Текущее время: 01 июл 2024, 05:39
uncledim
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 02 дек 2020, 15:30 |
Зарегистрирован: 22 дек 2016, 12:07 Наличности на руках: 1,135.36 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 1102 Откуда: Moscow
ilie321 писал(а): If driver it is loaded ok (good card) you can't test with dmgg but after running "memfa" it becomes possible to test with dmgg. "lspci" output differs before and after memfa test - attribute "disabled" disappears and vram window seems become accessible.
darker123
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 03 дек 2020, 03:15 |
Зарегистрирован: 20 окт 2020, 04:48 Наличности на руках: 92.12 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 44 Откуда: Molddova
Вложение: Capture.PNG I want to report my results with the latest dmgg script. I have received a card Power Color RX 580 8GB. When card is installed as primary display it displayed no video. If booted to windows as secondary adapter, it showed error 43 on the card... I have ran it thru dmgg under Linux latest script, see results attached. It reported memory chip 3 & 4 with errors. What i next is heated these 2 modules on soldering station and floated them on balls. After that I ran script again with 0 errors. Since I didn't remove the modules I can't tell unfortunately which module was originally defective 3 or 4. In any case thank you for the script the latest improvements are great!@
westcoast
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 04 дек 2020, 21:39 |
Зарегистрирован: 01 окт 2020, 02:15 Наличности на руках: 127.19 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 159 Откуда: europe
darker123 писал(а): I have ran it thru dmgg under Linux latest script, see results attached. It reported memory chip 3 & 4 with errors. What i next is heated these 2 modules on soldering station and floated them on balls. After that I ran script again with 0 errors. do you think the heating fixed the defect inside actual chip, or there was bad BGA contact/short between balls?
uncledim
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 05 дек 2020, 17:48 |
anton127 писал(а): Там, где MEMFA показывает ошибки по 1 каналу, DMGG показывает всё хорошо. а первый этап memfa что показывает? они по виду вроде одинаковые с dmgg
obli
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 05 дек 2020, 21:49 |
Зарегистрирован: 24 дек 2016, 04:53 Наличности на руках: 34.26 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 74 Откуда: moscow
Подскажите сегодня решил потестировать жутко артефактную карту, картинка ток в биосе , посе загрузки любой ос черный экран (дос не пробовал) после загрузки со встроенной карточке , с usb1804v2.pmf ,выдает Possible gpu address <unassigned> lspci -v выдало Вложение: 20201205_124640.jpg я так понимаю что gpu капут ? Или вся память ?
anton127
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 06 дек 2020, 05:50 |
Зарегистрирован: 29 июн 2018, 10:00 Наличности на руках: 450.22 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 370 Откуда: Урал
uncledimДа, там 2 теста проходит. На первом ошибок нет, на втором по одной банке. Банка перекатана - карта работает. ---------- Добавлено спустя 2 минуты: ---------- obli писал(а): Или вся память ? А что там с питанием памяти??
ilie321
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 06 дек 2020, 18:08 |
![Аватара пользователя](./download/file.php?avatar=110596_1583820810.jpg) |
Зарегистрирован: 27 фев 2020, 13:07 Наличности на руках: 305.76 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 297 Откуда: romania
uncledim писал(а): According to the chinese pdf it is abcd: Вложение: Screenshot_20201205-175906_Opera.jpg And i tested that with gas_man. Tserver give A1 and dmgg chip2. If it is abcd A1 =chip2. He just reball chip2 and card it is working now I have limit to 256MB because when driver fails only 256mb are loaded and if you put more it is stuck in loop and need hard reset . If the card it is good than yes you can test all memory but for that you have windows tools much better. But if is needed i can remove this or anyone can search in script and replace 256 with 10000 for example
uncledim
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 06 дек 2020, 18:30 |
ilie321 писал(а): According to the chinese pdf it is abcd: I see. IMHO rather an error in pdf's picture, than in tservertserver outputs lines in chip's physical (edited:) logical order, but named them by channels: ChB0, ChB1, ChA0, ChA1, ChC0, ChC1, ChD0, ChD1
Последний раз редактировалось uncledim 06 дек 2020, 21:10, всего редактировалось 1 раз.
uncledim
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 06 дек 2020, 21:12 |
aleksros писал(а): There is no mistake. ошибка у меня), в терминах заплутал tserver выводит в логическом, не физическом порядке. т.е. в порядке возрастания адресов (он же порядок отображения на дисплее) тогда всё сходится, никаких противоречий ща поправлю пред. пост
darker123
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 07 дек 2020, 19:11 |
westcoast писал(а): do you think the heating fixed the defect inside actual chip, or there was bad BGA contact/short between balls?
I do not believe direct heating fixed the defect inside the chip, I believe it was a bad BGA contact under the chip. The card was cheap and didn't have any thermal pads or heatsink on top of it. ---------- Добавлено спустя 1 час 37 минут 2 секунды: ---------- Кто нибудь видел такую проблему чтобы артефакты на экране были на пол канала на каждом канале??? карта XFX RX 580 GTS 8gb
galkinvv
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 07 дек 2020, 23:10 |
Зарегистрирован: 09 янв 2017, 12:18 Наличности на руках: 240.39 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 651 Откуда: Зеленоград
darker123 писал(а): Кто нибудь видел такую проблему чтобы артефакты на экране были на пол канала на каждом канале??? Какое разрешение передаётся с видяхи на моник у монитора в момент когда сделано фото? На AMD до активации ускорения драйвера - каждая микросхема памяти обслуживает 64 вертикальных линии, соответственно каждый канал - 128 вертикальных линий. После активации - разбиение уже идёт не по линиям, а по квадратам. Каждая микросххема памяти начинает осблуживать свой набор квадратиков 8x8.
darker123
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 08 дек 2020, 02:54 |
galkinvv писал(а): Какое разрешение передаётся с видяхи на моник у монитора в момент когда сделано фото? Pазрешение с видяхи на моник 1080P.. Что Это MoжeT быть? Memory или GPU?
uncledim
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 08 дек 2020, 09:20 |
darker123 писал(а): 1080P. а выглядит как 2560х1440 с отвалом в канале А что говорит dmgg? (только возьмите свежий, с конца 13й страницы темы)
