Hi guys This laptop restart after the first loading of windows installations before "install windows" button and continues this problem This what I checked - Change ram -Bios update last version -heat the GPU -disconnect all unessery component -I tried with some another os
But no success Thanks in advance
Евгений18
Заголовок сообщения: Re: HP 15-ay014ne (Bdl50 la-d704p ) Reset while installing os
Добавлено: 19 апр 2021, 12:12
Зарегистрирован: 24 сен 2012, 11:42 Наличности на руках: 59.17 Сообщения: 811 Откуда: г. Москва
Are all the CPU phases working?
_________________ Не всегда говори то что знаешь, но всегда знай что говоришь.
nasser_pczone1
Joined: 24 Sep 2012, 11:42 Cash on hand: 711.03 [Donate] Posts: 771 Location: г. Москва Has thanked: 30 times Have thanks: 104 times Are all the CPU phases working?
Did you mean rhe pwm coil voltage? Yes that OK on about 1.2
Евгений18
Добавлено: 19 апр 2021, 13:17
Measure with an oscilloscope
nasser_pczone1
I just test the that 2 coil of pwm one of coil no voltage come out and another one has 0.9v I resold the ncp81206 but no help What I should to do Thanks in advance
nasser_pczone1
Сейчас этот форум просматривают: domenof, osip2 и гости: 41
