Текущее время: 28 июн 2024, 13:57
 Заголовок сообщения: Asus FX502V (Asus GL502VM) Keyboard
СообщениеДобавлено: 14 май 2021, 15:19
Hi guys!
The keyboard is not working. The customer tried other keyboard, too.
I checked +5VS -> OK and also flashed IO firmware with Vertyanov. Still the keyboard does not work.
No shorts measured on KBD connector pins.
Please advise!
BR,
Giorgo
 Заголовок сообщения: Re: Asus FX502V (Asus GL502VM) Keyboard
СообщениеДобавлено: 15 май 2021, 12:37
KBC, firmware. If there is a keyboard controller, then the matter may be in it or in its firmware
СообщениеДобавлено: 15 май 2021, 15:45
Hi there! Does this laptop have a power button on the keyboard? Perhaps the new keyboard is defective. Try another keyboard :-):
СообщениеДобавлено: 15 май 2021, 16:07
Check the VCC on IT8171FN-56, SM and USB data lines, resistors and etc.
СообщениеДобавлено: 17 май 2021, 16:07
this motherboard has two controllers. Vertyanov targets the 128kb (IT8995VG) and read/write is successful. How can I use Vertyanov for IT8171FN-56?
some solution is here but still does not explain how to write IT8171FN-56.
https://www.badcaps.net/forum/showthrea ... ost1046377
maybe we can help more people with this solution. thank you for your precious time.
СообщениеДобавлено: 19 май 2021, 15:53
f-bone
j3101 only for 8171
for 8995 need use JDEBUG2
What plug (connector) and what did you program?
Программатор SUCCESSOR/JIG V2/3.
Пост карты DDR234/NGFF_GoWin/KFCT_BIG
СообщениеДобавлено: 19 май 2021, 17:06
Did you try https://dlcdnets.asus.com/pub/ASUS/nb/G ... ER1030.zip
? It's kb adjustment tool for this model. If it wont work, extract FW_NK0003000B with 7zip and flash thru vertianov.
pins:
KB_pins=30 LEFT DOWN FLASH=56 PD0=29 PD1=20 PD2=15 PD3=23 PD4=14 PD5=16 PD6=12 PD7=30 BUSY=26 STB=18 AFD=28 INIT=21 SLIN=19 KSI4=22 KSI5=24
СообщениеДобавлено: 24 май 2021, 14:23
thank you both for your replies. I am obliged.
so far I flashed 128kb file through keyboard connector J3101 which is wrong yes?? I must flash 56K file using the J3101 keyboard connector?
Today I will try the program first and then check again with Vertyanov.
I also do not know how to use jdebug2 connector for 8995... much of a noob me.
СообщениеДобавлено: 24 май 2021, 14:59
Yep. Flash it to 8171 through J3101.
KBC_Firmware 3008B.rar
You no need to flash 8995 yet.
СообщениеДобавлено: 24 май 2021, 18:58
I tried the software but says no compatible device found "Searching USB device, Not found, Retry"
I will now use Vertyanov but:
the FW_NK0003000B firmware is 56kb and the file you attached is 2.5MB... what should I flash through J3101?
СообщениеДобавлено: 25 май 2021, 11:24
ok I found a problem!
I flash the 56K file FW_NK0003000B to IT8171 but the EC rom does not write the data. When I read back its empty! And of course Vertyanov says "Data is not the same" when verifying.
BUT the IT8171 is detected properly by Vertyanov. Is IT8171 damaged??
I use this setting:
GL502VM KB_pins=30 LEFT DOWN FLASH=56 PD0=29 PD1=20 PD2=15 PD3=23 PD4=14 PD5=16 PD6=12 PD7=30 BUSY=26 STB=18 AFD=28 INIT=21 SLIN=19 KSI4=22 KSI5=24
СообщениеДобавлено: 31 май 2021, 14:10
I am sorry to be persistent I need the guru help regarding this issue... the chip is DETECTED and PROGRAMMED by Vertyanov but it stays EMPTY?
any experience how is this possible? dead IT8171? some other issue?
please share your ideas.
В этой теме нет новых непрочитанных сообщений. Asus FX502V ( (Asus GL502VM)) проблемы с изображением
IG67
06 сен 2022, 10:48
neo26rus Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus fx502v-dm549t (gl502vm-rev2.1) Нужен дамп биоса
sergeyklimanov1@gmail.com
3074
28 май 2018, 22:52
sergeyklimanov1@gmail.com Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Asus FX502V (GL502VM rev2.1) залитик не заряжется, после чего перестал включаться
AlexWilson
2170
21 сен 2018, 15:20
AlexWilson Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. FX502V (GL502VM) Нет картинки
gaijine
1498
19 фев 2020, 11:01
AndreyZagr Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. FX502V (GL502VM REV.2.1. (на стикере GL502VMZ)) Включается и выключается
Алексей
17 дек 2020, 23:23
Lev_Grishenin Перейти к последнему сообщению
Сейчас этот форум просматривают: GoGo.Ru [Bot], sasha_m, tro9nius, user54321, Джамбулец72 и гости: 88
cron
