Текущее время: 08 июл 2024, 05:32
ilie321
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 26 янв 2022, 22:14 |
Зарегистрирован: 27 фев 2020, 13:07 Наличности на руках: 305.76
Сообщения: 297 Откуда: romania
sshana писал(а): Hello, sorry if this have been asked before,
Is it possible to test an AMD card (Rx 580 to be exact) in secondary mode? there's no image on this card
Using iGPU (Intel) or another card as primary?
If possible, what is needed?
Thanks! If you read topic you will find that is very possible. Easiest is to have nvidia to see image.
sshana
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 27 янв 2022, 06:56 |
Зарегистрирован: 11 мар 2020, 06:57 Наличности на руках: 29.04
Сообщения: 20 Откуда: Venezuela
ilie321 писал(а): If you read topic you will find that is very possible. Easiest is to have nvidia to see image. Yeah, that did the trick, thank you. Fixed the 580, now having a weird problem with another cards What could it be, GPU?
StayeR
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 28 янв 2022, 08:05 |
Зарегистрирован: 18 янв 2011, 16:21 Наличности на руках: 185.45
Сообщения: 171 Откуда: Омская область
sshana писал(а): now having a weird problem with another cards Hello! There were such errors when replacing all the memory, and there were no soldered contacts. There was such a bug in TServer. Rescued script DMGG which showed on which channels the problem. After re-soldering - everything worked. Check it. And look at the state of the crystal on the chip for cracks and chips in the corners. I met the same error on chips with a damaged crystal.
motohomiak
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 30 янв 2022, 17:39 |
Зарегистрирован: 10 янв 2022, 16:12 Наличности на руках: 28.05
Сообщения: 22 Откуда: SPb
Pandemonium6 писал(а): viewtopic.php?f=48&t=100822&start=1050 Спасибо, мил человек!
Sinchuk
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 03 фев 2022, 14:29 |
Зарегистрирован: 26 авг 2018, 13:01 Наличности на руках: 36.39
Сообщения: 131 Откуда: Россия
Crimfell писал(а): то просто восстановите образ usb1804v3.pmf при помощи diskgenius. По крайней мере у меня все работает и без boot-repair-disk-64bit. Я на флешку все воcстановил, но с нее не грузится комп, постоянная перезагрузка... что я не так делаю ?
Gas_man
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 07 фев 2022, 09:03 |
Зарегистрирован: 31 янв 2019, 21:09 Наличности на руках: 390.39
Сообщения: 305 Откуда: Чебоксары
submitred писал(а): Ребят, подскажите Сделай свой скрипт и пропиши там тесты -test=ak600.001 и т.п. Вот я такой текст скрипта использую: rm -f memfa.log ./agt -pplist=short read -p "Select the test Mode = " mod echo "Mode select =" $mod sleep 5 ./agt -ppmode=$mod ./agt -fancontrol=2 ./tserver -d=gpu.* -test=ak600.001 sleep 1 ./tserver -d=gpu.* -test=ak403.001 sleep 1 ./tserver -d=gpu.* -test=ak403.003 sleep 1 ./tserver -d=gpu.* -test=ak401.001 sleep 1 ./tserver -d=gpu.* -test=ak010.001 sleep 1 ./tserver -d=gpu.* -test=ak311.007 sleep 1 ./agt -clkstatus sleep 3 nano memfa.log назвал его test.sh закинул в папку с rx470 и запускаю ./test.sh У меня было 2 такие карты. ошибки по каналам полезли уже на тесте ak403.001
DmitriyDDD
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 12 фев 2022, 17:55 |
Зарегистрирован: 09 июн 2015, 17:28 Наличности на руках: 235.11
Сообщения: 243 Откуда: Пушкино
Sinchuk писал(а): Я на флешку все воcстановил, но с нее не грузится комп, постоянная перезагрузка... что я не так делаю ? не каждая версия diskgenius корректно создает флешку из образа. нужно после залития или флешку восстанавливать с помощью boot-repair-disk-64bit или "правильную" версию diskgenius У меня версия 5.4.2.1239 она правильно создает флешку
MisterAlex
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 12 фев 2022, 20:37 |
Зарегистрирован: 03 апр 2013, 13:34 Наличности на руках: 29.07
Сообщения: 485 Откуда: Екатеринбург
Gas_man писал(а): MisterAlex писал(а): Подскажите пожалуйста
./tserver -d [отображает список карт] ./tserver -d = 1 [порядок может быть другим] ./tserver -d = 0 [порядок может быть другим] Не хочет ничего показывать . Я так понимаю последовательность такая , заходим в интересующую папку с модом и вводим ./tserver -d . Правильно понимаю ?
Gas_man
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 13 фев 2022, 11:52 |
MisterAlex писал(а): Не хочет ничего показывать . Я так понимаю последовательность такая , заходим в интересующую папку с модом и вводим ./tserver -d . Правильно понимаю ? Зачем? Если у вас в тесте одна карта - она автоматом определяется, если у нее нет каких-то других проблем, кроме памяти. ./tserver -d - нужно тогда, когда у вас материнка без поддержки встроенной графики и вы используете в качестве первичной карту АМД, тогда есть смысл использование команды выбора карты
olegshepeta
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 16 фев 2022, 18:35 |
Зарегистрирован: 27 янв 2021, 17:27 Наличности на руках: 14.49
Сообщения: 128 Откуда: Київ
Подскажите люди с опытом Есть MSI rx 480 4 Gb (ошибка 43 при запуске на встройке, невозможность установить драйвер, картинку не показывает). При тестировании tserver из папки 480 выдает пятерки в A канале https://drive.google.com/file/d/1mbXM64 ... sp=sharinghttps://drive.google.com/file/d/1mW5wZf ... sp=sharingЕсли тестировать папкой 590, то уже сыпет ошибками по всех каналах, причем пятерки в А канале остаются, в остальных каналах появляются четверки https://drive.google.com/file/d/1mevtqP ... sp=sharing, https://drive.google.com/file/d/1mf0Bda ... sp=sharing, https://drive.google.com/file/d/1mfFH7J ... sp=sharing, https://drive.google.com/file/d/1mg7lQU ... sp=sharingЗначит ли это, что логично поменять память на А канале и перепроверить повторно P.S. Как вставлять сразу изображения на форум без ссылок на другие ресурсы? Команда "Добавить изображение" у меня не работает, перекидывает на страницу с ошибкой 404
Gas_man
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 16 фев 2022, 20:23 |
olegshepeta писал(а): пятерки в A канале Меняй канал А (оба чипа) благо у тебя чипы не дефицитные. А там видно будет. А фото вставить через "ДОБАВИТЬ ФАЙЛ"
Vovan800
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 17 фев 2022, 06:25 |
Зарегистрирован: 29 июн 2014, 15:46 Наличности на руках: 11.21
Сообщения: 61 Откуда: Новокузнецк
Братья, пните в нужном направлении! :) Окуенная голубая сапфира нитро+ RX 580 на 8Гигов - память всегда 300, дрова не ставятся, частота GPU регулируется, частота памяти нет, в линуксе - дрова встают, майнит только Gminer-ом, 20Mh c ошибками. Тсервер проходит только на 300 с ошибками по всем каналам и только первую часть, потом на втором тесте зависон, махнул всю память на самсу (была хуникс), биос шил, а ничего не изменилось, при этом картинку норм выводит и все напряжения в норме, dmgg.py тест проходит... Все 43 стр. темы перечитал: при ошибках во всех каналах пинают смотреть питание памяти, но здесь всё замечательно, осцилом ровная линия 1,56V! GPU грел, качал на шарах с флюсом..
olegshepeta
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 17 фев 2022, 18:38 |
serega2014Mog писал(а): если показывакет канал a, то это единственный канал который можно с точностью сказать это а0 или а1 просто дать команду ./agt -mccfg если производитель памяти будет виден то просто меняйте а1 а если тишет что неизвестен то меняйте а0 Очень благодарен. Проверил только что другую карточку msi aero rx 560 4 gb - судя по Ваших рекомендациях можно сузить замену до одной микросхемы а1
stud
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 22 фев 2022, 11:41 |
Всем здравствуйте! Я здесь видел вопросы но ни не видел ответы по поводу ошибки в Tserver Когда проверяешь память и пишет ошибку, но при этом память целая. В чем проблема, это GPU отваливается? Вложение: 4b7f5e7b-c7e5-4906-8b0f-82a996d293db.jpg
stud
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 22 фев 2022, 16:02 |
kubik писал(а): Zkus udělat rebal videočipu a velmi často je jedna pamět vadná,tj všechny odpájet,zkontrolovat ohmetrem napájení pamětí a většinou jeden ze 4 pinů má nekonečný odpor u jedné i více pamětí,stává se tedy že paměti se tváří při testu že jsou ok ale karta i tak nehashuje Вы имеете ввиду, если показало что все хорошо но при этом эта ошибка, то ошибка в памяти имеется? Я конечно попробую. Иначе у меня выбора нет. Поставлю другую память и посмотрю изменится или нет. Но сам чип к сожалению я не смогу перекатать или заменить. Нет инфракрасной паяльной станции.
Gas_man
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 22 фев 2022, 20:09 |
stud писал(а): Вы имеете ввиду, если показало что все хорошо но при этом эта ошибка, то ошибка в памяти имеется? Я конечно попробую. Иначе у меня выбора нет. Поставлю другую память и посмотрю изменится или нет. Но сам чип к сожалению я не смогу перекатать или заменить. Нет инфракрасной паяльной станции. Забей на эти ошибки "VDDC" Карта работает ? Изо Дает? Тесты проходит?
stud
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 23 фев 2022, 13:00 |
Gas_man писал(а): Забей на эти ошибки "VDDC" Карта работает ? Изо Дает? Тесты проходит? Забивать на то что она не работает? Если знаете проблему, то говорите, а просто кидаться словами все могут. Карта не работает, если бы она работала я бы не писал ни чего! ---------- Добавлено спустя 52 секунды: ---------- kubik писал(а): Opravoval jsem asi 40 ks RX470 a hodně karet i po výměně špatných pamětí bud neprošly testem anebo byly ok-PASS ale po vložení do rigu nehashovaly,po odpájení a změření pamětí ohmetrem jsem našel vždy nějaké vadné paměti,ty dobré ještě přezkouším zapájením do dobré desky.Ale vždy začínám Bios čipem.Nejlepe se opravují karty,když si seženeš komplet všechny dobré paměti např. z ALIexpresu,ale i ty někdy posílají vadné. Спасибо! Я обязательно попробую
Gas_man
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 23 фев 2022, 13:09 |
stud писал(а): а просто кидаться словами все могут. Никто словами не кидается. Я же вопросы задал: Карта работает ? Изо Дает? Тесты проходит? "PASS" " это на стандартных частотах - 300 Mhz? или повышали частоту? - ./agt -mem=2000 Всю всю ли память видит правильно? - ./agt -mccfg Мало информации. LOG файл выложи.
