Текущее время: 22 ноя 2024, 16:33
 Страница 1 из 1 [ Сообщений: 19 ]
 Заголовок сообщения: Msi armor gtx 1060 help
СообщениеДобавлено: 23 май 2020, 19:06
Hello i have a gtx1060 armor v328 v6.1 with problems.
First there is no memory voltage. I changed the driver uP1537 because i had few ohms on the gate of upper mosfet( mosfet ok) .
Still no voltage but the area from picture is getting veeery hot.
Any suggestions?
Anyone has the schematic please?please please
Resistance on memory 40ohms!!! . All other voltages are ok.
 Заголовок сообщения: Re: Msi armor gtx 1060 help
СообщениеДобавлено: 23 май 2020, 19:55
Is a hot element detected by a finger?
СообщениеДобавлено: 23 май 2020, 20:07
Yes all those tranzistors seams too hot to touch
СообщениеДобавлено: 23 май 2020, 21:15
Check out hot items outside psb
СообщениеДобавлено: 23 май 2020, 21:18
I don't understand
СообщениеДобавлено: 23 май 2020, 21:23
Remove the hot transistors from the board (psb) and check them with a multimeter. I can’t write more clearly.
СообщениеДобавлено: 23 май 2020, 21:35
Ok thanks
СообщениеДобавлено: 23 май 2020, 22:32
You can also use receipt paper to see what component is hot. Put receipt paper on top of that area and hold with finger. You will see what location changes colour.
СообщениеДобавлено: 24 май 2020, 13:14
Ok the component that is going too hot is the 7002k smd from the picture. i changed it with same type but still same problem hot again. Im lost in pcb trying to understand the logic without schematic grrr.
Posted after 3 hours 14 minutes 48 seconds:
That 2ng37 or 2n636 from picture anyone knows what it is?
СообщениеДобавлено: 24 май 2020, 17:34
it is 2n7002, n-mosfet
check your email
СообщениеДобавлено: 24 май 2020, 17:47
СообщениеДобавлено: 25 май 2020, 12:05
3.3v after is from some power supply? I got 0 there but resistence is 470ohms
СообщениеДобавлено: 25 май 2020, 12:57
check q530, q4705, q9
СообщениеДобавлено: 25 май 2020, 13:22
Check email please
All 3 seams ok same readings on all no short
Any ideea if on gate of Q31 we need to have some voltage or 0V if 1.8v is ok? I have 0 and 1.8v is present
What value has R609? Thanks
СообщениеДобавлено: 25 май 2020, 14:58
r609 - 100k.
it's ok
СообщениеДобавлено: 25 май 2020, 15:45
Q31 was faulty with code LP. I changed it and now i have all voltages but no image. vram 1.410v! . Pcie led rest red and gpu is getting slightly hot only
Последний раз редактировалось ilie321 25 май 2020, 16:01, всего редактировалось 2 раз(а).
СообщениеДобавлено: 25 май 2020, 15:57
code LP = DRA2144T - DRA5144T
СообщениеДобавлено: 26 май 2020, 11:36
thanks to all for great help especially to aleksros
(i'm a beginner and this is a hobby for me)
results of this trying to fix= the gpu seams dead:
all voltages are ok
all resistances seams good except gpu (<0.5ohms!!!) 0.866V ;
board is not detected at all;
pcie red led rest on;
no black screen or anything;
gpu is getting only worm not hot at touch;
pcie lines seams ok
osc 27mhz ok
1.8v on bios chip ok
no physical damage found
in windows with other good card no detection
СообщениеДобавлено: 19 июн 2020, 18:48
ilie321, рlease checkmark "resolved".
В этой теме нет новых непрочитанных сообщений. MSI Geforce GTX 1060 armor 3G OCV1 номиналы и фото
madiyarmw
2640
04 дек 2020, 14:04
trahtenberg Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Маркировка чипа bios MSI GTX 1060 3G armor.
binaver
29 мар 2019, 21:35
В этой теме нет новых непрочитанных сообщений. GTX 1060 MSI Armor. Помогите подобрать замену мосфету M3106M
Домосед
25
5749
22 июн 2021, 20:14
3Tonus Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. GTX 1060 6G MSI Armor. Нет изображения
Домосед
2523
14 май 2020, 09:02
Домосед Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. MSI gtx 1060 armor 6g нет пит Гпу памяти и pci
den0222
21
4118
10 июн 2020, 12:43
vitok70 Перейти к последнему сообщению
Сейчас этот форум просматривают: bantlie, dikabraz, klasser, Омез, Shalun-avd, vit007 и гости: 92
