Pandemonium6 писал(а):
Use it as a secondary card and try to read errors, maybe 43 maybe a different one. Run GPU-Z and show tabs one and two.
for concretization: The GPU i s detected, it is not necessary to be mounted as a secondary GPU. Display is connected to this problematic GPU and I have image. Only when I try to install AMD driver the PC freezes and nothing will happening till reset. During post test no errors. If driver is already installed, then the OS booting will go till the moment where the GPU drivers are loaded and the system frizzes.
one image with amdvbflash. I have updated one of GPU bioses with bios from my good working rx5500 card. Now, with switch in the middle the bios -S04 and with switch left position -S-05 bios.
