com77 писал(а):
You can check yourself.
MSI MS-V381 this is RX5700:
I have all these boardviews, but where do you see the Memory Channels in that boardview file?
If you mean U2000 is always A0-A1 you are wrong, theres a boardview for 6800 too, starting with U2000 too, but in the video i have linked previously it clearly states that U2000 is C0-C1 so it looks like: C-D-E-F-G-H-A-B from counter clockwise, and i strongly think that on RX5700 is the same, because the pcb and the vrm's, VRAM etc... is almost the same. Have you seen the video i have linked?
