Текущее время: 18 ноя 2026, 08:57
 Заголовок сообщения: MSI RX570 ARMOR -
СообщениеДобавлено: 14 сен 2020, 22:19
hello, I have a msi armor that does not show the video, however and recognized by gpuz as the photo, already replaces the gpu with a known that is functional.
the plate was not used for mining. what should i check? memory?
thank you.
 Заголовок сообщения: Re: MSI RX570 ARMOR -
СообщениеДобавлено: 14 сен 2020, 23:27
Exactly!
Memory type = Micron
Memory size = 0MB
This is a direct clue: memory is "tired"
СообщениеДобавлено: 14 сен 2020, 23:32
pEEp писал(а):
Posted: 4 minutes ago
Exactly!
Memory size = 0MB
thanks for the tip, in this case, the best way to solve it is to go replacing one by one?
for example, replace one and check the gpu z?
СообщениеДобавлено: 14 сен 2020, 23:40
The easiest (but longest) way is to transplant all the memory from donor. Because, there is no explicit way to find a faulty memory module (for radeon) without image on the monitor.
СообщениеДобавлено: 16 сен 2020, 21:35
Hi, I started replacing the memories in a counterclockwise direction, but when replacing the first the card is no longer recognized in the device manager, I noticed that on pin 1 of the vbios where it should have 3.3v it has only 2.7v. i thought the gpu could have been damaged, but when replacing with another gpu the same 2.7v situation continued on pin 1 of ci Bios.
has anyone been there, do you have any idea what may be happening?
СообщениеДобавлено: 16 сен 2020, 22:01
A similar situation on RX488 - BIOS (1) 2.7V, BIOS is silent. I think - GPU, I have no solution.
СообщениеДобавлено: 17 сен 2020, 00:27
I replaced the GPU and nothing happened, what a strange situation? :nez-nayu:
СообщениеДобавлено: 17 сен 2020, 00:45
Try to replace second memory bank, nearest with first one (replace memory channel - 2 banks)
СообщениеДобавлено: 17 сен 2020, 01:15
a detail when removing the GPU and energizing the card I have 3.3v on pin 1 of the ci of bios
Posted after 4 hours 18 minutes 14 seconds:
another card with memories now, must you understand the same way? is it initially a memory problem?
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Греется и отключается MSI Radeon RX570 Armor 8Gb
Sergey183
26
9727
05 ноя 2020, 08:03
Sergey183 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. MSI Armor RX570 4GB замена памяти
coolcat
3222
25 янв 2021, 13:17
coolcat Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. MSI RX570 Armor - падает VDDCI
pEEp
3973
04 ноя 2021, 01:07
pEEp Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. msi rx570 armor 4gb
amkwca
27 дек 2021, 00:42
amkwca Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MSI RX570 8GB ARMOR (v341 ver 2.2) нужно фото платы с двух сторон
nikolay26rus
23 дек 2021, 21:37
Сейчас этот форум просматривают: Aleksdmitr, KrivorukiiLentyai, Sergach, soft89 и гости: 48
