Текущее время: 03 июл 2024, 05:21
 Страница 38 из 56 [ Сообщений: 1661 ]  На страницу Пред.  1 ... 35, 36, 37, 38, 39, 40, 41 ... 56  След.
 Заголовок сообщения: Re: need some help for ati cards with memory errors for making script
СообщениеДобавлено: 29 сен 2021, 11:36
preex писал(а):
Leha74
Is there a link for this test program?
what motherboard are you using
I launch tserver and choose which tests I need ./tserver -boardtest=config -edcsord=vddc,vddci,sclk,mclk
motherboard- Gigabite Z170HD3
По карте, дело было не в памяти, 3D тесты и игры вообще перестали запускаться, драйвер начал постоянно восстанавливаться, замена GPU решила проблему...
СообщениеДобавлено: 30 сен 2021, 02:40
Greetings. XFX Rx 470 8 Gb video card for repair after another service.
The memory chips and the GPU itself were in flux. The card is being initialized.
ddmg was showing:
chip 3 and / or 4 is faulty at adress: 0
chip 1 and / or 2 is faulty at adress: 512
chip 5 and / or 6 is faulty at adress: 1024
chip 7 and / or 8 is faulty at adress: 1536
I removed the memory and GPU, cleaned the board, soldered obviously working memory and GPU chips, flash up the required BIOS.
Connected to the stand from the IG, ddmg gives errors in all memory banks. In Windows, of course 43
swears in exactly the same way:
Measured:
The resistances on the video card / voltages are all in absolute normal, let me remind you that the GPU and the memory were removed from the working donor. It seems that the harness does not give the go-ahead to the map, tell me, maybe someone has experience in such things, where to look. The logic also works, all
СообщениеДобавлено: 30 сен 2021, 07:25
Смотря какой тест ты скачал, тут многие тесты ведут себя странновато
Скачал тут репак на 32 гига от Воробей
https://drive.google.com/file/d/1C3Yl3b ... sp=sharing
Заметил одну особенность если запустить первым dmgg.py на заведомо исправной карте будет писать
бла бла бла 4 чип не исправен
Но если с этой же сборке запустить сначала tserver а потом dmgg.py то показывает что все гуд
Также и на не исправной карте если запустить первым dmgg.py покажет
И опять же если запустить первым tserver а потом dmgg.py то уже показывает
бла бла бла 3 чип не исправен
СообщениеДобавлено: 30 сен 2021, 08:24
я использую проверенный
СообщениеДобавлено: 30 сен 2021, 12:49
dmgg.py - файл сюда выложите или скопируйте содержимое.
Это питоновский скрипт, может там символ пропущен, запятая или еще чего...
现在的也越来越难修啊,生意真是不好做啊!
© Конфуций из Шэньчжэня
СообщениеДобавлено: 30 сен 2021, 12:52
сам скрипт не при чем, такое поведение именно на сборках с тсервером
---------- Добавлено спустя 2 минуты 16 секунд: ----------
(и автор скрипта, помнится, в своих сборках это фиксил)
СообщениеДобавлено: 30 сен 2021, 12:59
uncledim
Значит нужно сравнить 2 папочки и сам скрипт, и посмотреть чего не хватает в том что не "пофиксен" :hi_hi_hi:
А не качать понапрасну по 60Гигов туда обратно...
Из-за 3-х строчек кода.
Как работать с bash скриптами писал здесь:
viewtopic.php?p=893592#p893592
3 поста вниз, для тех кто совсем "не в теме" :hi_hi_hi:
Я так полагаю db32 в тсервере тестирует АМД-шный северный мост, pcie контроллер и т.д. и т.п
У кого AM3 на руках(десктопы) ну и ноуты, могут попробовать...
СообщениеДобавлено: 30 сен 2021, 16:27
Воробей писал(а):
Нормальная история, большая часть карт именно так и диагностируется.
Я использую карточку Nvidia для проверки карточки AMD, чтобы Tserver не ругался. ибо если две карты амд, приходится:
./agt -i=1 -clkstatus
./tserver -d=1 -boardtest=memfa
Конечно так работает, но лишние 5 символов вводить лень
---------- Добавлено спустя 56 минут 47 секунд: ----------
Обновил репак Tserver
пофиксил размер, ибо получилось так, что не все флешки 32 гб на самом деле 32 гб.
встает как на жесткий диск, так и на флешку, 32гб и более.
Сборка эта, скрипты подпихивал разные у всех скриптов разное поведение до и после запуска Tserver
СообщениеДобавлено: 30 сен 2021, 16:41
"Если машина не едет, стоит начать с проверки прокладки между рулем и сиденьем" :hi_hi_hi:
Если вы никогда не пользовались Линуксом, на уровне продвинутого пользователя, то не стоит начинать это делать с этих тестов.
Отдайте тому, кто умеет этим пользоваться.
Вы же не ходите зубы к сантехнику лечить.
СообщениеДобавлено: 30 сен 2021, 17:00
а почему собственно? если кроме этих тестов от линукса ничего более не нужно.
СообщениеДобавлено: 30 сен 2021, 17:09
uncledim
Потому что для него это похоже бизнес - ремонт электроники.
Значит приглашается в сервис специалист за деньги, который в течении дня ему всё настроит и научит пользоваться.
СообщениеДобавлено: 02 окт 2021, 20:39
Подскажите в каком направлении двигаться? ГПУ или память?
Память вся проверенная, гпу под вопросом. Карта даёт картинку без артефактов, винду не грузит, чёрный экран. Тест memfa проходит и выдаёт ошибку якобы по 10каналу, но в логе ошибки по всем каналам сразу. При этом тесты АК403.003 проходит успешно
СообщениеДобавлено: 02 окт 2021, 21:59
Реболл гпу попробуйте)
СообщениеДобавлено: 03 окт 2021, 02:42
биос другой - родной попробуйте
СообщениеДобавлено: 03 окт 2021, 03:20
Карта работала, грузила систему, крутила бублик до 65град, дальше происходил сбой, требовался реболл ГПУ, ГПУ поднял, поставил другой, на который я ранее сам же накатал шары. Результат выше. Биус не трогал, в безопасном режиме или без драйверов грузится, как только грузишься с драйверами, черный экран.
СообщениеДобавлено: 06 окт 2021, 17:38
suhar777777
Не могли бы поделиться своим модом на dmgg? Который с графической схемой расположения чипов
СообщениеДобавлено: 06 окт 2021, 20:03
Поделитесь опытом?
RX560 4гиг, boardtest=memfa на стоке - pass. Какую бы частоту памяти не выставлял через ./agt - все pass. Даже 2200 ставил - вас ок.
АК325.001 который долгий 8бит, и даже с задранной частотой памяти - pass
AK403.001 зависает сразу практически даже на стоке. Соответственно логов нет.
Если пробовать через ppvddc менять напряжение любое из таблицы - или черный экран и виснет или применяются настройки, но запускаешь boardtest=memfa и тоже черный экран и виснет.
ГПУ отошёл?
Что основной, что второй картой - одинаково.
В винде 43 ошибка.
СообщениеДобавлено: 07 окт 2021, 02:32
А 403.001 на частотах по умолчанию, 300мгц тоже зависает?
СообщениеДобавлено: 07 окт 2021, 10:58
Да, причем сразу. Или черный экран, или застывшая картинка с градацией, или застывшая артефачная картинка. Но в любом случае тест нисколько не идёт.
---------- Добавлено спустя 3 часа 7 минут 51 секунду: ----------
и в догонку вопрос... может такое быть из-за того, что память стоит чуть другая?
изначально стояли 4 банки H5GC8H24MJR-R0C
сейчас стоит 1 банка H5GC8H24MJR-R0C и 3 банки H5GC8H24AJR-R0C
по этой таблице разницы не увидел
СообщениеДобавлено: 07 окт 2021, 15:44
zoidberg писал(а):
ddmg was showing:
hello i think you are not using the last version of dmgg; there was a version with problems as this was work in progress at that time ;
now dmgg it is dependent of agt file from tserver but if you wish it can be edited and made standalone script with some linux implementations that is able to detect the amd cards you wish to check ;
i posted few pages in the back a 32GB version with all the tools nvidia and amd also some other peoples made and post their version in same topic here; try any it should work ok;
start from current page and go back when searching here because we cant edit older posts and they keep sometime outdated information
СообщениеДобавлено: 07 окт 2021, 21:02
В версии тсервер на 32 гб из этой темы, команда ./agt mc -mccfg
должна выводить список чипов памяти с размером? У vik_on в видео где взял команду другая версия, но у него в гугл диске такая же как здесь.
У меня выводит только объем всей памяти, но он наверное из биоса берется?
Тсервер показывал исправными только 4 чипа, может поэтому?
СообщениеДобавлено: 08 окт 2021, 11:05
kvn73 писал(а):
только 4 чипа
получилось еще два восстановить, теперь 6 показывает рабочих, но объем чипов так и не показывает, версия тсервер 2.3.42.89 у Виктора 2.3.43...
эту карту уже замучил, раз десять уже перекатывал банки чтобы добиться шести рабочих
еще штук десять банок неизвестного состояния с доноров, сопротивление по шинам vddq-vssq 4-10 кОм vdd-vss 2-5 кОм падение напряжения на диодной прозвонке 0,53 и 0,34+- соответственно
и почему то не разу тсервер не показал что одна банка исправна или нет в канале, сразу на весь канал -5555555
этож сколько комбинаций еще перепробовать?
все линии к гпу вызванивал
СообщениеДобавлено: 08 окт 2021, 19:41
Вообщем изыскания закончились тем, что на модифицированном биосе от гигабайт майнит и эрго и классик, с разгонами и без... В винде 43 ошибка, хотя объем памяти показывает.
На стоковой прошивке любого вендора Майнер сразу валится и в хэвос показывает объем памяти каке-то космические цыфры.
Видимо КП отъехал? Не понятно. Хотя такое на двух картах - пробовал эту же память переставить на другую доску. Да, память ноутбучная, но не думаю что в этом есть какая-то разница - гддр он и в Африке гддр. Так ведь?
СообщениеДобавлено: 12 окт 2021, 19:55
попробуй дрова Win10-64Bit-for-mod-card с ней ошибка 43 уходит. только так я карту заставил работать в виндовс 10
СообщениеДобавлено: 13 окт 2021, 09:46
Пришли с али б/у чипы самсунг, к 6 хуниксам добавил 2 самсунг, карта завелась без ошибок и уже в работе.
Сопротивления у самсунга vddq-vssq 39 кОм vdd-vss 0,3 кОм
Хьюникс так и не понятно как по сопротивлению отбраковывать, и у рабочих и плохих сопротивления как выше написал, больше их не буду заказывать.
СообщениеДобавлено: 16 окт 2021, 03:04
Никто не пробовал тестить скриптом dmgg.py карты rx 6800 rx 5700 и подобные ? Так как в новом китайском образе под 6000 вообще нет теста а на 5700 5500 все жалуются что не работает корректно. У меня в ремонте Сапфир RX6800 проблема - при входе в виндовс - пропадает изо при подключении второй картой - код 43 . В винде иногда доходит до изо - но потом изо то пропадает то снова появляется. Но дело не в этом. Затестил карточку скриптом dmgg.py с флешки с арчлинуксом - dmgg показал ошибки по всем каналам. Ну может и правильно - если проблема - ГПУ. При этом в списке пси устройств отображался только ID карты и Sub ID без названия. Также запустил dmgg.py из под hiveoc - тут уже lspci -v|less показал полное название карты ядро Navy . После запуска скрипта комп ненадолго подвис затем появилась запись типа кернел паник с предупреждением о перезагрузке и чуть позже комп перезагрузился. Тоже как бы логично - если с ГПУ проблемы - драйвер не подцепился - вот и сообщение и перезанрузка. К сожалению на руках нет рабочей карточки Navy чтобы снять память и проверить работу скрипта. Подскажите пожалуйста - может я не по тому пути пытаюсь идти и скрипт не может работать с Navy ? А может у кого есть возможность проверить работу дмгг на рабочей карте со снятой банкой памяти ? Фото работы скрипта в hiveoc и archlinyx прилагаю. Там же фото от другого человека теста рабочей карточки 6700 ХТ по-моему. И да - а нельзя ли драйвер из hiveOC который корректно видит RX 5000 RX6000 как то приспособить к китайскому образу для RX5000 хотя бы. Сам к сожалению с линуксом почти не знаком
СообщениеДобавлено: 17 окт 2021, 20:38
Как мне известно ili321 (автор скрипта) не проверял и не редактировал свой тест для таких карт.
Иди по пути тестирования через TSERVER. - слышал 5700 и 5700 XT - тестировали с помощью Tserver
СообщениеДобавлено: 17 окт 2021, 21:05
а и не надо) скрипт и нвидию оттестирует, если его на нее натравить
так с него видимо и пришел)
нерабочее оно, что в открытом доступе..
СообщениеДобавлено: 17 окт 2021, 23:26
во во - тут делов то - у кого есть рабочая такая карточка - снять или отключить одну банку - и запустить дмгг - скинуть фото теста - потом можно и обсудить результаты
---------- Добавлено спустя 3 минуты 37 секунд: ----------
ну и затестить с под арча и с под хайвос
СообщениеДобавлено: 18 окт 2021, 00:56
"на это я пойтить не могу", но вот
убунта 20.04.02 lts
amdgpu 20.50
тест с подключенным к пациенту монитором (пришлось поподбирать начальный адрес)
"артефакты" (т.е. тест явно получил доступ к видеопамяти) в наличии
и те же 511 ошибок в итоге (ожидаемо)
---------- Добавлено спустя 13 минут 36 секунд: ----------
другой человек это я, дратути)
В этой теме нет новых непрочитанных сообщений. Need memory test software/script for RX 6900XT ASROCK
[ На страницу: 1, 2, 3, 4 ]
thegregin
94
19373
01 июл 2024, 23:03
kaare123 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Help help Help memory samsung detect micron (domate)
PT-AH
02 ноя 2022, 14:43
PT-AH Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. memory test software/script for RX 6950XT
Vdfm
27 ноя 2023, 16:00
dapove15662 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. RTX3080/3090 memory training errors вопрос
darker123
18
2654
05 янв 2024, 09:11
tonycstech Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. nvidia DTX970 gaming 4g vga cards help
serwanjaf7
22 май 2020, 06:52
vov4ik_il Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 19
