Текущее время: 17 ноя 2026, 07:46
| Автор |
TheMArcos
Заголовок сообщения: MSI RX570 ARMOR -  Добавлено: 14 сен 2020, 22:19 |
| Интересующийся |
Зарегистрирован: 18 мар 2020, 03:02 Наличности на руках: 21.68
Сообщения: 184 Откуда: Brasil
hello, I have a msi armor that does not show the video, however and recognized by gpuz as the photo, already replaces the gpu with a known that is functional. the plate was not used for mining. what should i check? memory? thank you.
MoneyBot
Заголовок сообщения: MSI RX570 ARMOR - |
MoneyBot
pEEp
Заголовок сообщения: Re: MSI RX570 ARMOR -  Добавлено: 14 сен 2020, 23:27 |
| Продвинутый форумчанин |
Зарегистрирован: 25 сен 2018, 19:41 Наличности на руках: 640.36
Сообщения: 1115 Откуда: Севастополь
TheMArcos писал(а): what should i check? memory? Exactly! Memory type = Micron Memory size = 0MBThis is a direct clue: memory is "tired"
TheMArcos
Заголовок сообщения: Re: MSI RX570 ARMOR -  Добавлено: 14 сен 2020, 23:32 |
| Интересующийся |
pEEp писал(а): Posted: 4 minutes ago TheMArcos wrote: what should i check? memory?
Exactly! Memory type = Micron Memory size = 0MB This is a direct clue: memory is "tired" thanks for the tip, in this case, the best way to solve it is to go replacing one by one? for example, replace one and check the gpu z?
pEEp
Заголовок сообщения: Re: MSI RX570 ARMOR -  Добавлено: 14 сен 2020, 23:40 |
TheMArcos писал(а): replace one and check the gpu z? The easiest (but longest) way is to transplant all the memory from donor. Because, there is no explicit way to find a faulty memory module (for radeon) without image on the monitor.
TheMArcos
Заголовок сообщения: Re: MSI RX570 ARMOR -  Добавлено: 17 сен 2020, 00:27 |
| Интересующийся |
pEEp писал(а): A similar situation on RX488 - BIOS (1) 2.7V, BIOS is silent. I think - GPU, I have no solution. I replaced the GPU and nothing happened, what a strange situation?
