Текущее время: 22 ноя 2024, 15:29
 Заголовок сообщения: ASUS GTX1060-6G - MATS/1 bit fail
СообщениеДобавлено: 15 апр 2021, 19:47
Hi, I have the following problem with ASUS GTX1060-6G, the PC boots-up with lower resolution on DVI or with high resolution on DisplayPort, no signal on Hdmi. The driver reports error 43
After running MATS I have replaced the memory B1 but no changes
I reball the GPU but again no changes
Does anyone have an idea?
From the following repost it fails only the bit B035 (!!) even if I increase the size of the memory under test
Does anyone know if it is a GPU or a PCB damage? Thank you :)
mats version 400.184. Testing GP106 with 60 MB of memory starting with 0 MB.
Read Error Count: 0
Write Error Count: 330900
Unknown Error Count: 0
=== MEMORY ERRORS BY SUBPARTITION ===
SUBPART READ ERRORS WRITE ERRORS UNKNOWN ERRS
FBIOA0 0 0 0
FBIOA1 0 0 0
FBIOB0 0 0 0
FBIOB1 0 330900 0
FBIOC0 0 0 0
FBIOC1 0 0 0
Failing Bits:
B035 <<<<<<<<<<======================== only always 1 bit !!
=== MEMORY ERRORS BY BIT ===
P : Partition (FBIO)
READ 0 READ 1 READ ?
P BIT READ ERRORS WRITE ERRORS UNKNOWN ERRS EXP. 1 EXP. 0 EXP. ?
B 035 0 330900 0 0 330900 0
=== MEMORY ERRORS BY ADDRESS ===
ADDRESS : Failing memory address, or buffer offset if starting with 'X+'
T : Type of memory error: W = write, R = read
S : Subpartition
B : Bank
E : Beat
ADDRESS EXPECTED ACTUAL REREAD1 REREAD2 FAILBITS TPSBE ROW COL BIT(s)
0003a1e5b0 00000000 00000008 00000008 00000008 00000008 WB164 009a 075 B035
0003a1e590 00000000 00000008 00000008 00000008 00000008 WB164 009a 074 B035
000040e130 00000000 00000008 00000008 00000008 00000008 WB164 000a 071 B035
000040e110 00000000 00000008 00000008 00000008 00000008 WB164 000a 070 B035
0000407130 00000000 00000008 00000008 00000008 00000008 WB174 000a 071 B035
0000407110 00000000 00000008 00000008 00000008 00000008 WB174 000a 070 B035
0001cb62b0 00000000 00000008 00000008 00000008 00000008 WB1a4 004c 07d B035
0001cb6290 00000000 00000008 00000008 00000008 00000008 WB1a4 004c 07c B035
00036972b0 00000000 00000008 00000008 00000008 00000008 WB164 0091 07d B035
0003697290 00000000 00000008 00000008 00000008 00000008 WB164 0091 07c B035 ...
 Заголовок сообщения: Re: ASUS GTX1060-6G - MATS/1 bit fail
СообщениеДобавлено: 18 апр 2021, 11:25
in the picture please note the artefacts that I see on the dos screen
СообщениеДобавлено: 04 окт 2021, 22:58
I have a 1060 gtx Gainward with the same problem.
I replaced the memory 2 times but no change. Unfortunately I forgot to measure all pins of the memory of the have some resistance to anything
Maybe it is a connection problem to the GPU and I will try to reflow the GPU in the next days.
СообщениеДобавлено: 08 окт 2021, 18:09
Now I reflowed the GPU without succes, problem is still there.
So in this case I will Reball the GPU and start measuring the pins to the ram bank when the GPU is lifted.
Does anyone know if there is a mapping from Bit to pin?
Теперь я безуспешно перепрограммировал графический процессор, проблема все еще существует.
Итак, в этом случае я переболю GPU и начну измерять контакты к банку RAM, когда GPU будет поднят.
Кто-нибудь знает, есть ли отображение Bit to pin?
СообщениеДобавлено: 09 окт 2021, 01:06
I did an reflow again befor reballing and I poked the GPU a very small bit when the solder was melted.
An now the failing bit is away, no errors on MATS.
But now the GPU has another problem, in Windows or 3D mode the whole computer crashes with some artefakts over the whol screen.
I am not sure if this comes from reflow or whats the reason behind.
I did some measurements and I see an voltage drop from 0.7V to 0.6V on the GPU-phases, maybe this comes from the first use, where I lowered the Power-Level with Afterburner to 65% and to watch the sensors in GPU-Z while mining to test the Memory and GPU :-)
But after some reboots it is still there.
Does anyone know if there is a safe mode power level for the GPU? Maybe I should nevertheless reball the GPU.
Я снова выполнил оплавление перед реболлингом, и я слегка ткнул графический процессор, когда припой расплавился.
Теперь сбойный бит отсутствует, ошибок на MATS нет.
Но теперь у графического процессора есть другая проблема, в режиме Windows или 3D весь компьютер вылетает с некоторыми артефактами на весь экран.
Я не уверен, происходит ли это от оплавления или в чем причина.
Я провел несколько измерений и вижу падение напряжения с 0,7 В до 0,6 В на фазах графического процессора, возможно, это связано с первым использованием, когда я снизил уровень мощности с помощью Afterburner до 65% и посмотрел на датчики в графическом процессоре. Z во время майнинга для тестирования памяти и графического процессора :-)
Но после некоторых перезагрузок он все еще там.
Кто-нибудь знает, есть ли уровень мощности в безопасном режиме для GPU? Может, стоит все же реболлинг GPU.
СообщениеДобавлено: 11 окт 2021, 12:01
Ok, I found it.
After Testing with 100MB, Mats shows failures on 3 Banks. Also on the included replaced bank.
I am not sure if I should replace them or this is a Problem with the GPU conntection or the GPU itself :-(
Хорошо, нашел.
После тестирования со 100 МБ Матс показывает сбои на 3 банках. Также на включенной замененной банке.
Я не уверен, стоит ли мне их заменять, или это проблема с подключением к графическому процессору или с самим графическим процессором :-(
mats version 400.184. Testing GP106 with 100 MB of memory starting with 0 MB.
Read Error Count: 0
Write Error Count: 15653868
FBIOA0 0 0 0
FBIOA1 0 0 0
FBIOB0 0 3971010 0
FBIOB1 0 676279 0
FBIOC0 0 11006579 0
FBIOC1 0 0 0
Failing Bits:
B000 B001 B002 B003 B004 B005 B006 B007 B008 B009 B010 B011 B012 B013 B014 B015
B016 B017 B018 B019 B020 B021 B022 B023 B024 B025 B026 B027 B028 B029 B030 B031
B056 B057 B058 B059 B060 B061 B062 B063 C000 C001 C002 C003 C004 C005 C006 C007
C008 C009 C010 C011 C012 C013 C014 C015 C016 C017 C018 C019 C020 C021 C022 C023
C024 C025 C026 C027 C028 C029 C030 C031
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. GeForce GTX1060 OC 3Gb - Ошибка 43, тест Fail
Master123
2709
05 янв 2021, 14:08
Master123 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Error running MATS with parameter ./mats -e 20
thanhnamvl86
25 фев 2023, 04:17
meecoolk3pro Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. GTX1060 3G Palit Dual. В MATS ошибки по всем банкам памяти.
Домосед
25 авг 2020, 11:35
Kitoman Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Palit Dual GTX1060 3Gb - ошибки по всем каналам в MATS
Conqueror
3911
11 авг 2022, 10:44
mike5551963 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. GTX 1070 Strix, weird artefacts on screen (mats ok) - странные артефакты на экране (mats ok)
cxav
21 фев 2021, 12:42
Сейчас этот форум просматривают: bsb5068 и гости: 91
