Текущее время: 21 ноя 2024, 22:27
 Страница 1 из 1 [ Сообщений: 27 ]
 Заголовок сообщения: Weird error with Mats/Mods and GTX970: unsupported dram Page size and L2 slices
СообщениеДобавлено: 02 окт 2021, 15:13
Hello there, i have a Gigabyte gtx970, no Video out. When i test it as secondary card with Mods, i get this weird message. It loops itself until i abort it. All voltage present, bioses already reflashed with spi flasher
Have anyone Informations about this issue?
 Заголовок сообщения: Re: Weird error with Mats/Mods and GTX970: unsupported dram Page size and L2 slices
СообщениеДобавлено: 02 окт 2021, 18:13
Версия какая?
СообщениеДобавлено: 02 окт 2021, 21:37
Gigabyte Gaming G1 GTX970
СообщениеДобавлено: 03 окт 2021, 00:43
Имелось ввиду версия MATS MODS.
СообщениеДобавлено: 03 окт 2021, 11:28
i have testet with two versions: v.367.38.1 and v.400.184
as secondary card with initializion parameter "./mods gputest.js -skip_rm_state_init -mfg"
and testing with "./mats -n 1 -e 20"
СообщениеДобавлено: 03 окт 2021, 11:45
Assassin
Use Shift+PageUp to see the result.
现在的也越来越难修啊,生意真是不好做啊!
© Конфуций из Шэньчжэня
СообщениеДобавлено: 03 окт 2021, 12:23
I know how to use mats/Mods ;)
There is no results, becaus the error message loops endless until i stoped it with STRG + C
Unsupported numbers of Slices 11
Unsupported numbers of slices
Decode Adress: unsupported DRAM Page Size - 32!
Invalid number of L2 Slices 11
Thats the point - i dont get any results, also no report.txt File:(
СообщениеДобавлено: 03 окт 2021, 12:31
It seems no :hi_hi_hi:
To see how the test ended, you can simply climb higher using the key combination Shift+PageUp
report.txt report.txt is created at the ./ of the disk partition
execute
cd /
bin home root report.txt
СообщениеДобавлено: 03 окт 2021, 12:38
The test never ends, it runs endless, over hours. Ubtil i stopped it manualy
СообщениеДобавлено: 03 окт 2021, 12:39
Assassin
can you shoot a video? it would be clearer
СообщениеДобавлено: 03 окт 2021, 12:57
https://drive.google.com/drive/folders/ ... BdTu6g__fZ
https://youtu.be/6CnOODXuPtA
At the end - i Interrupt/abort this with STRG+C, becaus when i dont Interrupt this, the report.txt fets filled completly ubtil the usb Stick have 0kb FREE of memory (and the report File is then 8GB big, but without any results, only this Looping message)
СообщениеДобавлено: 03 окт 2021, 13:06
Assassin
0:28
Press Shift and PageUp and move to the beginning of the test.
there should be a table by memory channels
Probably the culprit of the GPU
СообщениеДобавлено: 03 окт 2021, 13:08
была таже проблема матс от викона решила задачу
СообщениеДобавлено: 03 окт 2021, 13:19
in video, on 0:28 i have pressed CTRL + C to abort this looping message
i test it now with older 367 version with gold files...but how can i run mods on secondary GPU? becaus this GTX have no video out, so i use an old AMD card as primary card for video out, and the GTX970 is placed on a second PCIe x16 slot (x58 board)
i knows this command, but it shows me - hardware was not initialized
./mods gputest.js -oqa -old_gold -test 94 -fan_speed 70 -dramclk_percent 100 -ignore_fatal_errors -run_on_error -matsinfo
what commands should i use to say mods to use the second card?
СообщениеДобавлено: 03 окт 2021, 13:33
Assassin
here:
viewtopic.php?p=786243#p786243
although the built-in video core of the processor is used
and read the topic below :a_g_a:
Последний раз редактировалось com77 03 окт 2021, 13:35, всего редактировалось 1 раз.
СообщениеДобавлено: 03 окт 2021, 13:34
Mensch ich habe oben link für mats gelassen. Mach mit Rufus neu usb mit mats. Danach muss du Gold file in mats Ordnern kopieren. Im Bios von usb Start einstellen. Video Signal von defekte Karte. Egal ob die Karte liefert Bild oder nicht. Pc starten ca. 5 Minuten warten. Die Grafikkarte wird automatisch getestet. Pc ausschalten. Danach findest du Report.TXT file mit Test in usb. Sorry für Fehler
Ich habe gleiche Problem mit gtx960 gehabt.
СообщениеДобавлено: 03 окт 2021, 13:58
Предлагаю воспользоваться этой версией.
СообщениеДобавлено: 03 окт 2021, 14:13
@Lechnowitsch
wont work. report.txt file gets large and fill up usb stick completly :(
version 343 also wont work, same errors
Posted after 5 minutes 18 seconds:
can it be possible thtat gpu itself is damaged?
СообщениеДобавлено: 03 окт 2021, 14:23
einfach alle 4 ram austauschen
СообщениеДобавлено: 03 окт 2021, 14:35
4? It have 8 ^^
But i dont think its a memory issue... This L2 slice error confuses me, so i think, its an gpu damage
СообщениеДобавлено: 03 окт 2021, 14:48
reball it :hi_hi_hi:
СообщениеДобавлено: 03 окт 2021, 15:03
I have reflowed it with flux and push it a little, but error still exist
СообщениеДобавлено: 03 окт 2021, 15:17
Assassin
Only hard rock, only reball :a_g_a: :hi_hi_hi:
СообщениеДобавлено: 04 окт 2021, 05:02
unsupported dram Page size GTX 980 Ti :-):
СообщениеДобавлено: 04 окт 2021, 08:57
This card was baked in an oven by its previous owner... So its realy possible that is a gpu defekt i think.
A GTX 970 is not worth the effort of reballing
СообщениеДобавлено: 06 апр 2024, 21:54
Может поможет кому.
Была сейчас точно такая же ситуация с ASUS GTX 950. Матс говорил про не инициализированную карту. Только 400.250 матс сказал, что vbios плохой. Проверил обвязку и обнаружил наполовину сбитый резистор на первой ножке микросхемы BIOS, поправил и всё заработало.
В этой теме нет новых непрочитанных сообщений. GTX 1070 Strix, weird artefacts on screen (mats ok) - странные артефакты на экране (mats ok)
cxav
21 фев 2021, 12:42
В этой теме нет новых непрочитанных сообщений. MATS понятно а как MODS ? Синий экран Video Scheduler Internal Error
tonycstech
1131
01 май 2022, 03:51
tonycstech Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Is this second hand 3090 Gigabyte Eagle OC good for purchase? It passed Furmark and Unigine but not MATS/MODS.
Shayan
31 дек 2023, 21:07
FrostDad Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Error running MATS with parameter ./mats -e 20
thanhnamvl86
25 фев 2023, 04:17
meecoolk3pro Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Memory location and listing on this device Quadro K4000 and how to good mods test
nightdancer
08 фев 2022, 19:59
nightdancer Перейти к последнему сообщению
Сейчас этот форум просматривают: madking, wid0wmak3r и гости: 62
