Текущее время: 22 ноя 2024, 03:23
gligurski
Заголовок сообщения: Dell Inspiron 15 (Compal La-9104P) Short Circuit on VCCP Добавлено: 10 апр 2019, 17:39 |
Зарегистрирован: 16 апр 2017, 16:11 Наличности на руках: 16.05
Сообщения: 8 Откуда: Macedonia
I have a simple question. The motherboard is LA-9104P. Came to me already messed up bu someone else. There is КЗ (Short circuit - 0.4 Ohms) on the output side of coil Pl500 (VCCP ->+1.05VS) Since the CPU is the only thing that is powered by that power rail, can I be 99% sure that the CPU is fried? I tried to inject voltage on that point (coil removed, board disconnected from ЛБП), but nothing on the board gets heated up.
gligurski
Заголовок сообщения: Re: Dell Inspiron 15 (Compal La-9104P) Short Circuit on VCCP Добавлено: 10 апр 2019, 18:44 |
Thank you for your response. Will try it now and share the results later. Edit (I can only send one reply per hour): VCC_CORE (measured at PL701 with coil attached is 6 Ohm). I removed the TPS, found PQ203 and PQ205 КЗ, removed them, now on the same point of VCCP/VDD I have even less (0.3 Ohms). Can it be some capacitor shorted? I'll attach picture now. Afterwards I will remove ISL.
Последний раз редактировалось gligurski 10 апр 2019, 19:17, всего редактировалось 2 раз(а).
gligurski
Заголовок сообщения: Re: Dell Inspiron 15 (Compal La-9104P) Short Circuit on VCCP Добавлено: 11 апр 2019, 13:18 |
Yeah, that was what was I referring to when I said injecting voltage. I already did that on that line, but nothing heated up. Although, I was doing that with the processor attached, as it is soldered and I don't have infra-red station to be sure that I can re solder the CPU back with 100% precision. I can re solder smaller chips by hand (even PCH), but not something with > 1000 balls. At this point repairing this board became economically unfeasible, as I found UI circuits (the ones with 8 pins around USB - AP2301MPG) shorted also (removed them) - but the КЗ is still there. I will try few other things and report back, but it looks as this board is going to end up into the donor pile This is link with a similar problem viewtopic.php?f=41&t=30371Thank you for your help, it was helpful, I learned a lot from it. Will report if I find something later today.
