Текущее время: 28 июн 2024, 14:19
yusuf4511
Заголовок сообщения: Asus P67 Sabertooth No Vcore ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 10 сен 2022, 02:54 |
![Аватара пользователя](./download/file.php?avatar=128417_1668949506.jpg) |
Зарегистрирован: 17 янв 2022, 02:37 Наличности на руках: 61.09 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 52 Откуда: Midgard
Board came in bad condition, broken cpu socket and burnt sio. Changed both, all legs soldered well and cpu socket tested with tester. Board turns on but reset remains. VCCIO is 1.08 V and there s no vcore. ASP1000C has enable voltage of VCCIO which is 1.08 but there s no VRMVCC. Its connected to 3V directly with 0 ohm resistor and the problem starts here. the voltage on the resistor is 2.22 V, removed the resistor nothing changed, replaced the pwm controller everything is same. When i remove the controller voltage drops to 1.8 v, removed the cpu and force started motherboard with 3.3v injected to VRMVCC then vcore rises to 1.07 V but when i put the cpu voltage rises 2 V on vcore. I have never seen something like this, makes me feel desperate please help, thank you. Boardview : https://www.mediafire.com/file/t5az06ki ... 2X.fz/file
![](images/spacer.gif) |
dima644
Заголовок сообщения: Re: Asus P67 Sabertooth No Vcore ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 23 сен 2022, 10:14 |
Зарегистрирован: 20 окт 2011, 07:09 Наличности на руках: 10.54 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 110 Откуда: Челябинск
Also chek or replace at the bottom side of MB PU107,PU103,PU109 and his around area(PR176,PR177,PR160,PR161,PR185,PR184). Also impotent quolity of solder PU100. During montage its ic, perhaps bad(cold) soldering.
yusuf4511
Заголовок сообщения: Re: Asus P67 Sabertooth No Vcore ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 03 окт 2022, 21:58 |
vit975 писал(а): vit975 thats great to hear. I replaced the controller, voltages came back to normal 1.10V. But this time reset removes, all voltages and pgood signals present but no post code, reset not responding. Board starts and stops from pwrbtn, i dont know where to dig further
sensey
Заголовок сообщения: Re: Asus P67 Sabertooth No Vcore ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 07 окт 2022, 21:28 |
![Аватара пользователя](./download/file.php?avatar=38798_1668083422.jpg) |
Зарегистрирован: 07 мар 2015, 02:58 Наличности на руках: 53.26 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 401 Откуда: Одеса-мама
yusuf4511 писал(а): Yes you re right about PCH and reset sequence but on this motherboard, reset hooked up to TPU unit. It had dead sio it can also have dead tpu unit, i have no spare KB3270Q if i remember correctly. Lets see how your card will turn out with new pch
I highly recomend to study this document.
