Текущее время: 20 ноя 2026, 15:49
 Заголовок сообщения: MSI GTX 1070 Gaming X 8GB freezes randomly, therm_overt goes low
СообщениеДобавлено: 23 янв 2023, 18:53
hello, i decided to post it here to listen some advice from the pros :), i have this card and it freezes randomly it may work for 3-4 hours or it may freeze all time, all resistances and voltages are ok, the only thing i noticed is that when it freezes therm_overt signal goes low, temperatures is at 65-75 full load and hot spot at 75c in furmark or in game wz2, is there any safe way to bypass the hot unplug circuit to see if the fault is from gpu, thanks in advance :)
please correct me if say something wrong.
 Заголовок сообщения: Re: MSI GTX 1070 Gaming X 8GB freezes randomly, therm_overt goes low
СообщениеДобавлено: 26 янв 2023, 18:28
so i removed D509(pin 1 INPUT_PEX6_DT2_R*, pin 2 INPUT_PEX8_DT2_R*, pin 3 INPUT_HOT_UNPLUG_DT_R throught a 10k resistance) and graphics card works just fine 2 days in a row, resistances are all ok, i also replaced it with another one and still had random freezes, any ideas?
СообщениеДобавлено: 26 янв 2023, 21:16
prospa писал(а):
any ideas
poor contact in pcie6(8) power connector
СообщениеДобавлено: 27 янв 2023, 17:15
3rd day again freezed, i tested with different psu and still the same
СообщениеДобавлено: 27 янв 2023, 20:58
Q508, 509, 511...
СообщениеДобавлено: 27 янв 2023, 21:22
ok ill replace them and ill give you feedback :)
Posted after 17 minutes 11 seconds:
in working state Q508 pin1,2 0v and 3 0.60v, Q509 pin1 0.60v,2 pin3 0v, Q511 pin1 and 2 0v, pin3 3.20v,
when problem occures i have Q508 pin1,2 0v and pin3 3.20v, Q509 pin1 3.20v,pin2 2.80v pin3 2.80v, Q511 pin1 0v and pin2 2.80v, pin3 0v.
Posted after 8 minutes 25 seconds:
i didnt replace them yet thats old measurements
 Заголовок сообщения: Re: MSI GTX 1070 Gaming X 8GB freezes randomly, therm_overt goes low  [РЕШЕНО]
СообщениеДобавлено: 28 янв 2023, 04:41
after alot of replacements, i tried to replace the pwm pu9511 too, after the replacement i had message on boot "please power down and connect the pcie power cable for this graphics card" yeaaayyyyy!
i can finally see the problem, i had 3.2v to LOWPWR_MODE, i replaced q33 and r232, gpu is on tests.. its normal that i have 3.2v to INA3221_LOW_PERF* ?
LOWPWR_MODE_Q1 at 1.7v and GPIO12_LOW_PERF* 1.7v too.
СообщениеДобавлено: 06 фев 2023, 05:34
so the problem was q33, after the replacement graphics card works just fine, problem solved.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MSI 1050Ti не поднимются все питания GPu therm overt
[ На страницу: 1, 2, 3 ]
demon_cold
69
3020
18 дек 2025, 14:16
demon_cold Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. GV-RTX 2060 занижен THERM-OVERT, высокое потребление
Raptor_3000
12
693
14 окт 2026, 15:42
feedme Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. GTX 1660SUPER ASUS EVO/ SCREEN FREEZES EVERY 5 TO 10 SECONDS
azzed
27 дек 2022, 12:58
cxav Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Acer 5741G (Compal LA-5891P) turns off randomly
andromedax
2936
31 май 2019, 18:36
andromedax Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Dell Alienware M15 R3 (LA-J522P) Randomly Boots but Stuck and Black Screen
в форуме Dell
labrepair
24 окт 2026, 16:04
labrepair Перейти к последнему сообщению
Сейчас этот форум просматривают: Bazhukovilia, Евгений Владимирович, strategu, zetor и гости: 88
