Зарегистрирован: 13 дек 2012, 12:00 Наличности на руках: 46.01 Сообщения: 12 Откуда: UK
You may be able to extract it from the BIOS Update installer. I did that for my fujitsu laptop and edited it using phoenix bios. I don't know what type of bios you have though.
Зарегистрирован: 29 ноя 2012, 22:23 Наличности на руках: 0.01 Сообщения: 172 Откуда: Kenya
I was able to extract, but the issue is where to split the 4608KB file to be able to obtain the 4096KB main bios and 512KB display bios ? Regards.
Зарегистрирован: 15 ноя 2012, 12:33 Наличности на руках: 1,087.65 Сообщения: 335 Откуда: Israel
I was tied to simply split to 4096 main and the rest for EC bios, isn't work. I think you need to search bios dump for motherboard . It can be from other models. After you up the comp you can run the update software for specific model.
_________________ Where there is a will, there is a way
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 26
