Текущее время: 22 ноя 2024, 01:21
Часовой пояс: UTC + 4 часа
 Заголовок сообщения: k556u (asus) work slowly with mechanical hdd
СообщениеДобавлено: 27 июл 2019, 12:52
hi guys i have an asus k556u its new but no garanty so i have problem with mechanics hdd, when it work with ssd hdd its ok but when it work with mechanic hdd it work very slowly i change hdd with new one but almost it work very slowly...
 Заголовок сообщения: Re: k556u (asus) work slowly with mechanical hdd
СообщениеДобавлено: 27 июл 2019, 13:55
SSD fastests contra HDD.
СообщениеДобавлено: 27 июл 2019, 16:25
sure but its very very slow for open the window it take 1min...
СообщениеДобавлено: 27 июл 2019, 20:21
Depend of operating system version. Check mode of hdd controller - IDE or AHCI. Maybe need to clean hdd from old data or(and) defragment it. For best performance turn off video effect"s and use for background only clean colors without pictures, photos, etc.
СообщениеДобавлено: 28 июл 2019, 19:26
I TRYED BY 3 HDD ONE OF THEM WAS NEW AND DIFRENT OPERATION SYSTEM, ONE MORE THING IN SETTUP IT JUST HAVE AHCI MODE...
СообщениеДобавлено: 29 июл 2019, 00:48
Try this https://www.asus.com/us/support/FAQ/1034608/
https://remontka.pro/disk-usage-100-percent-windows-10/
СообщениеДобавлено: 29 июл 2019, 10:24
thanx for answer, i try it but noting change.... :(
СообщениеДобавлено: 29 июл 2019, 17:46
You can improve disk performance(+33%) by change HDD model from 5400 rpm to 7200 rpm, but best performance - change HDD to SSD for system disk.
СообщениеДобавлено: 30 июл 2019, 12:03
one more thing i check sata0 its directly related to pch. Could there be a problem with pch?
СообщениеДобавлено: 31 июл 2019, 23:06
(sorry for my bad english)
If the root of problem is pch - your work with ssd will be slowly too.
Can you set up optibay instead of your DVD-RW drive, use mechanical HDD in optibay and SSD in HDD slot? With this, you can use big space of HDD with fast speed of SSD; and of cource you can test speed of your HDD under installed OS.
Cyber_maniac
Люблю всё красивое, металличное...
TL866II, Vertyanov JIG, DS1102E, MFR PS1K, MPS/IR/ISL программатор, T12 и IR самоделки.
Если от образования в мозгах остались одни пробелы, то и мир вокруг чудесный, магический и непонятный.
СообщениеДобавлено: 01 авг 2019, 10:32
tanx for answer, realy i test many way, i used CADI for HDD for tsst SATA1 (DVD Slot)
but in all way with mechanic HDD speed is very very slow but with ssd no problem.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Zbook 15u G3 (6050a2892401) usb 2 not work (3 and 1.1 work)
R EZ A
29 фев 2024, 14:11
i001546 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Asus K556U (X556UV MB rev: 3.1) Не включается
Radio2865
25 июн 2019, 14:16
SyxaR1k Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus K556U (X556UJ_MB REV.2.0) Глючит тачпад.
Warlcok_Lord
28 окт 2019, 08:32
Warlcok_Lord Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. asus k556u (x556uq) не грузит ОС
yurabratsk
22 июл 2021, 10:55
bass Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Asus k556u (X556UV rev3.1) нет инициализации
Dragg0n
16 июн 2022, 14:04
Dragg0n Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 31
