, Data cache writeback Built 1 zonelists in Zone order, mobility grouping on. Total pages: 19812 Kernel command line: mem=78M console=ttyAMA0,115200 root=/dev/mtdblock2 rootfsty pe=jffs2 mtdparts=hi_sfc:768K(boot),2304K(dva110000),13M(rootfs) PID hash table entries: 512 (order: -1, 2048 bytes) Dentry cache hash table entries: 16384 (order: 4, 65536 bytes) Inode-cache hash table entries: 8192 (order: 3, 32768 bytes) Memory: 78MB = 78MB total Memory: 74496k/74496k available, 5376k reserved, 0K highmem Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) DMA : 0xffc00000 - 0xffe00000 ( 2 MB) vmalloc : 0xc5000000 - 0xfe000000 ( 912 MB) lowmem : 0xc0000000 - 0xc4e00000 ( 78 MB) modules : 0xbf000000 - 0xc0000000 ( 16 MB) .init : 0xc0008000 - 0xc0029000 ( 132 kB) .text : 0xc0029000 - 0xc040f000 (3992 kB) .data : 0xc0410000 - .bss : 0xc042e224 - 0xc047bd80 ( 311 kB) SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 NR_IRQS:128 nr_irqs:128 128 sched_clock: 32 bits at 82MHz, resolution 12ns, wraps every 52060ms Console: colour dummy device 80x30 Calibrating delay loop... 1318.91 BogoMIPS (lpj=6594560) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok NET: Registered protocol family 16 Serial: AMBA PL011 UART driver uart:0: ttyAMA0 at MMIO 0x20080000 (irq = 40) is a PL011 rev2 console [ttyAMA0] enabled uart:1: ttyAMA1 at MMIO 0x20090000 (irq = 41) is a PL011 rev2 bio: create slab <bio-0> at 0 SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb cfg80211: Calling CRDA to update world regulatory domain Switching to clocksource timer1 NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 409 TCP established hash table entries: 4096 (order: 3, 32768 bytes) TCP bind hash table entries: 4096 (order: 2, 16384 bytes) TCP: Hash tables configured (established 4096 bind 4096) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 NetWinder Floating Point Emulator V0.97 (double precision) L2cache cache controller enabled JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc. fuse init (API version 7.16) msgmni has been set to 145 Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254) io scheduler noop registered io scheduler deadline registered (default) io scheduler cfq registered brd: module loaded loop: module loaded ahci: SSS flag set, parallel bus scan disabled ahci ahci.0: AHCI 0001.0200 32 slots 2 ports 3 Gbps 0x3 impl platform mode ahci ahci.0: flags: ncq sntf stag pm led clo only pmp pio slum part ccc sxs boh
scsi0 : ahci_platform scsi1 : ahci_platform ata1: SATA max UDMA/133 mmio [mem 0x10080000-0x1008ffff] port 0x100 irq 52 ata2: SATA max UDMA/133 mmio [mem 0x10080000-0x1008ffff] port 0x180 irq 52 Spi id table Version 1.22 Spi(cs1) ID: 0x01 0x20 0x18 0x03 0x01 0x00 SPI FLASH start_up_mode is 3 Bytes Spi(cs1): Block:64KB Chip:16MB Name:"S25FL128P-1" spi size: 0x16777216 chip num: 1 3 cmdlinepart partitions found on MTD device hi_sfc Creating 3 MTD partitions on "hi_sfc": 0x000000000000-0x0000000c0000 : "boot" 0x0000000c0000-0x000000300000 : "dva110000" 0x000000300000-0x000001000000 : "rootfs" Fixed MDIO Bus: probed PPP generic driver version 2.4.2 PPP Deflate Compression module registered PPP BSD Compression module registered PPP MPPE Compression module registered NET: Registered protocol family 24 ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver hiusb-ehci hiusb-ehci.0: HIUSB EHCI hiusb-ehci hiusb-ehci.0: new USB bus registered, assigned bus number 1 hiusb-ehci hiusb-ehci.0: irq 53, io mem 0x100b0000 hiusb-ehci hiusb-ehci.0: USB 0.0 started, EHCI 1.0 hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver hiusb-ohci hiusb-ohci.0: HIUSB OHCI hiusb-ohci hiusb-ohci.0: new USB bus registered, assigned bus number 2 hiusb-ohci hiusb-ohci.0: irq 54, io mem 0x100a0000 hub 2-0:1.0: USB hub found hub 2-0:1.0: 2 ports detected usbcore: registered new interface driver cdc_acm cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters usbcore: registered new interface driver cdc_wdm Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. usbcore: registered new interface driver ums-alauda usbcore: registered new interface driver usbserial USB Serial support registered for generic usbcore: registered new interface driver usbserial_generic usbserial: USB Serial Driver core USB Serial support registered for GSM modem (1-port) usbcore: registered new interface driver option option: v0.7.2:USB Driver for GSM modems USB Serial support registered for pl2303 usbcore: registered new interface driver pl2303 pl2303: Prolific PL2303 USB to serial adaptor driver mousedev: PS/2 mouse device common for all mice usbcore: registered new interface driver usbhid usbhid: USB HID core driver TCP cubic registered Initializing XFRM netlink socket NET: Registered protocol family 10 IPv6 over IPv4 tunneling driver NET: Registered protocol family 17 NET: Registered protocol family 15 lib80211: common routines for IEEE802.11 drivers Registering the dns_resolver key type registered taskstats version 1 ata1: SATA link down (SStatus 0 SControl 300) ata2: SATA link down (SStatus 0 SControl 300) usb 2-2: new full speed USB device number 2 using hiusb-ohci input: MOSART Semi. 2.4G Wireless Mouse as /devices/platform/hiusb-ohci.0/usb2/2 -2/2-2:1.0/input/input0 generic-usb 0003:3938:1031.0001: input: USB HID v1.10 Mouse [MOSART Semi. 2.4G W ireless Mouse] on usb-hiusb-ohci-2/input0 VFS: Mounted root (jffs2 filesystem) on device 31:2. Freeing init m
_ _ _ _ _ _ _ _ _ _ _ _ \ _ _ _ _ _ ___ / /__/ \ |_/ / __ / - _ ___ / / / / / / _ _ _ _/ / / \_/ \_ ______ ___________\___\__________________
[RCS]: /etc/init.d/S00devs [RCS]: /etc/init.d/S01udev Jan 1 00:00:03 udevd (474): /proc/474/oom_adj is deprecated, please use /proc/4 74/oom_score_adj instead. udevd[474]: main: error opening /dev/null: No such file or directory [RCS]: /etc/init.d/S80network [RCS]: /etc/init.d/S81toe /upgrade/preupgra Auto login as root ... (none) login: admin Password: Login incorrect (none) login: admin Password:
