aleksrosYes in English would be much easier for me but i don't think it will be fair for this forums users.. as its Russian language forum.. i can speak and read in Russian just to write is a bit difficult.. it takes longer..
OK coming back to my problem with this card's LED's i think there is some problem with controller.. it does not functioning properly i think.. checked back plates LED's are working.. swapped them around and only first 4 working.. after forth one signal mystically disappears.. :) also blyn :) 2 broke and one lost in a process.. so would be nice if any one knows marking of these damn LED's what MSI uses :) i found few similar looking but want to be sure before buying..
So another strange observation is when in Mystic lights options change LED's to follow Top part of Card light should go from one side till end and disappear and again start from beginning.. but light come's back from end for few cm almost exactly the distance whats missing and not working on back plate..
probably would be best to do video but its the best what could do with photos..
That's why i assuming this is controllers fault.. as i mentioned before i found flux left overs around it, so would be logical tu presume it was messed up some how.
