Hi, you can ty the following that has the correct subsystem ID "E396" but Samsung memory that has often very similar timings to Hynix. If it doesn't work you can manually replace the timings with the tool PolarisBiosEditor from another bios with the Hynix memory. https://www.techpowerup.com/vgabios/218418/218418
Alternatively you can search in all the UnverifiedUploads of Techpowerup, good luck :)
Сейчас этот форум просматривают: Linh1994, tyghvm и гости: 78
