Текущее время: 22 ноя 2024, 15:05
TheMArcos
Заголовок сообщения: Re: Zotac 1050 2gb mini - help finding 1.8V bios Добавлено: 25 апр 2020, 07:07 |
Зарегистрирован: 18 мар 2020, 04:02 Наличности на руках: 21.68
Сообщения: 184 Откуда: Brasil
dennis85 писал(а): Can you remove 1.8V regulator and provide 1.8V/0.2A from laboratory power supply in to 4-8pin SPI flash(without any other supplies)? What a current consumption will be? hi,sorry for the delay, is that i can only work on cards 22:00 ~ 01: 00am brasilia time, i removed the regulator and injected 1.8v the consumption current was 0.500mA on pin 8, is this normal?
dennis85
Заголовок сообщения: Re: Zotac 1050 2gb mini - help finding 1.8V bios Добавлено: 25 апр 2020, 07:31 |
Зарегистрирован: 20 сен 2012, 23:43 Наличности на руках: 796.60
Сообщения: 412 Откуда: Ukraine
TheMArcos писал(а): i removed the regulator and injected 1.8v the consumption current was 0.500mA on pin 8, is this normal? If 0.5mA(NOT "0.5A", like a 500mA) - normal. But why your linear regulator U504 doesn't give 1.8V(maybe it broken)? "Z08N" - that marking chip was on board from manufacture? Can't find information for that chip.
_________________ Главный враг истины не отсутствие знания, а иллюзия знания.
TheMArcos
Заголовок сообщения: Re: Zotac 1050 2gb mini - help finding 1.8V bios Добавлено: 27 апр 2020, 03:20 |
dennis85 писал(а): Amigo, este IC não é criador de 1.8V. Procure e meça outras tensões dos CIs selecionados (nas imagens anexas). you are right, I calmly analyzed the pcb and saw that there was no enable on the uP1727, so it replaces the resistor marked red because when I obese on the other board and then comes the enable for the Regulated, and then the enable and all the other board voltages went up, but it didn’t show video, I believe there is a defect in the memories or the gpu. is it possible to use mats on vgas that do not output video?
