Текущее время: 02 ноя 2026, 15:42
 Заголовок сообщения: HP EliteDesk 600 G2 Bios Pass
СообщениеДобавлено: 07 апр 2021, 16:38
hi guys
i have a board with bios password
i tried dump files that i found in forum but doesn't boot with those files
its my locked file
Вложение:
MX25L12805D @ SOP16_20210406_180312 read bios pass.rar
 Заголовок сообщения: Re: HP EliteDesk 600 G2 Bios Pass
СообщениеДобавлено: 07 апр 2021, 17:10
Try . . .
СообщениеДобавлено: 08 апр 2021, 10:17
Sergej писал(а):
Try.
thanks alot
it worked
can you help me to learn allitle more?
i compared two files and find different here
Вложение:
how you find where to clear?
and system doesn't accept "AdminPW" or "Admin" as password
how password store in bios?
СообщениеДобавлено: 08 апр 2021, 10:26
look PM
СообщениеДобавлено: 08 апр 2021, 10:41
Sergej писал(а):
look PM
thank you
СообщениеДобавлено: 08 апр 2021, 19:38
my problem solved by your help
but now i have another problem
i can't flash this file on other same board
if i read and unlock with HP Unlocker it worked
but if i flash unlocked file from system A on system B it doesn't work
i tried to make a Clean ME file and try but it doesn't help
how can i make a file that work on any hp 600 g2 board?
СообщениеДобавлено: 09 апр 2021, 16:00
string ADMIN PW is a marker which you should search and do that Sergej did
The password stored as a hash and the enrolled flag (which tells bios password is on) The real password will have never been known by you.
And if HDD is locked by this password - you need a new one hdd.
Clean ME is a must thing.
system A and B have differend DMI - keep in mind.
-приворот winDOвSa
-розыгрыш автоБАНа
СообщениеДобавлено: 10 июн 2021, 10:58
i tried different ME files but doesn't work
can you kame me a clean ME and DMI file please ?
or send me a link about how should i do
thanks
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP EliteDesk 800 G3 (HP EliteDesk 800 G3 ) пароль BIOS
AndreyVl96
14264
24 авг 2021, 14:27
AndreyVl96 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. HP EliteDesk 600 G2 mini не включается
в форуме HP
Mobiua
394
24 апр 2026, 13:55
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Fujitsu (S792) BIOS pass
в форуме Fujitsu-Siemens
Dwit
17
6576
09 мар 2017, 21:01
Dwit Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. DELL E4300 (COMPAL) BIOS PASS
в форуме Dell
stas707
3131
13 мар 2018, 21:38
stas707 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. L460 (NM-A651) Bios Pass
в форуме Поиск BIOS
R EZ A
1753
23 окт 2026, 11:03
polivanov Перейти к последнему сообщению
