Текущее время: 03 июл 2024, 05:14
Leha74
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 29 сен 2021, 11:36 |
Зарегистрирован: 15 мар 2021, 14:12 Наличности на руках: 64.43
Сообщения: 54 Откуда: Калининград
preex писал(а): Leha74 Is there a link for this test program? what motherboard are you using
I launch tserver and choose which tests I need ./tserver -boardtest=config -edcsord=vddc,vddci,sclk,mclk motherboard- Gigabite Z170HD3 По карте, дело было не в памяти, 3D тесты и игры вообще перестали запускаться, драйвер начал постоянно восстанавливаться, замена GPU решила проблему...
zoidberg
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 30 сен 2021, 02:40 |
Зарегистрирован: 15 июн 2016, 15:27 Наличности на руках: 68.20
Сообщения: 55 Откуда: Piter
Greetings. XFX Rx 470 8 Gb video card for repair after another service. The memory chips and the GPU itself were in flux. The card is being initialized.
ddmg was showing:
chip 3 and / or 4 is faulty at adress: 0 chip 1 and / or 2 is faulty at adress: 512 chip 5 and / or 6 is faulty at adress: 1024 chip 7 and / or 8 is faulty at adress: 1536
I removed the memory and GPU, cleaned the board, soldered obviously working memory and GPU chips, flash up the required BIOS. Connected to the stand from the IG, ddmg gives errors in all memory banks. In Windows, of course 43
swears in exactly the same way:
Measured: The resistances on the video card / voltages are all in absolute normal, let me remind you that the GPU and the memory were removed from the working donor. It seems that the harness does not give the go-ahead to the map, tell me, maybe someone has experience in such things, where to look. The logic also works, all
manyment
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 30 сен 2021, 07:25 |
Сообщения: 6 Откуда: Спб
Смотря какой тест ты скачал, тут многие тесты ведут себя странновато Скачал тут репак на 32 гига от Воробей https://drive.google.com/file/d/1C3Yl3b ... sp=sharingЗаметил одну особенность если запустить первым dmgg.py на заведомо исправной карте будет писать chip 3 and / or 4 is faulty at adress: 0 chip 1 and / or 2 is faulty at adress: 512 chip 5 and / or 6 is faulty at adress: 1024 chip 7 and / or 8 is faulty at adress: 1536 бла бла бла 4 чип не исправен Но если с этой же сборке запустить сначала tserver а потом dmgg.py то показывает что все гуд Также и на не исправной карте если запустить первым dmgg.py покажет chip 3 and / or 4 is faulty at adress: 0 chip 1 and / or 2 is faulty at adress: 512 chip 5 and / or 6 is faulty at adress: 1024 chip 7 and / or 8 is faulty at adress: 1536 бла бла бла 4 чип не исправен И опять же если запустить первым tserver а потом dmgg.py то уже показывает chip 1 and / or 2 is faulty at adress: 512 chip 5 and / or 6 is faulty at adress: 1024 chip 7 and / or 8 is faulty at adress: 1536 бла бла бла 3 чип не исправен
zoidberg
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 30 сен 2021, 08:24 |
manyment писал(а): Смотря какой тест ты скачал, тут многие тесты ведут себя странновато я использую проверенный
com77
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 30 сен 2021, 12:49 |
Зарегистрирован: 08 дек 2018, 13:28 Наличности на руках: 1,414.83
manyment писал(а): Заметил одну особенность если запустить первым dmgg.py на заведомо исправной карте будет писать dmgg.py - файл сюда выложите или скопируйте содержимое. Это питоновский скрипт, может там символ пропущен, запятая или еще чего...
uncledim
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 30 сен 2021, 12:52 |
Зарегистрирован: 22 дек 2016, 12:07 Наличности на руках: 1,135.36
Сообщения: 1102 Откуда: Moscow
com77 писал(а): Это питоновский скрипт сам скрипт не при чем, такое поведение именно на сборках с тсервером ---------- Добавлено спустя 2 минуты 16 секунд: ---------- (и автор скрипта, помнится, в своих сборках это фиксил)
com77
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 30 сен 2021, 12:59 |
uncledimuncledim писал(а): и автор скрипта, помнится, в своих сборках это фиксил Значит нужно сравнить 2 папочки и сам скрипт, и посмотреть чего не хватает в том что не "пофиксен" А не качать понапрасну по 60Гигов туда обратно... Из-за 3-х строчек кода. === Как работать с bash скриптами писал здесь: viewtopic.php?p=893592#p8935923 поста вниз, для тех кто совсем "не в теме" === Я так полагаю db32 в тсервере тестирует АМД-шный северный мост, pcie контроллер и т.д. и т.п У кого AM3 на руках(десктопы) ну и ноуты, могут попробовать...
manyment
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 30 сен 2021, 16:27 |
Воробей писал(а): Нормальная история, большая часть карт именно так и диагностируется. Я использую карточку Nvidia для проверки карточки AMD, чтобы Tserver не ругался. ибо если две карты амд, приходится: ./agt -i=1 -clkstatus ./tserver -d=1 -boardtest=memfa Конечно так работает, но лишние 5 символов вводить лень ---------- Добавлено спустя 56 минут 47 секунд: ---------- Обновил репак Tserver пофиксил размер, ибо получилось так, что не все флешки 32 гб на самом деле 32 гб. встает как на жесткий диск, так и на флешку, 32гб и более. Сборка эта, скрипты подпихивал разные у всех скриптов разное поведение до и после запуска Tserver
com77
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 30 сен 2021, 16:41 |
manyment писал(а): Сборка эта, скрипты подпихивал разные "Если машина не едет, стоит начать с проверки прокладки между рулем и сиденьем" Если вы никогда не пользовались Линуксом, на уровне продвинутого пользователя, то не стоит начинать это делать с этих тестов. Отдайте тому, кто умеет этим пользоваться. Вы же не ходите зубы к сантехнику лечить.
uncledim
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 30 сен 2021, 17:00 |
com77 писал(а): не стоит начинать это делать с этих тестов а почему собственно? если кроме этих тестов от линукса ничего более не нужно.
com77
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 02 окт 2021, 21:59 |
Zvik писал(а): Карта даёт картинку без артефактов, винду не грузит, чёрный экран Реболл гпу попробуйте)
Zvik
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 03 окт 2021, 03:20 |
Зарегистрирован: 10 июн 2017, 21:51 Наличности на руках: 661.31
Сообщения: 530 Откуда: Казань
Карта работала, грузила систему, крутила бублик до 65град, дальше происходил сбой, требовался реболл ГПУ, ГПУ поднял, поставил другой, на который я ранее сам же накатал шары. Результат выше. Биус не трогал, в безопасном режиме или без драйверов грузится, как только грузишься с драйверами, черный экран.
djigor3
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 07 окт 2021, 10:58 |
Зарегистрирован: 03 апр 2021, 01:22 Наличности на руках: 103.56
Сообщения: 78 Откуда: Брянск
Zvik писал(а): А 403.001 на частотах по умолчанию, 300мгц тоже зависает? Да, причем сразу. Или черный экран, или застывшая картинка с градацией, или застывшая артефачная картинка. Но в любом случае тест нисколько не идёт. ---------- Добавлено спустя 3 часа 7 минут 51 секунду: ---------- и в догонку вопрос... может такое быть из-за того, что память стоит чуть другая? изначально стояли 4 банки H5GC8H24MJR-R0C сейчас стоит 1 банка H5GC8H24 MJR-R0C и 3 банки H5GC8H24 AJR-R0C по этой таблице разницы не увидел
ilie321
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 07 окт 2021, 15:44 |
Зарегистрирован: 27 фев 2020, 13:07 Наличности на руках: 305.76
Сообщения: 297 Откуда: romania
zoidberg писал(а): ddmg was showing:
chip 3 and / or 4 is faulty at adress: 0 chip 1 and / or 2 is faulty at adress: 512 chip 5 and / or 6 is faulty at adress: 1024 chip 7 and / or 8 is faulty at adress: 1536 hello i think you are not using the last version of dmgg; there was a version with problems as this was work in progress at that time ; now dmgg it is dependent of agt file from tserver but if you wish it can be edited and made standalone script with some linux implementations that is able to detect the amd cards you wish to check ; i posted few pages in the back a 32GB version with all the tools nvidia and amd also some other peoples made and post their version in same topic here; try any it should work ok; start from current page and go back when searching here because we cant edit older posts and they keep sometime outdated information
kvn73
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 08 окт 2021, 11:05 |
Зарегистрирован: 02 апр 2021, 19:45 Наличности на руках: 86.04
Сообщения: 41 Откуда: Саранск
kvn73 писал(а): только 4 чипа получилось еще два восстановить, теперь 6 показывает рабочих, но объем чипов так и не показывает, версия тсервер 2.3.42.89 у Виктора 2.3.43... эту карту уже замучил, раз десять уже перекатывал банки чтобы добиться шести рабочих еще штук десять банок неизвестного состояния с доноров, сопротивление по шинам vddq-vssq 4-10 кОм vdd-vss 2-5 кОм падение напряжения на диодной прозвонке 0,53 и 0,34+- соответственно и почему то не разу тсервер не показал что одна банка исправна или нет в канале, сразу на весь канал -5555555 этож сколько комбинаций еще перепробовать? все линии к гпу вызванивал
djigor3
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 08 окт 2021, 19:41 |
djigor3 писал(а): А 403.001 на частотах по умолчанию, 300мгц тоже зависает?
сейчас стоит 1 банка H5GC8H24MJR-R0C и 3 банки H5GC8H24AJR-R0C
Вообщем изыскания закончились тем, что на модифицированном биосе от гигабайт майнит и эрго и классик, с разгонами и без... В винде 43 ошибка, хотя объем памяти показывает. На стоковой прошивке любого вендора Майнер сразу валится и в хэвос показывает объем памяти каке-то космические цыфры. Видимо КП отъехал? Не понятно. Хотя такое на двух картах - пробовал эту же память переставить на другую доску. Да, память ноутбучная, но не думаю что в этом есть какая-то разница - гддр он и в Африке гддр. Так ведь?
kvn73
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 13 окт 2021, 09:46 |
kvn73 писал(а): еще штук десять банок неизвестного состояния с доноров, сопротивление по шинам vddq-vssq 4-10 кОм vdd-vss 2-5 кОм падение напряжения на диодной прозвонке 0,53 и 0,34+- соответственно и почему то не разу тсервер не показал что одна банка исправна или нет в канале, сразу на весь канал -5555555 этож сколько комбинаций еще перепробовать? Пришли с али б/у чипы самсунг, к 6 хуниксам добавил 2 самсунг, карта завелась без ошибок и уже в работе. Сопротивления у самсунга vddq-vssq 39 кОм vdd-vss 0,3 кОм Хьюникс так и не понятно как по сопротивлению отбраковывать, и у рабочих и плохих сопротивления как выше написал, больше их не буду заказывать.
Gas_man
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 17 окт 2021, 20:38 |
Зарегистрирован: 31 янв 2019, 21:09 Наличности на руках: 390.39
Сообщения: 305 Откуда: Чебоксары
crocodile70 писал(а): тестить скриптом dmgg.py карты rx 6800 rx 5700 и подобные Как мне известно ili321 (автор скрипта) не проверял и не редактировал свой тест для таких карт. Иди по пути тестирования через TSERVER. - слышал 5700 и 5700 XT - тестировали с помощью Tserver
uncledim
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 17 окт 2021, 21:05 |
Gas_man писал(а): не проверял и не редактировал а и не надо) скрипт и нвидию оттестирует, если его на нее натравить Gas_man писал(а): Иди по пути тестирования через TSERVER так с него видимо и пришел) нерабочее оно, что в открытом доступе..
crocodile70
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 17 окт 2021, 23:26 |
Зарегистрирован: 31 май 2020, 23:55 Наличности на руках: 433.63
Сообщения: 632 Откуда: Украина Днепр
uncledim писал(а): так с него видимо и пришел) нерабочее оно, что в открытом доступе..
во во - тут делов то - у кого есть рабочая такая карточка - снять или отключить одну банку - и запустить дмгг - скинуть фото теста - потом можно и обсудить результаты ---------- Добавлено спустя 3 минуты 37 секунд: ---------- ну и затестить с под арча и с под хайвос
uncledim
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 18 окт 2021, 00:56 |
crocodile70 писал(а): снять или отключить одну банку "на это я пойтить не могу", но вот убунта 20.04.02 lts amdgpu 20.50 тест с подключенным к пациенту монитором (пришлось поподбирать начальный адрес) "артефакты" (т.е. тест явно получил доступ к видеопамяти) в наличии и те же 511 ошибок в итоге (ожидаемо) ---------- Добавлено спустя 13 минут 36 секунд: ---------- crocodile70 писал(а): фото от другого человека теста рабочей карточки 6700 ХТ другой человек это я, дратути)
