Текущее время: 20 ноя 2026, 10:05
 Заголовок сообщения: Dell Inspiron 15 (Compal La-9104P) Short Circuit on VCCP
СообщениеДобавлено: 10 апр 2019, 16:39
I have a simple question.
The motherboard is LA-9104P. Came to me already messed up bu someone else. There is КЗ (Short circuit - 0.4 Ohms) on the output side of coil Pl500 (VCCP ->+1.05VS)
Since the CPU is the only thing that is powered by that power rail, can I be 99% sure that the CPU is fried? I tried to inject voltage on that point (coil removed, board disconnected from ЛБП), but nothing on the board gets heated up.
 Заголовок сообщения: Re: Dell Inspiron 15 (Compal La-9104P) Short Circuit on VCCP
СообщениеДобавлено: 10 апр 2019, 17:34
hi there! you have short to ground via 1.05V ?
VCCP/VDD must be - 1.05V
also need to chek and replace
TPS51212DSCR IC
Последний раз редактировалось recordsman 10 апр 2019, 17:46, всего редактировалось 1 раз.
не будьте дампоепами...
СообщениеДобавлено: 10 апр 2019, 17:44
Thank you for your response. Will try it now and share the results later.
Edit (I can only send one reply per hour):
VCC_CORE (measured at PL701 with coil attached is 6 Ohm).
I removed the TPS, found PQ203 and PQ205 КЗ, removed them, now on the same point of VCCP/VDD I have even less (0.3 Ohms). Can it be some capacitor shorted? I'll attach picture now. Afterwards I will remove ISL.
Последний раз редактировалось gligurski 10 апр 2019, 18:17, всего редактировалось 2 раз(а).
СообщениеДобавлено: 10 апр 2019, 17:49
ok, also must be cheking PU700 ISL95833HRTZ - was two boards with this problem
and what is resistance on rail vcc_core ?
CPU 1.7 Ohm must be
СообщениеДобавлено: 10 апр 2019, 18:51
Same thing with ISL removed.
Resistance on PL701 - 5.9 Ohm
PL700 - 3.8 Ohm
On the marked place on picture - 0.3 Ohm.
СообщениеДобавлено: 11 апр 2019, 09:17
so remove CPU and try to supply this line from 1 volt to 5 volts slowly (with current under 2 A) and finde overheating details. It's possible to finde some broken ICs and mosfets//
СообщениеДобавлено: 11 апр 2019, 12:18
Yeah, that was what was I referring to when I said injecting voltage. I already did that on that line, but nothing heated up. Although, I was doing that with the processor attached, as it is soldered and I don't have infra-red station to be sure that I can re solder the CPU back with 100% precision. I can re solder smaller chips by hand (even PCH), but not something with > 1000 balls. At this point repairing this board became economically unfeasible, as I found UI circuits (the ones with 8 pins around USB - AP2301MPG) shorted also (removed them) - but the КЗ is still there. I will try few other things and report back, but it looks as this board is going to end up into the donor pile :-(
This is link with a similar problem viewtopic.php?f=41&t=30371
Thank you for your help, it was helpful, I learned a lot from it.
Will report if I find something later today.
СообщениеДобавлено: 11 апр 2019, 13:20
yeap
in this topik was replaced new IC PU300
and DDR3 plane
СообщениеДобавлено: 27 апр 2019, 21:57
The board was returned without repair. The thread can be closed now.
В этой теме нет новых непрочитанных сообщений. DELL 3521 (LA-9104P) Короткое по линии VCCP
в форуме Dell
DENART
3206
13 авг 2021, 10:39
Driver79 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. 5760 (DA0ZRJMB8C0) short circuit in battery
R EZ A
25 фев 2017, 12:29
R EZ A Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Yoga 500-14IBD (Intel 5200U) Rtc Short-Circuit
savcu
19 май 2017, 11:05
savcu Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Lenovo ideapad 100-15IBD (CG410/CG510 NM-681A rev:1.0) Short Circuit at PL701 (+1.05VS)
gligurski
29 янв 2019, 16:43
gligurski Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Rx 850 4gb sapphire - short circuit in the coil
TheMArcos
04 апр 2020, 05:08
TheMArcos Перейти к последнему сообщению
Сейчас этот форум просматривают: AndreyZagr и гости: 67
