Текущее время: 22 ноя 2024, 15:42
 Заголовок сообщения: Zotac 1050 2gb mini - help finding 1.8V bios
СообщениеДобавлено: 24 апр 2020, 04:51
Hello guys, the card does not have Vcore, Vmem, Pcivdd and enable in up9509, looking for something wrong I saw that 1.8v is not coming on pin 1 and 8 of the bios, it is generated by the component in the photo below, replaced component, but same behavior without 1.8 v on bios, resistance on pin 1 and 15k on pin 8 of 1.5k, could someone instruct me what to look for now? continuity of the voltage regulator to pin 8 of the bios.
 Заголовок сообщения: Re: Zotac 1050 2gb mini - help finding 1.8V bios
СообщениеДобавлено: 24 апр 2020, 05:58
Can you remove 1.8V regulator and provide 1.8V/0.2A from laboratory power supply in to 4-8pin SPI flash(without any other supplies)? What a current consumption will be?
Главный враг истины не отсутствие знания, а иллюзия знания.
СообщениеДобавлено: 25 апр 2020, 07:07
hi,sorry for the delay, is that i can only work on cards 22:00 ~ 01: 00am brasilia time, i removed the regulator and injected 1.8v the consumption current was 0.500mA on pin 8, is this normal?
СообщениеДобавлено: 25 апр 2020, 07:31
If 0.5mA(NOT "0.5A", like a 500mA) - normal. But why your linear regulator U504 doesn't give 1.8V(maybe it broken)? "Z08N" - that marking chip was on board from manufacture? Can't find information for that chip. :-(
СообщениеДобавлено: 25 апр 2020, 07:50
I have another identical pcb, and the chip has another nomeclature, (image), I have already inverted them and continued the same thing, I am suspicious of a broken track, if I only heard 1.8v on the regulator output I would try a jumper, but only I have 0.4mV.
СообщениеДобавлено: 25 апр 2020, 08:12
Possible you doesn't have enable voltage on it LDO. Can you look and write pinout/voltages for this IC?
p.s. board on photos have a lot of places with serious corrosion defects - maybe some traces/components is damaged?
СообщениеДобавлено: 26 апр 2020, 06:39
follows the tensions found the black ones are the ones in the regulator, the yellow ones are the ones that should be (compared to another similar board)
СообщениеДобавлено: 26 апр 2020, 07:09
Friend, this IC is not 1.8V creator. Look and measure other voltages from selected ICs (on attached images).
СообщениеДобавлено: 27 апр 2020, 03:20
dennis85 писал(а):
Amigo, este IC não é criador de 1.8V. Procure e meça outras tensões dos CIs selecionados (nas imagens anexas).
you are right, I calmly analyzed the pcb and saw that there was no enable on the uP1727, so it replaces the resistor marked red because when I obese on the other board and then comes the enable for the Regulated, and then the enable and all the other board voltages went up, but it didn’t show video, I believe there is a defect in the memories or the gpu.
is it possible to use mats on vgas that do not output video?
СообщениеДобавлено: 27 апр 2020, 03:28
Firstly look on VGA bios for compatible with your board. Mats easy can use as second vga on MB.
В этой теме нет новых непрочитанных сообщений. страпы 1050 ti zotac mini
gagat222
849
01 окт 2022, 19:34
В этой теме нет новых непрочитанных сообщений. Zotac GTX1050 2GB DDR5 mini опознать елемент
ИвановИг
01 дек 2018, 23:14
nazikos999 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. help for asus x552e (help for asus x552e) help
serwanjaf7
05 авг 2016, 18:08
serwanjaf7 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Help help Help memory samsung detect micron (domate)
PT-AH
02 ноя 2022, 14:43
PT-AH Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Zotac gtx 1070 Ti Mini Help No display Indentification Elemen
dani82
1140
19 янв 2022, 16:24
Pandemonium6 Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 94
