Текущее время: 29 ноя 2026, 17:10
 Страница 1 из 1 [ Сообщений: 19 ]
 Заголовок сообщения: Asus P67 Sabertooth No Vcore
СообщениеДобавлено: 10 сен 2022, 01:54
Board came in bad condition, broken cpu socket and burnt sio. Changed both, all legs soldered well and cpu socket tested with tester. Board turns on but reset remains. VCCIO is 1.08 V and there s no vcore. ASP1000C has enable voltage of VCCIO which is 1.08 but there s no VRMVCC. Its connected to 3V directly with 0 ohm resistor and the problem starts here. the voltage on the resistor is 2.22 V, removed the resistor nothing changed, replaced the pwm controller everything is same. When i remove the controller voltage drops to 1.8 v, removed the cpu and force started motherboard with 3.3v injected to VRMVCC then vcore rises to 1.07 V but when i put the cpu voltage rises 2 V on vcore. I have never seen something like this, makes me feel desperate please help, thank you.
Boardview : https://www.mediafire.com/file/t5az06ki ... 2X.fz/file
 Заголовок сообщения: Re: Asus P67 Sabertooth No Vcore
СообщениеДобавлено: 22 сен 2022, 14:50
Did u watching closely for broken /swept away elements in asp1000 feedback circuit? As soon as the board has so bad condition. I wait for working sabertooth p67, it has to arrive in some days. So I could make some measures for u and watch over smd alements in vrm area.
СообщениеДобавлено: 23 сен 2022, 09:14
Also chek or replace at the bottom side of MB PU107,PU103,PU109 and his around area(PR176,PR177,PR160,PR161,PR185,PR184).
Also impotent quolity of solder PU100. During montage its ic, perhaps bad(cold) soldering.
СообщениеДобавлено: 26 сен 2022, 00:42
Thanks for replies. After careful inspection i found out 3.3v line to pwm controller was burnt so bad. Restored the line and now pwm powered by 3.3v but +Vcore is 2V so burns the cpu immediately. Checked every resistor in the area but they re all good.
СообщениеДобавлено: 01 окт 2022, 01:05
yusuf4511 I got the same board now. Fully working. I can make measures in vrm area if u want to.
СообщениеДобавлено: 03 окт 2022, 20:58
vit975 писал(а):
vit975
thats great to hear. I replaced the controller, voltages came back to normal 1.10V. But this time reset removes, all voltages and pgood signals present but no post code, reset not responding. Board starts and stops from pwrbtn, i dont know where to dig further
СообщениеДобавлено: 06 окт 2022, 03:08
yusuf4511 I got the same problem with Asrock P67 Pro 3. All supplies set up, no responding on reset button. I reflashed bios several times and changed the ic. The pch was reballed. Reset circuit was traced under the pch without problem. So, I came to the conclusion that I need the new pch. Waiting for it from Aliexpress now.
СообщениеДобавлено: 06 окт 2022, 20:52
Do you have power sequence for this type of PHC? Maybe first check it?
СообщениеДобавлено: 07 окт 2022, 09:03
sensey In spite of any reason there should be reaction on push the reset button if all resistors and others from pch to fpanel checked out and they all ok. rst 3.3V on pci, pci-e. I removed the pch from mobo and the reset circuit well up, but no reaction at all. Well, it's all on him)
СообщениеДобавлено: 07 окт 2022, 10:11
Yes you re right about PCH and reset sequence but on this motherboard, reset hooked up to TPU unit. It had dead sio it can also have dead tpu unit, i have no spare KB3270Q if i remember correctly. Lets see how your card will turn out with new pch
СообщениеДобавлено: 07 окт 2022, 20:28
I highly recomend to study this document.
СообщениеДобавлено: 08 окт 2022, 18:07
Sorry i cant reach the file because i dont have 15 messages. Can you hand it over PM?
СообщениеДобавлено: 09 окт 2022, 03:46
Please check your mail.
СообщениеДобавлено: 10 окт 2022, 02:43
yusuf4511
In my Sabertooth P67 at25f512b spi flash installed as O2U2. Check out PM.
СообщениеДобавлено: 10 окт 2022, 09:47
vit975 thank you for firmware but checked with my chip, they re both same
sensey thank you so much
СообщениеДобавлено: 10 окт 2022, 10:23
yusuf4511 Try to disconnect 28 pin of tpu ic from board which marked as o_rstcon, and then test reset circuit. It has the connection to sys_reset# pin of pch and could lock it.
СообщениеДобавлено: 10 окт 2022, 15:46
vit975 no luck, unfortunately everything points to PCH :(
СообщениеДобавлено: 11 окт 2022, 08:16
yusuf4511
At the 28 pin TPU 3.3v present?
СообщениеДобавлено: 17 окт 2022, 16:04
dima644
yes its present
В этой теме нет новых непрочитанных сообщений. Asus Sabertooth p67 прошивка TPU
в форуме Asus
Vlad_O
13 фев 2019, 21:00
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. asus sabertooth p67
[ На страницу: 1, 2, 3 ]
в форуме Asus
den2
62
12811
04 окт 2019, 20:15
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus SABERTOOTH P67. RT8015B померла или ещё что смотреть.
в форуме Asus
den2
12
4156
07 ноя 2019, 09:51
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus P9X79 Sabertooth rev1.02 Нет Vcore
в форуме Asus
sensey
11 сен 2017, 00:57
sensey Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus asrock P67 Professional Fatal1ty опознать транзистор
в форуме Asus
DamirSPb
01 июл 2020, 18:02
DamirSPb Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 23
