Текущее время: 22 ноя 2024, 16:31
ilie321
Заголовок сообщения: Msi armor gtx 1060 help Добавлено: 23 май 2020, 19:06 |
Зарегистрирован: 27 фев 2020, 13:07 Наличности на руках: 277.77
Сообщения: 299 Откуда: romania
Hello i have a gtx1060 armor v328 v6.1 with problems. First there is no memory voltage. I changed the driver uP1537 because i had few ohms on the gate of upper mosfet( mosfet ok) . Still no voltage but the area from picture is getting veeery hot. Any suggestions? Anyone has the schematic please?please please Resistance on memory 40ohms!!! . All other voltages are ok. Вложение: 20200523_180201.jpg
men2k1
Заголовок сообщения: Re: Msi armor gtx 1060 help Добавлено: 23 май 2020, 19:55 |
Зарегистрирован: 28 июл 2019, 08:05 Наличности на руках: 193.41
Сообщения: 166 Откуда: Ю-С
ilie321 писал(а): Still no voltage but the area from picture is getting veeery hot. Is a hot element detected by a finger?
men2k1
Заголовок сообщения: Re: Msi armor gtx 1060 help Добавлено: 23 май 2020, 21:15 |
ilie321 писал(а): Yes all those tranzistors seams too hot to touch Check out hot items outside psb
men2k1
Заголовок сообщения: Re: Msi armor gtx 1060 help Добавлено: 23 май 2020, 21:23 |
ilie321 писал(а): Yes all those tranzistors seams too hot to touch Remove the hot transistors from the board (psb) and check them with a multimeter. I can’t write more clearly.
ilie321
Заголовок сообщения: Re: Msi armor gtx 1060 help Добавлено: 24 май 2020, 13:14 |
Ok the component that is going too hot is the 7002k smd from the picture. i changed it with same type but still same problem hot again. Im lost in pcb trying to understand the logic without schematic grrr. Вложение: 20200524_121221.jpg Posted after 3 hours 14 minutes 48 seconds:That 2ng37 or 2n636 from picture anyone knows what it is?
men2k1
Заголовок сообщения: Re: Msi armor gtx 1060 help Добавлено: 24 май 2020, 17:47 |
ilie321 писал(а): That 2ng37 or 2n636 from picture anyone knows what it is? aleksros писал(а): it is 2n7002, n-mosfet
ilie321
Заголовок сообщения: Re: Msi armor gtx 1060 help Добавлено: 25 май 2020, 12:05 |
Вложение: 20200525_110350.png 3.3v after is from some power supply? I got 0 there but resistence is 470ohms Вложение: 20200525_113641.jpg
ilie321
Заголовок сообщения: Re: Msi armor gtx 1060 help Добавлено: 25 май 2020, 13:22 |
aleksros писал(а): check q530, q4705, q9 Check email please All 3 seams ok same readings on all no short Any ideea if on gate of Q31 we need to have some voltage or 0V if 1.8v is ok? I have 0 and 1.8v is present What value has R609? Thanks
aleksros
Заголовок сообщения: Re: Msi armor gtx 1060 help Добавлено: 25 май 2020, 14:58 |
Зарегистрирован: 26 ноя 2011, 01:09 Наличности на руках: 1,839.25
Сообщения: 4472 Откуда: Киев
r609 - 100k. ilie321 писал(а): gate of Q31 we need to have some voltage or 0V if 1.8v is ok? it's ok
men2k1
Заголовок сообщения: Re: Msi armor gtx 1060 help Добавлено: 25 май 2020, 15:57 |
ilie321 писал(а): Q31 was faulty with code LP code LP = DRA2144T - DRA5144T
