Текущее время: 02 июн 2024, 18:02
 Заголовок сообщения: HP EliteDesk 600 G2 Bios Pass
СообщениеДобавлено: 07 апр 2021, 17:38
hi guys
i have a board with bios password
i tried dump files that i found in forum but doesn't boot with those files
its my locked file
MX25L12805D @ SOP16_20210406_180312 read bios pass.rar
 Заголовок сообщения: Re: HP EliteDesk 600 G2 Bios Pass
СообщениеДобавлено: 07 апр 2021, 18:10
Try . . .
СообщениеДобавлено: 08 апр 2021, 11:17
Sergej писал(а):
Try.
thanks alot
it worked
can you help me to learn allitle more?
i compared two files and find different here
how you find where to clear?
and system doesn't accept "AdminPW" or "Admin" as password
how password store in bios?
СообщениеДобавлено: 08 апр 2021, 11:26
look PM
СообщениеДобавлено: 08 апр 2021, 11:41
Sergej писал(а):
look PM
thank you
СообщениеДобавлено: 08 апр 2021, 20:38
my problem solved by your help
but now i have another problem
i can't flash this file on other same board
if i read and unlock with HP Unlocker it worked
but if i flash unlocked file from system A on system B it doesn't work
i tried to make a Clean ME file and try but it doesn't help
how can i make a file that work on any hp 600 g2 board?
СообщениеДобавлено: 09 апр 2021, 17:00
string ADMIN PW is a marker which you should search and do that Sergej did
The password stored as a hash and the enrolled flag (which tells bios password is on) The real password will have never been known by you.
And if HDD is locked by this password - you need a new one hdd.
Clean ME is a must thing.
system A and B have differend DMI - keep in mind.
-приворот winDOвSa
-розыгрыш автоБАНа
СообщениеДобавлено: 10 июн 2021, 11:58
i tried different ME files but doesn't work
can you kame me a clean ME and DMI file please ?
or send me a link about how should i do
thanks
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP EliteDesk 800 G3 (HP EliteDesk 800 G3 ) пароль BIOS
AndreyVl96
10716
24 авг 2021, 15:27
AndreyVl96 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP Elitebook 8470p bios password remove (HP Elitebook 8470p bios password remove) HP Elitebook 8470p bios pass
zenelli
02 ноя 2014, 18:22
montarbo Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Fujitsu (S792) BIOS pass
в форуме Fujitsu-Siemens
Dwit
17
4868
09 мар 2017, 22:01
Dwit Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. DELL E4300 (COMPAL) BIOS PASS
в форуме Dell
stas707
2214
13 мар 2018, 22:38
stas707 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. L460 (NM-A651) Bios Pass
в форуме Поиск BIOS
R EZ A
18 апр 2022, 14:54
EStebio Перейти к последнему сообщению
