Текущее время: 26 ноя 2026, 18:04
| Автор |
prospa
Заголовок сообщения: MSI GTX 1070 Gaming X 8GB freezes randomly, therm_overt goes low  Добавлено: 23 янв 2023, 18:53 |
| Интересующийся |
Зарегистрирован: 26 фев 2015, 20:28 Наличности на руках: 195.49
Сообщения: 71 Откуда: GREECE
hello, i decided to post it here to listen some advice from the pros :), i have this card and it freezes randomly it may work for 3-4 hours or it may freeze all time, all resistances and voltages are ok, the only thing i noticed is that when it freezes therm_overt signal goes low, temperatures is at 65-75 full load and hot spot at 75c in furmark or in game wz2, is there any safe way to bypass the hot unplug circuit to see if the fault is from gpu, thanks in advance :) please correct me if say something wrong.
MoneyBot
Заголовок сообщения: MSI GTX 1070 Gaming X 8GB freezes randomly, therm_overt goes low |
uncledim
Заголовок сообщения: Re: MSI GTX 1070 Gaming X 8GB freezes randomly, therm_overt goes low  Добавлено: 26 янв 2023, 21:16 |
| Продвинутый форумчанин |
Зарегистрирован: 22 дек 2016, 11:07 Наличности на руках: 1,135.36
Сообщения: 1102 Откуда: Moscow
prospa писал(а): any ideas poor contact in pcie6(8) power connector
prospa
Заголовок сообщения: Re: MSI GTX 1070 Gaming X 8GB freezes randomly, therm_overt goes low  Добавлено: 27 янв 2023, 21:22 |
| Интересующийся |
ok ill replace them and ill give you feedback :) Posted after 17 minutes 11 seconds: in working state Q508 pin1,2 0v and 3 0.60v, Q509 pin1 0.60v,2 pin3 0v, Q511 pin1 and 2 0v, pin3 3.20v,
when problem occures i have Q508 pin1,2 0v and pin3 3.20v, Q509 pin1 3.20v,pin2 2.80v pin3 2.80v, Q511 pin1 0v and pin2 2.80v, pin3 0v.
Posted after 8 minutes 25 seconds: i didnt replace them yet thats old measurements
